Question about Audiovox SMT5600 Smartphone
Phone does not start with sim card on it
I have the unlocked audiovox smt 5600 phone and it does not start with the sim card on it. when i take out the sim card and turn it on then it starts up but if i try it with sim card on it, it does not start. plese let me know if u have solution to this
    Novelist:
  • 172 Answers
Be sure you have SIM card in right. Look at contacts on SIM then allign them with SIM Contacts on the phone.
If this doesn't work, then SIM card itself is highly suspicious. Try it in another phone.
Posted on Feb 27, 2009
SOURCE:
CAN I USE MY AT&T SIMS CARD IN A VERIZON AUDIOVOX CDM8945VW PH?
if there is a sim card slot on any cell you can use the phone...just one thing might stand in your way (do the starcom say verizon on it...you may need to have this cell unlocked) most carrier do that...but put the sim in now and call your house phone to see if it works or not...
May 18, 2010 | Audiovox CDM8940VW
How 2 unlock audiovox 8910 phone?
See this post:
http://mobilenetconnect.com/unlocking-an-audiovox-cdm-8910-cell-phone/
Jan 25, 2010 | Audiovox 8910 Cellular Phone
Unlocked
what phone company was the phone using before you unlocked it (sprint) ?? that slot you are looking at is probably a memory card slot not a SIM slot. everything im reading says that phone is not a GSM phone aka it doesnt take SIM cards
Feb 05, 2009 | Audiovox PPC 6700
My audiovox smt 5600 can't show start any more if any one can help me restart it with a code pls mail me at temitope.4all@yahoo.com
I assume you mean the phone is asking for a network code or password before the Start Menu is available, ie, phone can be used.
If this is so and it is asking for a network code, then you need a SIM card that matches the carrier the phone was designed for. If it is ATT/Cingular, you can buy a SIM card from the new ATT/Cingular network for $6. It is a pay-as-you-GO phone SIM, but once you have it, you can call ATT to as for a number xfer as well as a standard monthly contract using this SIM.
If it is from the old Blue ATT network, then it cannot be used on ANY carrier unless it is unlocked for use on ALL carriers. This would be noted witht the docs that came with the camera. If nothing says ATT/Cingular, and especially if someithing says ATT without Cingular, then it is probably an old Blue ATT phone. You can buy a BLUE SIM off ebay which will get you to the point of being able to use the phones functions, but it will not work to make calls until you unlock it and replace the BLUE SIM with another current carriers SIM. Sprint will not work either because it is not a GSM ATT type network. Cingular and T-Mobile yes.
Google phones model number and UNLOCK and you will find a way to do it yourself at no charge if you have an XP or earlier PC with a USB port. Vista OS cannot be used to do it with the downloaded unlock software. It is also very hard to find anyone that can do it selling Unlock Codes based on phones IEMI code.
If it is not a network lock message, then it may be the last users personal lock password. In this case, you can hard reset the phone by holding down both right and left softkeys while powering on the phone.
Oct 30, 2008 | Audiovox SMT5600 Smartphone
Unlock
check out this link
http://www.gsmliberty.net/shop/nokia_unlock.php
i dont assure you but i think it will help you.
thanks.
Oct 23, 2008 | Cell Phones
Unlocked audiovox smt5600 will work in india?
yeah go to a cellphone repair shop and ask for an open line.
Aug 12, 2008 | Audiovox SMT5600
Computer won't sync with audiovox smt 5600
You must install ActiveSync software on an Win XP OS available with disk supplied with phone or on MicroSoft support page.
If you are using Win Vista OS, then download latest Mobile Center software while you phone is plugged into USB port.
Phone must be recognized by OS for phone to charge. Nice Audiovox/Microsoft desigh heh? Some times you just want to get designs by the throat and squeeze them.
Mar 25, 2008 | Audiovox SMT5600
SMT 5600 does not load OS, screen goes white and then blank.
Screen sound bad, or intermittent connection inside. You can find disassembly instructions on the net. Search with phone model and disassemble. Remove and reattach all cables in case one is lose or contact dirty.
Dec 17, 2007 | Audiovox SMT5600 Smartphone
Auidovox smt 5600 buzzing noise.
SOUND S LIKE THE SPEACKER IS GOING TIME FOR A NEW ONE MY FRIEND
Apr 11, 2007 | Audiovox SMT5600 Smartphone
Audiovox SMT 5600 will not charge
If your battery goes COMPLETELY dead, which it will do if phone is not turned OFF and not used for a long period of time, you will need to JUMP START it using you OEM SMT-5600 AC charger. Other AC chargers will not work for this purpose and neither will a USB port.
You can JUMP START the battery using a USB port by cutting off a USB cable to expost the red and black power USB PORT power pins 1 and 4. Remove your SMT-5600 battery and while the modified USB cable is plugged into your USB PORT, hold the BLACK wire to the negative (-) terminal and the RED wire to the positive (+) terminal for about a minute. Replace the battery in the phone and connect the phone to a USB PORT using a standard USB cable. The SMT-5600 charging light may not register for a while, but will eventually light amber to show it is charging, assuming your phone is recoginzed by your computer.
Note some mini USB cables DONOT carry the USB power leads through to the phone, only data. If you have a very thin USB cable, be suspicious the power leads are not being carried in the cable.
Since the USB PORT power is limited to 100ma it cannot hurt the battery, but will insert enough current into a totally flat batter to cause the battery to register a voltage large enough to alllow USB PORT charging, typically 3.7VDC.
Nov 18, 2006 | Audiovox SMT5600
Audiovox SMT5600 Smartphone Logo
165 people viewed this question
Top Audiovox Computers & Internet Experts
Rick
Level 1 Expert
Jaagoo
Level 1 Expert
Argospete
Argospete
Are you an Audiovox Computer and Internet Expert? Answer questions, earn points and help others
