Cannon ir 6000 ver 8
My copier show error for E601.Than i am change hard disk.now display only download mode. please help me....
My copier show error for E601.Than i am change hard disk.now display only download mode.i want ir 6000 version 8 flash software. please help me....
Posted on Nov 21, 2008
  • 1,326 Answers
Did you get a brand new hard drive from Canon? If so, the hard drive needs to be "Flashed" with the software for the copier. Did you try to put the old HD back in, to clear the download mode? I don't believe it will work with out the software installed. Did you try one from another copier?
Posted on Nov 20, 2008
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
I have a cannon ir 3300 machiene and occured a problem with a error code e000000-0000 please help me out to remove this problem my technician has asked me to change the filament which is worth 12000.w
First clear that error from service mode. Press additional function
press 2 and 8 together
press additional function agian
service mode should appear in screen
select copier
select function
select "clear"
select "err"
select ok.
unplug power cord for a few seconds and restart the machine
try to make some copies if problem persist replace the fixing heater assembly
Feb 17, 2014 | Cannon Office Equipment & Supplies
My canon ir 6000 is showing an error codes E000001-0000 How it will solve?
Your error code is for the fixing unit solve by checking the follwoing:-
1. Fixing lamp.
2. thermistor
3. Fixing assembly if receiving PD
5. if no Potential difference received they the power supply is not okey.
Jul 13, 2011 | Canon imageRUNNER 6000 Copier
Getting a problem with a canon ir 6000 error code E 350-001
ji guys I need ur help, I've error code on cannon ir6000 "000732-0001", please help me send to my mail ahlalrasyid@yahoo.com. ty
Feb 16, 2010 | Canon Office Equipment & Supplies
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
Error E601-0003 on cano ir 3320 plz help
Image transfer error in your machine.
check your ip board.
Oct 21, 2009 | Office Equipment & Supplies
Canon IR6000 please wait message after switching on
When the display panel goes blank do you see at the bottom of the display show a E601-001 or numbers like that? If so you will most likely need a new hard drive for the copier. The only tricky part of that is that the hard drive needs to be Flashed for your model and if you have the copier networked, you need that software loaded as well. If you have another working IR-5000 or 6000 model, you can switch out the hard drives... Good Luck
Jul 01, 2009 | Canon Office Equipment & Supplies
Code error of Cannon IR3300 E000006-0000
getfile.asp?rid=1258 November 7, 2002 getfile.asp?rid=3215 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution :
In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS
Apr 29, 2009 | Office Equipment & Supplies
Cannon ir 6000 download mode problem
my copier not working only display the download mode.
Nov 18, 2008 | Canon imageRUNNER 8500 Copier
372 people viewed this question
jasbo
jasbo
