Question about Zenith IQB50M90W 50" Rear Projection Television
Zenith IQC50H95W displays in monochrome
Hi
Just noticed a new problem with this set - when connecting any non-component-video source to any input, it displays in black and white. I hadn't noticed because normally the only devices connected are the HD cable box and progressive scan DVD player and those both display nice color via YPbPr, but now I've found that when connecting anything to the two antenna-in jacks, the rear video inputs via composite or S-Video, or to the front video input, it all displays in black and white. Any thoughts? Thanks! -paul
  • 3 more comments
  • pdieten Nov 19, 2008
    Tried that. It didn't work.
    Tried leaving it unplugged for 30 minutes then plugged it back in. Everything is still black and white except component video.
    Okay, I see the new offered solution. What does that mean and will it be expensive to fix?
  • pdieten Nov 20, 2008
    Not a PAL problem, this happens with everything I plug in via RF or composite. I tried a Zenith DTT900 converter box. It displays black and white. So does my basic cable connection. Everything is B&W except video input via component. I don't see anyplace to set PAL on the TV anyway.
    OK. I don't work on electronics made after the tube era, so I'll have to call the shop. I just don't know what such a repair might cost. Thanks much
    Brigadier General:
  • 6,966 Answers
Since your general location is in the United States and Zenith being predominantly designed/marketed in the US makes this unit purely an NTSC color system. Having said this, then color system selection (choices of PAL, SECAM and others) need not be considered.
That would leave us with the one of the boards which is responsible for deciphering and embedding the necessary color to any video signal that passes through RF, composite Video and/or S-video. Component level wise repair would involve check of the ICs, the 3.58MHz crystal and other components. To verify, voltage checks should be performed on a live set with the back open. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 20, 2008
    Genius:
  • 1,011 Answers
Sir,
It's possible that there is difference between the NTSC and PAL encoding on the DVD and your TV playback. If your TV/DVD is set to PAL, NTSC DVDs will be played black and white.
thanks
goodluck
  • 685 Answers
It suffers from the same progressive video bug as the Hitachi where the RPTV video shuts down during sudden screen intensity transitions like the inputs were being overloaded. The Pitch Black trailer on the U-571 DVD is a prime example of this bug. No VGA connector for use with the RCA DTC-100.
Posted on Nov 19, 2008
  • 849 Answers
Either the 2nd input color system is not properly selected or a fault arose in the chroma section of 2nd input.
    Master:
    Sergeant:
  • 461 Answers
Have you try to hard reset the system?
1. turn off
2. remove/unplug the power cable including from the main switch
3. leave it for 30 minutes
4. plug in the power cable
5. turn it back on
Video Does not work on New Magnavox TV
Hi, it sounds like your problem is that you've selected the wrong "video input" for your DVD player. Your new television most likely has at least 3-4 (sometimes 6-7) different inputs for video. With your DVD player connected and turned on, press the "Source" button on your TV to cycle through the different inputs. Be sure to wait 2-4 seconds between selections to give your TV enough time to switch inputs. If your DVD player has "color coded" output cables, it's most likely a "component" video connection. See if one of your video inputs on the TV is called "Component". Some other video types are Video, DTV, HDMI, SVideo, Component, Composite, RGB, PC Input, etc...
Jul 24, 2013 | Sylvania SDVD7014BJ 7 in. Portable DVD...
How do I change my resolution on my 32 inch flat screen from 480 to 720
Assuming your TV will support 720p signals, check how you have the TV connected to the Playstation 3. Change your video cable to component video or HDMI, depending on the TV. (The Composite input is limited to 480i (SD) pictures. The same is true for a SCART connection.) Put the TV to the new input by pressing the Input Source button on the TV Remote or through the menu depending on your TV.
You may have to do the first of these steps before changing your cables and the TV input source (I'm not sure). On the Playstation, select Settings and then Display Settings.Choose your video output (component or HDMI). Next select all resolution that the TV can use. (Most 32" TVs only do 720p. There are some that can do 1080i or 1080p.) Confirm the video connection works. Then Save your settings.
For screen captures of the steps, see: http://manuals.playstation.net/document/en/ps3/3_15/settings/videooutput.html . You should always turn off the TV and the Playstation before swapping the cables. (So you may need to stop and save after setting the output to component video. Then return to the Display Settings menu.)
I hope this helps.
Mar 14, 2013 | Televison & Video
After warm-up screen flashes and loses color but comes back on and off intermittidly. This is a 50" Zenith Plasma tv. thanks.
Sounds as if a cable connection is bad. Check the cables first. If cable are good, change inputs, if cables are bad replace cables. If it's component, make sure that red, blue or green didn't come loose on both sides...the tv and the source. If you still have problems, check for red video noise on the screen itself, preferably when it's on but with on input (black) If you notice this, your plasma is failing.
Mar 23, 2011 | Zenith Z50P3 50 in. Plasma TV
I have a zenith tv older model, and have dish network, i need to know how to hook it up and switch it over so i can play it
If you have an HD receiver you will want to use one of two types of cables; you can use component cables which have five ends red, blue, green, red and white, or you can use an HDMI cable which will have one flat connection. If you have a standard definition receiver you will want to use RCA cables these have three ends red yellow white. The connections will be labeled on the television as well as the receiver. Once you get this connected hit the input/source button on your TV set if you're using RCA cables you want the TV set to video 1 or video 2. If you're using an HDMI cable then set the TV to HDMI 1or 2 using the input /source button. If you use Component cables set the TV to Y/PB/PR or component 1/2.
Daniel Busa
DISH Network Customer Service
Mar 09, 2011 | Zenith Z50P3 50 in. Plasma TV
PIP function does not work, the settings is greyed out also! I have a wii, PS3 and freesat :)
Hi nikkicollier,
PiP for your TV works between two different sources. This means between a component source and an HDMI source or between an HDMI source and another HDMI source. PiP also works with a PC connection, e.g. when using the TV as a computer display. PiP does not work between two component sources. The setting will be grayed out when you don't have a configuration that is supported, as the Samsung TV's are usually able to automatically detect which sources are plugged in and available.
I'm not exactly sure what sort of configuration you want your PiP to work in, but try one of the following configurations.
  • TV Cable (through VCR or other via Component input) with Satellite in PiP (via HDMI input)
  • PS3 (via HDMI Input) with Satellite in PiP (via Component Input)
  • Wii via HDMI Input) with PS3 in PiP (via HDMI Input)
You can usually find an HDMI cable for much cheaper at an electronics supplies shop, Radio Shack, or on eBay or Gumtree.
To change your PiP settings:
  1. Press the MENU button on the remote control. Select Picture and press Enter.
  2. Select PIP and press Enter.
  3. Press the enter button again, and press up or down to change the setting to On and press enter again.
    Note:
    If PIP is activated the screen will display in widescreen (16:9 aspect ratio.)
  4. Press the up or down buttons to select the Source then press the Enter button.
    Select the source of the sub-picture by pressing the up and down arrows and then pressing the Enter button.
    Note: The sub-picture can serve different source selections based on the what the main source is set to.
    Note:
    You may notice that the picture in the PIP window becomes slightly unnatural when you use the main screen to view a game or karaoke.
You can download the full PDF manual for your TV here (large download at 26MB.) Much of the PIP information can be found on pages 13 and 14.
Good luck, I hope that helps.
Mar 01, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Component video problem. Hi I got the Denon AVR-3806 receiver and has it hooked up with a component cable to my background projection TV. To the reciever I have a satellite box connected also with a...
Just fixed this myself - made my head hurt to figure out. 1. Switch to a setting (say DVD). 2. Watch the AVR screen as it switches. You'll see the audio and video settings. For example, Audio = DVD, Video = DVD (Mine showed Audio = DVD, Video = DBS even though is was set correctly using the SETUP for audio and video)3. Under the round control knob on the left, push the (tiny) Video Select button. 4. Turn control know to choose the correct video source
Your system should work right. Mine did.
Jan 03, 2011 | Denon AVR-3806 Receiver
Get ''not supported ''message on vx-1018-ah
Verify this is a Pioneer VSX-1018AH.
The manual explains it all... The problem is probably an incompatible setting on your source.
Search for "not support" in the manual...
http://www.pioneerelectronics.com/PUSA/Unassigned+Content/VSX-1018AH-K+OPERATING+INSTRUCTIONS
I think this may do it... From Page 86...
No picture or sound. • This receiver is HDCP-compatible. Check that the components you are connecting are also HDCPcompatible.
If they are not, please connect them using the component or composite video jacks.
• Depending on the connected source component, it’s possible that it will not work with this receiver
(even if it is HDCP-compatible). In this case, connect using the component or composite video jacks
between source and receiver.
• If the problem still persists when connecting your HDMI component directly to your monitor,
please consult the component or monitor manual or contact the manufacturer for support.
• If video images do not appear on your TV or flat panel TV, try adjusting the resolution, DeepColor
or other setting for your component.
If ‘NOT SUPPORT’ appears in the receiver’s display, try adjusting the resolution, DeepColor or
• While analog video signals are being output over HDMI, use a separate connection for audio
output.
• When this receiver reproduces MULTI CH IN audio sources with the HDMI setting set to
THROUGH, you cannot hear audio output from all channels. In this case, make a digital or analog
audio connection.
• To output signals in DeepColor, use an HDMI cable (high speed HDMI cable) to connect this
receiver to a component or TV with the DeepColor feature.
Check the HDMI Control (Page 65-66 of the manual). It only works with Pioneer Flat Panel TV's. Also check Page 83 for "No image is output..."
No image is output when an
input is selected.
• Check the video connections of the source component (see page 18).
For high-definition video (using component video connections), or when digital video conversion
is switched off (in Setting the Video options on page 72), you must connect your TV to this receiver
using the same type of video cable as you used to connect your video component.
• Make sure the input assignment is correct for components connected using component or HDMI
cables (see The Input Setup menu on page 67).
• Check the video output settings of the source component.
• Check that the video input you selected on your TV is correct.
Some components (such as video game units) have resolutions that may not be converted. If
adjusting this receiver’s Resolution setting (in Setting the Video options on page 72) and/or the
resolution settings on your component or display doesn’t work, try switching Digital Video
Conversion (in Setting the Video options on page 72) OFF
Apr 05, 2009 | Pioneer Audio Players & Recorders
No auto setup display on TV
For the setup functions you have to use either the monitor out (a yellow jack on the top-right corner of the back) or you have to use component video out. HDMI will NOT work for setting up the system. This is one complaint to Yamaha from all of us.
Feb 14, 2009 | Yamaha RX-V661 Receiver
HDMI input not working
I had the same problem with my 50 zenith when it was new. It needs a HDMI board replaced.
Dec 04, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Monochrome s video
as a follow up on our online session....
It may not be an s video connection problem. it may be that your DVD (or video source) is set to a different color system other than what your projector is set to.
In your DVD, try pressing the NTSC/PAL button.
Good luck and kind regards.
Oct 21, 2007 | BenQ PB8240 Multimedia Projector
Zenith IQB50M90W 50" Rear Projection Television Logo
46 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
