Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
HI amji Hey i have a quick quetion for you, i opened my set to clean the pisture tubes and i saw this things underneath them, they look like rings that you can move around... What are they and what do they do? thanx!!! evildude
  • George Juarez
    George Juarez Nov 20, 2008
    Thank you amji,
    You know i also notice my screen if a liltle off centre. can those thigs fix that?
    i will look for you next time im online that way we can talk....
    thank you :P
  • Sony Master
  • 586 Answers
    Please don't try to touch them.These are for the adjustment of picture position.If once you disturb them it will not adjust to.So, my again friendly advise is to u that contact any expert.And if u want to do by urself then try when find me online.
Posted on Nov 20, 2008
  • AMJAD HUSSAIN Nov 20, 2008
    Yes, i would be a nice session when we talk.
    Untill next tc bye
    Yes, it would be a nice session when v talk.
    yntill next tc bye 4 now.
Chain saw won't keep running. runs and stalls
Hi there, Sounds like you need to change the fuel filter.Use a piece of tie wire with hook on one end and fish out the plastic tube with the fuel filter on the end. Hemostats can be used also.Use a turkey baster to **** the gas and trash out of the tank.then pour in a pack of BB'S cover hole and shake the saw.This will loosen any stuck trash and when you put some gas back in it will come out with the turkey baster.The next step is buy a spray can Berrymans carburetor cleaner (any carb cleaner will do.) I recommend saftey glass's for next step.Stick the carburetor cleaner nozzle straw in the tank tube and press the saw trigger like you were going to cut wood,spray cleaner and open and close saw trigger 4 or5 times.If you do this with the carburetor filter off, place a clean rag over the carburetor.When you think it's clean hold the trigger open until the cleaner dries and then install gas tank filter.Now spray carburetor and linkage on the outside.Install clean filter and cover.With new gas&oil mix in tank You should be set to go.If this is not the right solution please post again.Thank You for choosing FixYa.
Sep 07, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Hey guys , after a little bit of tweaking a managed to open the monocular , cleaned the lenses, tightened the bolts , but i don't really remember the order of the lenses & their orientation. I have...
Hello, did you remove the lens from its tubes? Also did you remove the lens set rings? If you did, O boy. These lens are set to give a center line focal point in the NV tube. The adjustment on the eye piece is for the focal point on you eye. While adjustment on the large 50mm lens is to adjust the center line focal point. If you removed and of lens rings and took them out. Then the lens need to send a lens Opitic company for reclibration to the correct focal point..
Now send me a diagram on what lens you have and I will see if I can reassembly in the correct manner. stewbison
Aug 14, 2011 | Night Owl Optics Explorer NOCX3 Monocular
I am looking for a workshop manual for an 029I am want to fit new rings to it and check out the oil pump. It seems to be not pumping enough oil.
The adjusting screw is underneath the saw. You shouldn't monkey with the rings unless you know what you're doing and if you know enough to change rings, then why would you need the manual? Are you looking for part numbers for the rings? The upper ring is 1118 034 3001 and the lower one is 1113 034 3006. DO NOT GET THEM MIXED UP! You will destroy the engine REAL quick.
Jul 24, 2011 | Stihl Chainsaw Piston Assembly (44mm)
What are the carburetorr pin settings for a 334t tree saw
hi there
the base settings for hi and lo are 1 & 1/4 turn out from lightly seated
but make the hi setting just a fracrtion richer at top speed no load it should putter or 4 stroke slightly and the lo one should be about right buyt should pick off nicly when you stab the throttle quickly with no hesitation
note do not sett hi mixture setting to lean 2 top nol load or when you place it under lood it will lean out further and destroy the piston and rings
cheers pauly46
May 29, 2011 | Husqvarna Forest & Garden No.967012396 345...
What causes water to leak from underneath the unit?
Most often the problem is that the rubber rings are too old. The best is to open the machine, put the lid back on top, add the water container, add water. Push the espresso button, and afterwards (when the espresso is finished) open quickly the lid and check the origin of the water. I have a magic de luxe and it turned out that when i replaced the boiler, one of the high pressure tubes were damaged. Other frequently occuring problems are related to old rubber rings. the cost virtually nothing, and are easy to replace!
Apr 01, 2011 | Saeco Magic De Luxe Espresso Machine
Hey, my drop saw wont lock off the sliding arm when i pack it up an put it in the ute. i turn the handle full tighten an still slides freely?
there is a tube underneath and a lock mechanism. what might have happened is the lock has spread open and not putting enough pressure on the slide. Unplug the tool and turn it over and you will see the tube and lock. The lock is held in place by a phillips head screw and if the end is spread you can "GENTLY" squeeze it shut, reassemble and I think this will take care of your problem, also look for excessive wear on the lock and if so turn it 180degrees and try it that way. Let me know if you need more help.
Feb 27, 2011 | Makita 10" Dual Bevel Sliding Compound...
Color is bad especially colors like orange and the white on peoples teeth is black most of the time andthe picture is not clear
HI, thank you for visit fixya.
Common problem on this set .
Picture tube liquid is dirty.
Mostly in crt green and crt blue.
Do you have electronics skills?. If so, open the TV ( back cover), you will see green,blue and red gun. After turn on your tv, select any channel or video signal, cover with piece a paper two guns at the top ( any), and see how look the picture in the front, try one at time, ( press menu on remote control and see leters-clear). I am sure the green and blue will be no clear. all the time red tube is fine.
I will be here for any quetions.
Thank you
Dec 01, 2009 | Philips 60PP9352 60" Rear Projection...
Video goes black on startup
sems like your pisture tube for the tv is going slowly out. replace the tube or replace the tv, its cheaper to replace the tv then a new tv screen colour tube.
Aug 23, 2008 | Sharp Aquos LC-32D40U Television
Whirpool refrigerator ,water dips into the fridge compartment from the freezer
It is not supposed to be removed. try flushing some warm water through it.
Aug 01, 2008 | Whirlpool ET1FHTXM Top Freezer...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
