Question about HP PSC 1510 All-In-One InkJet Printer
Printer sharing How do I enable another computer to share my printer? I have windows xp and they have vista. I am having trouble making the network setup disc for their computer from mine.
  • drorke Nov 20, 2008
    we are connected through a router. problem is that I am supposed to make a network setup disc so the vista computer can get set up and I am unable to do that.
    have done all of the above, vista needs my xp to all it to share. I don't know what a flash/thumb drive is but will check it out. Thank you.
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
Initially, pls try enabling the Share feature of the printer in XP. Pls go to Start, Printers & Faxes, right click on the printer you want to share, click on Sharing...follow on screen instructions. A few suggestions:
  • verify that the Vista and the XP uses the same Workgroup;
  • verify that other shared folders and files could be viewed from each other;
  • verify that each could access the internet from a single connection.
A few questions:
  • do you have a router or a hub;
  • how are the XP and Vista connected to the network, LAN cables or wireless.
  • confirm that it is a HP > PSC 1510 All-In-One InkJet Printer that is connected to the XP machine.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 19, 2008
  • Louie  Role
    Louie Role Nov 20, 2008
    Lets try two alternatives:
    • in lieu of a setup disc, would the system allow the setup files to be saved on a flash/thumb drive? and/or
    • enable printer sharing in the XP machine, on the Vista machine, click on Printers & Faxes, Add Printer, Next, select A network printer....., select Browse for a printer, choose the one installed in the XP, Yes to all.
Unable to find printer sharing for mfc6890 over window xp
To set up printer sharing in your home network, you need to configure printer options in the control panel of Windows XP Operating System. You could get a menu while right clicking the printer icon in the Control Panel. From this, you need to select the sharing option. You also need to make sure that you have enabled printer sharing option in the network card properties. To connect a printer in the network you need to set an IP address for your printer. If you have any troubles with printing with your printer in the network it might due to the errors in the network. So, you need to make sure the network connection.
Apr 06, 2011 | Brother MFC-6890CDW Printer
Tip
HOW TO SHARE FILES AND PRINTERS BETWEN WINDOWS 7 AND VISTA With three different...
With three different versions of Windows being used now, you’ll probably find yourself trying to share files or printers between them. Today we take a look at how to share files and printers between Vista and Windows 7 machines.
In this example we are on a basic home network using Windows 7 Ultimate (64-bit version) and Windows Vista Home Premium SP2 (32-bit version).
Set Windows 7 Share Settings
On the Windows 7 machine we need to set up a few things in Advanced Sharing Settings. First type network and sharing center into the search box in the Start Menu and hit Enter.
Then click on Change advanced sharing settings…
Now in Advanced Sharing Settings, make sure to turn on network discovery, file and printer sharing, and public folder sharing. Make sure these are enabled in both the Home or work and Public profiles.
Depending on your setup, you might want to turn off password protected sharing. Other wise you’ll need to enter the password for each machine in, which isn’t that big of a deal. Turning it off while you’re setting it up makes things a bit easier though by saving a step.
Set Vista Share Settings
On the Vista machine we need to double check and make sure it’s sharing settings are ready to go. Right-click on Network and choose Properties.
The Network and Sharing Center opens up. Under Sharing and Discovery we need to turn on File Sharing, Public Folder Sharing, and Network Discovery.
Also on the Vista machine you might want to turn off password protected sharing … but it’s completely up to you.
Share Files Windows 7 View
Now that we have the correct Settings On each machine, it’s time to put it to the test. Open up Network on the Windows 7 machine, and you should see all of the machines on the network. The Vista machine in this example is VISTAGEEK-PC.
There was no need to enter a password to access the Vista machine because password protection is turned off. But now you can go through and see the User Shared folders. In this example both public and Users directories are shared.
Share Files Vista View
Now on the Vista computer, double click on Network and you should see the Windows 7 machine (where in this instance it’s MYSTICGEEK-PC).
I enabled password protection on the Windows 7 machine so we can take a look at the login screen that will be displayed before connecting.
Then you’ll see the folders and devices that are shared. Here you can see the HP printer connected to the Windows 7 machine is available.
And you can continue browsing through all available shared folders and files.
Printer Sharing
As we showed above, you can see the printer connected to Windows 7. Let’s make sure we can connect to it and print a test document. In Vista click on the Start menu and type printers into the search box and hit Enter.
Right-click on the shared printer and select Properties.
Under the General tab click on the Print Test Page button.
The following message is displayed while the test page prints out on the printer connected to your Windows 7 machine.
Another test you might want to perform is opening a test document and making sure you can print that to the Windows 7 printer.
Provided everything prints out successfully you might want to make it the default printer.
Troubleshooting
If your machines aren’t able to see each other or the printer isn’t working…here are a few steps you might want to use to determine where the problem is.
Double check to make sure Network Discovery and File and Print Sharing is enabled on both machines as shown above.
In this example both machines are connected to a Belkin home wireless router and IP addresses are dynamically assigned. If you are using Static addresses make sure you can ping the IP address of each computer. If not, double check the assigned IP Address and cabling of each computer…
If the printer isn’t working, double check to make sure you have the latest drivers for each OS installed.
on May 24, 2010 | Computers & Internet
Tip
Network Windows 7 with Xp and Vista
Windows 7 includes a new way to share data between all computers in the house with the Residential Group. But only when computers running Windows 7 may join the Group residential and enjoy the new features of sharing, playing multimedia files remotely, etc.. If you have computers running Windows XP or Windows Vista networking with Windows 7, you can still share your files and printers in Windows 7 "old" by following the instructions in this case practice. Below are the steps to do the same.
Check the workgroup:
To be a network, your computers with XP, Vista and Windows 7 should be part of the same workgroup.
Click the Start button. Right-click Computer (My Computer in XP) and click Properties.
In the Settings area of the computer name, verify the name of the working group. The default name is WORKGROUP but you can customize it by clicking the Change Settings button.
Make sure it is the same on other machines on the network. Under XP, the information is in the Computer Name tab.
Enable Sharing:
To enable sharing in Windows 7, you must change the settings of the Network and Sharing Center.
Click Start, then Control Panel.
Click Network and Internet and then click Network and Sharing Center.
In the left column, click Change sharing settings advanced.
Verify that the options Enable network discovery, Enable file sharing and printer sharing and Enable so that anyone with network access can read and write are checked.
Click Save Changes.
on May 19, 2010 | Computers & Internet
Vista and xp network
  1. All computers should have installed and enabled file and printer sharing, which you can see and change in the properties of the network connection.
  2. All computers should have enabled file and printer sharing as an exception for the Windows firewall.
  3. Sometimes you need to install the IPX protocol on the network connection.
May 05, 2009 | Computers & Internet
Windows Vista
In the start menu click network,on the bar on top click network and sharing center,scroll down and enable network discovery.
Apr 20, 2009 | Microsoft Windows Vista Ultimate Edition
Tip
How to use a printer?
Install a New Printer DIY installation of your new printer in Windows. You may have a new printer with an installation disc, or maybe a second hand one with no disc. Either way you will find out how to install your printer onto your computer.
Add Network Printer If you have two or more computers in your house or office you will only need one printer installed on one computer for both to have printing privileges. This article shows you how to add a network printer to Windows Vista.
Add Network Printer Applies to Windows XP. Even though the instructions are similar to installing a network printer on Windows Vista, there are a few extra tips that might be interesting.
Enable Printer and File sharing How to enable in Windows XP And Vista. If you want to share a printer on your network you must enable printer sharing. It is not hard to do but it will not work if it is not enabled.
Path to your network printer How to find the path \\server\printer. If Windows does not find your network printer automatically then you will need to know the path to your network printer.
Set Network printer permissions Set who can change printer settings in Windows XP and Vista. I personally like to let everyone on the network just print and not be able to change too many settings to do with the printer.
Network printer has problems printing - You do not have permission to use selected printer.
Quick Printing Trick Cool printing trick for Windows Vista and XP.
on Jan 18, 2010 | Office Equipment & Supplies
How to share internet connection on Windows Vista OS. I want to share internet connection between two Laptops using Windows Vista Operating system and the other using Windows XP. The Host computer is...
All right let's call your Vista computer A and your Xp computer B. First you have to bring the two computers into LAN. If you already did this, please skip the next eight steps.
Step 1: In Vista, before doing this you should enable Sharing and Discovery. You can do that by going to Control Panel -> Network and Sharing Center. Under the section ‘Sharing and Discovery, enable Network discovery, File Sharing, Public folder sharing and others if you want to. (See picture below)
Step 2: If your LAN card that is connecting to another computer is installed, it will be shown under Control Panel -> Network Connections.
Step 3: Right click that local area connection and click properties.
Step 4: Under the tab ‘Networking’, click the properties Internet Protocol Version 4 (TCP/IPv4).
Step 5: Click the radio button to ‘Use the following IP’ and give an IP address (For example, IP address: 192.168.0.1 and Subnet Mask: 255.255.255.0)
Step 6: Don’t give any other information, Click Ok and close everything.
Step 7: In computer B, which is the XP, make sure you enable the LAN card which is used to connect to computer ‘A’. Here you need not give any IP information as Computer ‘A’ will assign an IP address dynamically. If it’s not working make sure there are no IP assigned and change the properties to ‘Obtain an IP address automatically’.
Step 8: Test the connection by pinging. (You can do this by typing ping 192.168.0.1 or whichever is Compter ‘A’s IP in the comand prompt)
NOW your computers are connected. Now to share the internet:
Right click LAN card which is connected to Internet under Control Panel -> Network Connections and click ‘Sharing’ tab and enable both the options to share Internet. (Note: Unless there is another enabled LAN setting you will not be able to see the shared tab under properties)
Click Ok and close. This option is given by the Windows OS known as ICS (Internet Connection Sharing).
Now you can use Internet from both Computer A and Computer B from a single connection.
So this is the setup you need on the Host computer as you requested, if you turn out to need help witht he XP one too, let me know:)
Feb 14, 2009 | Compaq Presario 700 470024-192 Notebook
Use two computers with one printer
Printer Sharing (This is good for Windows 2000, XP and Vista)
Sharing will be very easy if your network is working.
You need to consider the computer where the printer connected as the "Host" and the other computer that wants to print to that printer as the "Client".
Before you do such sharing, you need to acquire each computer's IP address.
You can do it by accessing MSDOS Prompt and typing in ipconfig/all. Write down your IP addresses and the share name on a paper.
For your Host:
Install the driver, make sure that you can print on direct bi-directional connection (such as USB).
Go to Control Panel >Printers and Faxes* >Sharing >Share this printer >Type in your share name, good example is PRINTER (this is case sensitive).
For your Client:
Install the driver, make sure that you can print, same with the Host.
Go to Control Panel >Printers and Faxes* >Properties >Ports >Add Port >Add local port type in \\ (the IP Addressof the Host) \ (share name), click OK.
ex. \\192.168.1.3\PRINTER (watch your backslash, no spaces)
*Term used is "Printers" for Windows Vista and Windows 2000
Oct 23, 2008 | NetGear FS105 5x10/100 Mbps Networking...
Networking XP and Vista
Since I won't be able to read your response, you can probably try these steps if it concern file sharing between your XP and Vista computer;
-Make sure that both machine have the same Workgroup Name.
-Turn off Firewall on both machine.
-Download the LLTD patch for Windows XP http://www.microsoft.com/downloads/details.aspx?FamilyId=4F01A31D-EE46-481E-BA11-37F485FA34EA&displaylang=en
- Make sure file and printer sharing is enabled for both machines.
- Restart the computer and check if they can now see each other wheb you view entire workgroup.
Hope this will solve your sharing problems.
Regards,
Jun 29, 2008 | HP Computers & Internet
Setting up a new computer on a wireless network
hello Danj29,
I suggest you make sure that your Vista is configured to connect to a private network. To do this follow these steps:
1. Click Start, right-click Network, click Properties.
-The Network Sharing Center window displays the network type in parenthesis after the network name.
2. To the right of the network name and type click Customize.
3. In the Set Network Location dialog box, click Private, and then click Next.
4. In the Successfully set network settings dialog box, click Close
By changing your network location type to private, network discovery is automatically enabled in the Sharing and Discovery section of the Network and Sharing Center window. The following additional file and printer sharing options must be manually enabled:
  • File sharing
  • Public folder sharing
  • Printer sharing
  • Password protected sharing
When all of these sharing and discovery options are enabled, your computer can:
  • Locate other computers and devices on your home network and have other computers locate your computer
  • Share its folders
  • Share its Public folder
  • Share its printers
  • Require user names and passwords for other computers that connect to the shared folders and printers of this computer
To enable file sharing, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to File sharing.
  2. Within the File sharing settings, click Turn on file sharing, and then click Apply.
To enable public folder sharing, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Public folder sharing.
  2. Within the Public folder sharing settings, click one of the following:
    • If you want to share the public folder so that other computers on the network can access the Public share to open files, but not create or change files, click Turn on sharing so anyone with network access can open files. This is the default setting.
    • If you want to share the public folder so that other computers on the network can access the Public share to open files and also create or change files, click Turn on sharing so anyone with network access can open, change, and create files.
  3. Click Apply.
To enable printer sharing and share all of your connected printers, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Printer sharing.
  2. Within the Printer sharing settings, click Turn on printer sharing, and then click Apply.
[Optional] To enable password protected sharing, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Password protected sharing.
  2. Within the Password protected sharing settings, click Turn on password protected sharing, and then click Apply.
Hope you find this helpful info and thanks for using the FixYa service
Kind regards
Feb 14, 2008 | Computers & Internet
HP PSC 1510 All-In-One InkJet Printer Logo
78 people viewed this question
Ben Johnson
