Question about HP PSC 1510 All-In-One InkJet Printer
Making a network setup disc
I am trying to set up a network with a computer using vista (i have xp) and need to make a network setup disc but am having problems with it. The first problem is that my disc drive is labelled 'e' and there is no e drive listed. the second problem is that when I try to make a disc another way, it says that one is already made and i can't make another. I don't have a disc for this and never did. What do I do? The other computer is set up to mine for the internet, we just want to enable them to use my printer from their computer.
  • Barbara Balvanz Jan 22, 2009
    Yes, I have the exact same problem. Trying to network XP to Vista.....Set up Wizard says to make a network setup disk and insert it in J,H,I.K. but no E drive, which is what I have.
    Can You please help me.....
  • 849 Answers
I guess it has only option to make a floppy disk, you may try to make a floppy disk.
Posted on Nov 19, 2008
So I am having a problem where I can't see any of my homes XP Computers in the My Network Places Folder on my new Vista Laptop and I can't see the Laptop on any of the XP Computers. However if I use Run...
you need to make the sure that your router is a private one password protected and they all have to be connected to the router at the time and set it to home when you connect to the network or in the network and sharing area
Aug 23, 2009 | Computers & Internet
VISTA Business cannot 'see' XP machine in same workgroup
Check that the two machines are in the same workgroup on network settings.
Oct 14, 2008 | Microsoft Windows Vista Business DVD...
Tip
How To Repair Your Operating System
A Repair Install will replace the system files with the files on the XP CD used for the Repair Install. It will leave your applications and settings intact, but Windows updates will need to be reapplied. Here is how to run an OS Repair using the Operating System CD in XP, Vista, or 7:
Windows XP
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below:
3. Press ENTER to start the Windows Setup.
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Windows Vista
If you have a Windows Vista installation disc, you need to restart (boot) your computer using the installation disc. If you do not restart your computer from the disc, the option to repair your computer will not appear.
Here is a step by step picture guide.
If you have a Windows Vista installation disc:
1. Insert the installation disc.
2. Restart your computer.
3. Click the Start button, click the arrow next to the Lock button, and then click Restart.
4. If prompted, press any key to start Windows from the installation disc.
Windows 7
1. If a startup problem is detected, Startup Repair will start automatically and try to fix the problem.
2. If the problem is severe enough that Startup Repair doesn't start on its own and you can't access the System Recovery Options menu on your computer's hard disk, you can get to the menu and start Startup Repair by using the Windows installation disc or a system repair disc that you created earlier.
on Jul 13, 2010 | Computers & Internet
Tip
How to use a printer?
Install a New Printer DIY installation of your new printer in Windows. You may have a new printer with an installation disc, or maybe a second hand one with no disc. Either way you will find out how to install your printer onto your computer.
Add Network Printer If you have two or more computers in your house or office you will only need one printer installed on one computer for both to have printing privileges. This article shows you how to add a network printer to Windows Vista.
Add Network Printer Applies to Windows XP. Even though the instructions are similar to installing a network printer on Windows Vista, there are a few extra tips that might be interesting.
Enable Printer and File sharing How to enable in Windows XP And Vista. If you want to share a printer on your network you must enable printer sharing. It is not hard to do but it will not work if it is not enabled.
Path to your network printer How to find the path \\server\printer. If Windows does not find your network printer automatically then you will need to know the path to your network printer.
Set Network printer permissions Set who can change printer settings in Windows XP and Vista. I personally like to let everyone on the network just print and not be able to change too many settings to do with the printer.
Network printer has problems printing - You do not have permission to use selected printer.
Quick Printing Trick Cool printing trick for Windows Vista and XP.
on Jan 18, 2010 | Office Equipment & Supplies
No net connectivity
If you encounter difficulties accessing computers that are visible on the network map, make sure the computer being accessed has an account with the same name/password as the system connecting to it uses to login.
To set up Network Sharing between XP and Windows Vista, please note that File and Printer Sharing is different in Windows Vista than from the setup in Windows XP.
On a computer running Windows XP, click Start, click Control Panel, and then click Network Connections.
Click Local Area Network Connection, click Properties, and then view the list of items used by the network connection.
Ensure that the Link-Layer Topology Discovery Responder check box is selected.
Jul 02, 2009 | Microsoft Windows Vista Ultimate Edition
Printer sharing
Appreciate the direct "Ask Me".
Initially, pls try enabling the Share feature of the printer in XP. Pls go to Start, Printers & Faxes, right click on the printer you want to share, click on Sharing...follow on screen instructions. A few suggestions:
  • verify that the Vista and the XP uses the same Workgroup;
  • verify that other shared folders and files could be viewed from each other;
  • verify that each could access the internet from a single connection.
A few questions:
  • do you have a router or a hub;
  • how are the XP and Vista connected to the network, LAN cables or wireless.
  • confirm that it is a HP > PSC 1510 All-In-One InkJet Printer that is connected to the XP machine.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 19, 2008 | HP PSC 1510 All-In-One InkJet Printer
I can't get my system recovery disk to work so i can restore my computer to the orginal format
If your recovery CDs have failed you have some options
1. you can call the company who made your computer about a new set of restore discs
2. you can buy an operating system disc such as XP or vista
XP or Vista , Operating System Installation CD will setup the computer nicely , you may need drivers for certan things but not likely.
Malfunctioning restore CDs really **** me off
I just chunk em and load my XP pro disc
( multi machine volume license required if you wanna put it on multible computers )
( same with vista )
but in some cases you may find that XP pro will install on many machines just fine.
Thank you for using FixYa!
Az.
Sep 18, 2008 | Computers & Internet
Transfering mail setup from Windows xp to a windos vista machine with EasySuite
I'm not 100% sure about vista because I hate it but I can help you copy all of your outlook express data to a CD\DVD disk & your address book. Your network settings for express account is a phone call to your ISP.
If vista's explorer is set up like XP you should be able to copy your data into outlook express.
Open all these folders on you XP system.
User name\Application Data\Identities\{xxxxxxx}\Microsoft\Outlook Express
Copy the Outlook Express folder to your CD.
User name\Application Data\Microsoft\Address Book. Copy Address Book folder.
Making sure you have everything.
Open, User name\Local Settings\Application Data\Identities\{xxxxxxx}\Microsoft\Outlook Express
Compair the two Outlook Express folder files. CD will not allow copy of same named folder.
If Vista's lay out is the same as XP than copy Outlook Express folder to Vista.
Suggest you have your current ISP setting /account setup before copying to Vista
Let me know if this works for you!
Good Luck & Kind Regards.
Mar 21, 2008 | Computers & Internet
Remove Vista OS and Replace With XP Pro
1. make sure your laptop is set to startup from a cd
2. after laptop finds the bootinfo from the cd and asks you to press any key to start from cd, press any key and xp setup will start.
3. in xp setup your going to need to delete your vista partitions, preferably all partitions and then proseed to install xp into a new partition.
4. proseed with the windows setup follow the instructions and configure your settings as you wish.
Mar 17, 2008 | Acer Aspire 5100 Notebook
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
HP PSC 1510 All-In-One InkJet Printer Logo
53 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
