Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Fl231 fuse quest
I'm wondering is there a replacement fuse that can handle the voltage instead of inserting the same OE (original equipment)? I've replaced my fuse today and within a couple hours it blew again. i'm taking the blame and assuming my soldering skills are not up to par and the reason for it blowing a second time, but a higher rated improved fuse would be reassuring as well. i'm well aware a bad soldering job will not do justice to an improved fuse either, but again if i can eliminate a troubled fuse, troubleshooting a common problem becomes easier.is there a better improved replacement fuse out there?? if so can someone tell me where i can get that?
i also want to thank you for this site. i've saved alot of money, this fuse can blow 10 times and i'd still save money replacing it myself than having a tech make a house call. not that i want to nor hope to, but such a common problem should probably have more attention paid to it by the manufacturer. as much as i love this tv i will not but another rca tv product and thats unfortunate. thanks in advance for all your replys
Hi willtab,
no i didn't resolder the flyback. apparently i missed step #7 in bold caps of your instructions to resolder the flyback. i just ordered another fuse so when it comes in i will def do that. tahnks for the help and advice. i'll repost and let you know how i made out.
Posted on Nov 19, 2008
  • cbqb53185 Aug 07, 2009
    UPDATE its been several months now since i've replaced the fuse and i've not had ONE PROBLEM with it. thanks for the advice I LOVE THIS SITE!!!
What is the flyback??
  • Christie Houston Nov 22, 2008
    i fixed my problem with the wire from a bread tie. Works for now. Either something will start on fire, or hurt something else. But it won't blow, and will buy me a while before I get another TV!!
    Oh, yeah, it was cheap too..... : )
    Genius:
  • 1,030 Answers
Did you resolder the flyback? this is the main reason this fuse blows this is a .400ma fuse.
  • Willie Howell Nov 20, 2008
    The flyback kaliki73 is the large black component with the big red wire coming from the top (kinda looks like a car distribitor)
What does OE mean.
OE original equipment
OEM is original equipment manufacturer
Apr 18, 2017 | Washing Machines
Cant find convergence in setup
There are three small rectangles sqaure boxes cap fuses parts(FL231) the one in the middle is dead.Replaced the one in the middle located right side near of the big black block of plastic call FBT.U know how to do soldering and have the equipments?Try website like Ebay.com to the cap fuse part(FL231) fuse.After the cap fuse(FL231) is replaced the Convergence well return,ur tv back to normal.
May 28, 2010 | RCA D52W136D 52 in. TV/DVD Combo
Wont turn on after replacing FL231 fuse on a RCA HD52W59
If you replaced the fuse alone without installing the other components that are rquired to repair that issue the new fuse can allow voltages to flow trough the diode in both directions which can prevent the set from firing up. You need to replace the FL231, DL231 and CL230 as a set then reflow the solder on the flyback and vertical IC.
Dec 04, 2009 | RCA HD52W59 HDTV Projection Television
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
Fl231
Its just a regular fuse some models have F231 instead of FL231 it should be just to the upper right side of the flyback.
May 21, 2008 | RCA P52926 52" Rear Projection Television
RCA 52w59 projection fuse fl231
Instead of taking the board out, I just soldered two wires to the old fl231 fuse on the underside. Installed a fuse holder with a half amp fuse. And I re-soldered all of the flyback points. My tv is working like new. thanks for everyone's help.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
193 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
