Question about Canon PIXMA MP530 All-In-One InkJet Printer
PIXMA IP90V only prints in black and white
I was changing the black ink cartridge on my printer. A pop up occurred asking me if I wanted to print in black and white or color. I picked black and white since I only had a black cartridge. I figured I could select color later when I put in a new cartridge. A couple of weeks later I replaced the color cartridge and it would not print in color. I looked for the dialogue box which said it is only available on select models (under maintenance). I didn't find it. The only thing that I can think of is that I downloaded the driver online and it was not the correct one for the printer but that it worked anyway and the pop up occurred. Of course, I reinstalled the driver with the one given to me with the printer, No help and probably confused the issue more. Any help out there. Got any ideas on how to flash the Pixma memory?? Thanks!
  • 685 Answers
Try unplugging it and plugging it back in.when you reinstalled it did you do a fresh install?if not install again.first take out the old one
Posted on Nov 19, 2008
The printer's lying to me
The printer requires both cartridges to have ink before the printer will initialize and operational. Even if you are only printing black and white both cartridge have to contain ink or the printer will error out. This is standard on all ink jet printers from every manufacturer. You will have to get ink before you can print.
Apr 28, 2013 | Canon Pixma MX410 All-In-One Printer
Why I can't print in black and white.
It may want the cartridge in to protect the heads. Put an old empty on in. Make sure to go to Start, Settings, Printers. Select the Pixma and go to Printing Preferences. Once here set the COLOR OPTIONS to Grayscale, print black ink only.
Hope this workds for you.
good luck
Feb 19, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
I want to use black ink only and stop wasting color ink
Go to Control Panel->Printers. Then right click on your printer and select printing preferences. There you will see an option like Print in Grayscale or Black and White only.
However, please note that some printers although they are set to print in grayscale they also use the color cartridge and some even don't allow you to print in grayscale if the color cartridge is empty. Why is that? Manufacturer's way of charging you more money.
Feb 11, 2010 | Canon PIXMA MP470 All-in-One Printer
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
I have a Pixma iP4500 printer.When I buy ink, the #5 black ink tank isn't included in the box. There are 2 black ink tanks in the printer.The #8 black ink tank hasn't been used and the #5 is out(as are the...
There are two black inks in the printer so that when you are printing only black and white such as printing a fax or when you set print in B/W for printed matter, the printer will use the larger ink cartridge. When you are printing in the multicolor mode (most people don't know the difference) the printer will use the finer black ink in the smaller cartridge. This smaller cartridge is used for photo printing and multi-color page printing. You cannot mix the two blacks since the larger cartridge is a coarser ink.
Jun 06, 2009 | Canon Pixma iP4500 InkJet Printer
Printer will not print black ink.
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't's what I did:
1. open the top lid to have the cartridges that are inserted in the print head to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head..slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out.
5. Have severasl paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. May color and black and white print is back!
Hope this helps.
Feb 16, 2009 | Canon PIXMA iP90v InkJet Printer
Color ink cartridge out. Won't let me print in black only?
Do this, press and hold the "Stop" button on the printer for 10 seconds that should clear the fault set by the empty ink cartridge.
Jul 21, 2017 | Canon PIXMA iP1800 InkJet Photo Printer
I have a Canon Pixma ip 1600 printer. My coloured cartridge has just run out but I mostly print in black and white anyway so don't really want to buy another one just yet. The problem is my printer just...
That is the way your printer operates - if cartridge has no ink or is low it will stop operating completely. It sucks but..........................Those bastards want you to buy their ridiculously overpriced ink!
Jun 20, 2017 | Office Equipment & Supplies
That would require a very special "white ink" print cartridge for your printer. The regular color ink cartridges won't do this, since they can only make the black paper "black-er" when it prints ink on the paper. You may want to ask the manufacturer (Canon) if they make a special "white ink" cartridge for that printer, or know of someone who does. Your only other option is to make a "negative" print image in Photoshop, or a similar graphics software application, and then PRINT the black ink on white paper... which will then leave everything you want to "print white" as an unprinted area on the white surface of regular paper. (Note: with such heavy printing you would want probably want to use a heavier grade of paper, such as 28# or 60#.) This will use a LOT of ink, but it may be the only way you can accomplish your goal. Hope this helps...
Aug 04, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
42 people viewed this question
old marine
old marine
