Question about Makita 10" Miter Saw LS1030N
I need a owners manual for my makita LS1011
A friend just gave me his old Makita Ls1011 and i need the owners manual fo it any help with this would be grealty appreciated
  • rob gunton Mar 09, 2009
    I have no manual as purchased a used item.
    I have no manual
    New Friend:
  • 55 Answers
  • Makita Master
  • 1,828 Answers
How to remove turn base from base on a Makita LS1011 Slide Compound Saw?
If you have removed the kerf boards and the center bolt the saw will lift straight off the turn base. It is possible the aluminum is deformed a little, but it will pull straight up and off if that bolt is out
Nov 27, 2014 | Makita Saws
Makita L1011 compound sliding saw with sticky miter table
The LS1011 doesn't have a table angle release lever like the newer models so it's harder too swing the table from angle to angle, this also causes the plastic swing body to crack. Have you loosened the locking screw for the table? The table may have to be removed and the pivet shaft greased. I had this problem with an old Makita Table Saw 10" 2600.
Feb 01, 2013 | Saws
I need the owners manual for a ls1011 slide cutoff saw ....10''
you can try going to "makitausa.com" and type in your model number for the manual
Jun 17, 2011 | Makita Saws
I just acquired an LS1011 Makita saw. How does
unscrew the handle in the front to change, also I would recommend going to Makitatools.com and typing on your model number to download a users manual for this tool, it would be helpful to get the most out of it.
Oct 25, 2009 | Makita 10" Miter Saw LS1030N
Makita LS1011- when power is turned off there is a rumbling noise coming out of the saw. I've taken it apart and can't find any broken parts. I suspect worn gears? Anyone have this problem?
Hi, Thanks for getting back to me, sorry for not making it clear but it was a 2 part question. I have a LS1011N and assumed it would have an electric blade brake like mine. When the bearings are bad it doesn't take long to also wear out the brushes so the electric brake not working full time is a symptom of that failure. Since yours doesn't have a brake then you are right in half of your guess of the gears the other half would be bearings. The only way I know to tell with the thing still assembled is to hold a screwdriver to the rear of the motor case and put your ear on the handle and run the saw and listen for the sand like sound of a bad bearing. If you don't hear anything like that it has to be worn gears and for that you have to look. Good Luck, this should Fixya!
Mar 18, 2009 | Makita 10" Miter Saw LS1030N
Blade guard spring assembly for LS1011
here ya go Bob hope it helps
http://www.ereplacementparts.com/makita-ls1030n-miter-saw-parts-c-97_98_99_321.html
Jan 01, 2009 | Makita 10" Miter Saw LS1030N
How do you ulock the saw to pull up the blade so you can put the wood underneath to cut
push down gently on the arm and reach around to the rear of saw with your right hand and pull retainer pin the arm should release and allow usuage of your saw.
Oct 08, 2008 | Makita 10" Miter Saw LS1030N
Makita 10" Miter Saw LS1030N Logo
2,550 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
