Question about HP Compaq dc5100 Small Form Factor PC Desktop
Desktop won't complete boot
Compaq Presario starts booting but powers off/on at the Windows screen and starts the boot over again. It is in a continual loop. Tried booting in Safe Mode...same problem.
    President:
  • 2,961 Answers
Open up the desktop and replace your CMOS battery, or atleast test it and see if the re-booting stops. If not and you have your XP installation disc you may have to do a system repair, start your pc with disc in and press enter when prompted, but make sure that your cd drive is set up as first boot in the bios.
Posted on Dec 11, 2006
Why won't my compaq presario 1250 load windows?
1 - You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose safe mode).
Win 7 - Start > Search type System Restore
XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
2 - Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 11, 2012 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Trying to reinstall windows XP on Dell Dimension 8300....cant' start up using the CD drive...
Inpect the computers preexisting operating systems to ascertain compartibility to windows XP. Only XP computers would recognise XP operatign systems. Attemptign to install windows XP onto alternate system either windows 98, 2000, mellanuim or Vista XP or 7 is least achieveable unless the old system were erased or new empty storage disk drive were acquired and replaced.
Feb 03, 2011 | Compaq Presario 5000 PC Desktop
No complete starting
Unmountable boot volume means your harddrive has gone out.You will have to get a new one and load your os again.Sorry:-(
Apr 08, 2010 | HP Compaq Presario C502US Notebook
Hp compaq presario sr1830nx will never go past error page that asks which mode ud like to start in..If i pick any the screen goes black after
You will have to Boot on a Windows DVD, and do a "Repair Install" failing that you will have to completely re-install Windows. from the DVD
Feb 11, 2010 | HP Compaq Presario SR1830NX PC Desktop
My Compaq laptop will not boot up. It gets only
Tturn on your computer, then, before the windows boot screen appears, press the F8 key, this should bring up the start options , if it does not, turn off , turn back on and try again.
On the start options use the up/down arrows on keyboard to select "last known good configuration", press the enter key. Windows should start as normal if it does not do the process again but instead select "safemode" .
Oct 14, 2009 | HP Compaq Presario v4000 Notebook
Still wont boot
Disk boot failure is usually a sign that your operating system has become corrupt in some way.
If you've got your Windows disc, put that in the CD rom, then boot the computer.
There's a "repair" option that you can select, instead of re-installed Windows.
That *should* fix the problem.
It's also (thought unlikely) possible that your hard drive has died completely.
Mar 19, 2009 | HP Compaq Presario SR1303wm PC Desktop
Compaq logo
It appears that the hard disk drive is not being seen in the Bios. Ensure that both the power and data cables are connected to the drive and the controller. try booting again.
Jan 24, 2009 | Compaq Presario 5000 PC Desktop
Hp compaq presario v3000 is not loding the OS, show an error
  • as you boot the computer, start tapping the F8 keys
  • From the boot menu, select Safe Mode
If this seems to work, you can try restoring the computer to an earlier point from Start > All Programs > Accessories > System Tools > System Restore.
If Safe Mode also fails to load, you would have to check your disk for errors or you may have to install XP all over again.
Please get back, if you need any further help.
Jan 09, 2009 | HP Compaq Presario SR1920NX PC Desktop
Problems booting up--no access to toolbars, etc. on XP
To resolve this issue, simple trick is, when it stands at the wallpaper without Start menu and Task bar, Press Alt + Ctrl + Del keys
Then select TaskManager.
In the Task manager, select Process Tab.
Under that select Windows Explorer process and select End
Again click on File menu in the same Window and select New Task.
Type Explorer.exe in the blank and click okay--OK
That should bring the complete screen.
Aug 04, 2008 | HP Compaq Presario V2000 Notebook
Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
May 19, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq dc5100 Small Form Factor PC Desktop Logo
183 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
