Question about D-Link DI-634M Wireless Router (DI634M)
D-link 634M wireless router problem
I bought that router two days ago..i made all the necessary installations but my laptop and my flatmates' laptop don't connect to the router wirelessly...i had the same problem with that router and i thought it was the routers problem but it isn't because i got and exchange.... i can connect to other wireless routers but with this one i don't know why that is happening...any solutions please????
  • geo peri Dec 11, 2006
    from where can i change this?? do i need to click clone mac adress??
  • geo peri Dec 12, 2006
    i have tried that but still nothing happens...do you think that i should disable the super g that my router supports??
I have the same problem with the D-Link Router.I bought the 624M origionally and it wouldn't work so I exchanged it for the 634M. My old router worked but I thought I needed more speed and for $20 after rebates it was a good deal... Or so I thought. I too have tried changing settings without success. Then updated the firmware. Now the router cycles on and off every few seconds. I was looking for D-LInk support when I happened upon this site. Has anypne been able to make a D-Link Mimo router work?
Posted on Apr 30, 2007
    President:
  • 2,961 Answers
Assuming wireless connection is enabled in the router(if you have the option), and it was set up initially through a RJ45 lead; make sure the router is not using 108 mbps streaming, as your laptop probably only has 54 mbps capability. See if you can set it to 54 mbps and re-start router.
Posted on Dec 11, 2006
  • 1 more comment
  • andrew pester
    andrew pester Dec 11, 2006
    You would set this up in the routers settings via your internet explorer programme
  • andrew pester
    andrew pester Dec 12, 2006
    Yes that's what i said to do in other solution, 108 MBPS may not be supported by your laptop on 54MBPS.
    Give it a go.
  • andrew pester
    andrew pester Apr 30, 2007
    If you have a problem, start a fresh, because the post you did ends up as a solution and can get missed.
    The same may apply to you as other post, most recievers only accept 54MBPS connection and from a mimo router the signal transfer will be 108 or 125MBPs, so causing you to lose connectiom.
    You have paid more for a router for the speed, this is not isp connection speed but transfer speeds from router to pc.
    Go into your routers settings and change the transfer speed to 54MBPs if you are wireless on a laptop, or check the capabilities of your network cards supported speed.
Can I use a D-Link DI-634M as a repeater? how?
Sorry, no, the DI-634M does not have the repeating function.
Mar 06, 2011 | D-Link DI-634M Wireless Router (DI634M)
Conection wireless dlink di-634m with notebook windows vista no work !! help !
Make sure you have the ipx and spx protocol install on the wireless adapter.
Nov 14, 2009 | D-Link DI-634M Wireless Router (DI634M)
How to reset the d-link di-634m wireless router
go to this link to to reset your d-link 634m manually: http://www.retrevo.com/pdf/426bh043/6/Hardware+Overview#q=D-link+DI-634M
Apr 14, 2009 | D-Link DI-634M Wireless Router (DI634M)
What is the d-link part number for power adapter for D-link Di-634M router?
what is the d-link part number for power adapter for D-link Di-634M router? How can I get this?
Mar 28, 2009 | D-Link DI-634M Wireless Router (DI634M)
DLINK DI-634M WIRELESS ROUTER USED AS A REPEATER?
No. Here is the help guide:
http://support.dlink.com/Emulators/di634m/help_men.html
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 19, 2008 | D-Link DI-634M Wireless Router (DI634M)
My wireless router wont work
Run a cat5 cable from the laptop to a cat5 port on the router, open internet explorer in the address window type http://192.168.1.1 or what ever the IP address of the router once you have accessed the router create your PPPOE internet connection, enter your Internet Service Provider's username and password. Once you have done this, disconnect the cat5 cable and connect wirelessly to the router from the laptop. If all this fails press and hold the reset button on the back of the router for 10-15 seconds this will reset the router to factory defaults. connect to the wireless router and create the PPPOE connection. BPCS
Dec 29, 2007 | D-Link DI-634M Wireless Router (DI634M)
D-link router connection problems
I'm guessing you're saying you've left the security open on the pc's, but what about the router? You can connect to most wireless routers with a TCP/IP cable. Try that and see if you can check your wireless router's settings. It may have some security settings enabled.
Nov 18, 2007 | D-Link DI-634M Wireless Router (DI634M)
My D-Link DI-634M wireless Router never worked
Hi, Like most router products, the reset is at the rear near the power jack connector. You have to use a straightened metal paper clip to press on the hole to access the small push button underneath. Do this with the power connected. Press for a couple of seconds or till the leds blink. Once done, the unit will be set to factory default settings and you will have to configure it again. If this does not work, perhaps you have tried to update the firmware which: a. did not finish; b. was not successful or c; got corrupted. The only recourse for a router with faulty firmware is get RMA & replacement from D-Link. Post back should you need additional information. Good luck and kind regards.
Aug 26, 2007 | D-Link DI-634M Wireless Router (DI634M)
D-Link DI-634M Wireless Router (DI634M) Logo
149 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
