Question about Sony CDX-GT300 CD Player
Subwoofer in my car works only on tuner
I purchased a Sony CDX Gt-520 Head Unit for my car. I already had an amplifier from Interfire and 2 10'' JL Audio Subwoofers. I hooked up everything and it works extremely well with the tuner. However when I switch to the cd player or my auxilary (which has my ipod connected it) the amplifier shuts off and the subwoofers do not play. I have reset my head unit thinking it was a setting but it did not work. Do you have any ideas on what could be wrong?
The product underneath is not my product but you couldn't find mine.
    Problem Solver:
  • 15 Answers
I had the same problem. most radios have a power antenna wire and an amp turn on wire it sounds like your amps are being turned on by the power ant wire that loses power when you put a cd in try swapping the blue with blue and white wire this should solve it
Posted on Nov 28, 2008
Sony CDX-GT44U doesn't start. After switching off
car running or not? if it works with the car off then I would check the alternator, your car will require more power from your already low battery causing your radio to not play. If it won't start either way check all of the wiring going to it including your speakers. Could be loose or shorted wires. Could also be the switch on the unit. only way to know is to take it apart and test the switch. If all else fails then have it looked at.
Aug 19, 2013 | Sony Cdx-gt44u Cd Mp3 Car Stereo Player...
How do u know if A sony xplode XM-552ZR amp is on and how do u connect it to a sony xplode cdx-gt570 head unit.
Just to the left of the output (speaker) terminals, near the top of the amp, there's an LED marked "POWER/PROTECTOR". If the amp is connected properly and powered on, the LED is ON.
If the amp is being used for normal speakers, use a pair of RCA cables and connect the left/right channels to the appropriate inputs on the amp. The switch marked "LPF" should be "OFF".
If the amp is being used with the channels bridged for a subwoofer, use an RCA "Y" adapter and connect the single "Sub Out" preamp output from the head unit to both amp inputs. The switch marked "LPF" should be "ON" and the crossover set to about 80-100Hz.
Nov 03, 2010 | Sony Z2X-1200 SPL Car Amplifier (1200...
I hooked up my jl audio 500/1 and it turns on but there is no response from the subs.
-Did you verify that you have an input signal?
-Is the amp going into protection?
-If they are bridged mono, are they bridged across the appropriate terminals?
-If there is a subwoofer line out on your head unit is it muted or turned off?
Jan 04, 2010 | Jl Audio 500/1 Car Audio Amplifier
MEX-BT5700U, no sound in speakers in CD source, tuner source OK.
What many people do on this model is connect the remotes wires improperly. Use the solid blue wire for the amp and the blue with white stripe for the connection to the car.
Dec 06, 2009 | Car Audio & Video
Subwoofer doesnt hit hard at all with this amp.
set gain to match head unit.its not a volume control.turn bass up.on unit and amp.and not knocking what you have but sony well theres much better.
Nov 14, 2009 | Sony XM-2200GTX Car Audio Amplifier
Installed sony cdx-gt280 in car, everything works fine until cd is inserted and then the head unit starts to flash on and off continually. Do you have any idea what might be wrong?
When you run a CD the radio needs more current then when you are using only the tuner.
Check that the positive power cable is connected properly and thick enough. Do the same with the ground... I have had this when the ground cable is not connected properly or too thin.
Try grounding it straight to the battery or body with a thicker cable
Nov 03, 2009 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Hooking sub up
Hello missywarden,
According to the specifications, the amp is capable of "tri-mode" operation, that is, running normal speakers on the individual channels while also powering a subwoofer in bridged mode.
Your sub needs to be a minimum of 4ohms and should be relatively efficient. I'd look for a sub that has an RMS power range of from about 75 watts up to a maximum of 250 watts.
The sub connects to the leftmost speaker terminal (positive - right channel) and the rightmost speaker terminal (negative - left channel).
It's not going to be a really loud subwoofer. The power is 360 watts RMS which will be shared by the normal speakers and subwoofer.
Hope this helps.
Aug 05, 2009 | Power Acoustik TS620-2 Car Audio Amplifier
Very little sound
make sure all your gains are turned up to atleast half.
Check your head unit, make sure your low pass frequency for the RCA's amp is set to high or set to more than 0. Make sure you don't have your fader set toward the front of the vehicle or you won't get any bass, but the subwoofer will be pulling only what the head unit is sending to the amplifier.
if that doesn't work I would try another pair of patch cables.
Do you have another subwoofer you can swap out to test your subwoofer with?
I have a subwoofer that has something wrong with the coil itself. Has your amplifier blown any fuses? If so the subwoofer coil is bad.
Also make sure you have a solid ground for your amplifier.
Hope this helps!
Apr 22, 2009 | Jl Audio 13W7 Car Subwoofer
Sony CDX-GT710 subwoofer installation trouble
HI
I have a cdx gt 710 deck i am having a problem with.i had it in my grand prix and took it out to put in my new to me honda.When i did this i turned it on , the deck went to test1 mode.it looks like it is in demo mode.I had this problem when changing the battery.The tech fixed it before by pressing two buttons together at the same time,Of course i forgot witch two buttons.
If you could help it would be great.THANKS
Jun 08, 2008 | Car Audio & Video
Rear speakers
If have a VOM check for voltage at the amp. If not, a cheap trouble light (often in cheap tool bin) will tell if have voltage. this will tell if the problem is the head unit or the amp or wiring.
Occasionally the remote wire will have a fuse in line.
Jan 05, 2008 | Sony CDX-GT710 CD Player
Sony CDX-GT300 CD Player Logo
243 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
