Question about Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C does not reset after ink is replaced
On the screen "Ink Empty Black" "Open Cover". I am on my 3rd new cartridge right out of the box and the message does not change, will not print and does not respond.Thanks,Lou
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
Please clean ink tank level sensor.
Posted on Nov 19, 2008
No Cartridges. Open Scanner cover, then reinstall ink cartridge. All Cartridges are full
No Cartridge will show on the display if the machine cannot recognize one of the cartridge or one of the ink is empty.
To make sure about the real issue unplug the mach from the power outlet then plug it back in after 10 seconds.
If the display show: "ink empty C" it means the cyan/blue needs to be replace. "ink empty M" it means the magenta/pink needs to be replace. "ink empty BK" it means that the black needs to replace. If the display shows "ink empty Y" it means that yellow needs to be replace.
Even if it looks like the cartridge is full, it really needs to be replace so that the machine will work again.
Hope this helps. Rate if it works. Thanks
May 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
I replaced the inkjet cartridges in a Brother 210c All in One and it still shows low ink levels in the color cartridges (Black is fine). Where do I need to troubleshoot?
Just unplug the machine and plug it back in while you hold the stop key for about 10 seconds. Usually clears up and resets ink levels.
Nov 25, 2009 | Brother MFC 210C All-In-One InkJet Printer
Problem with my Brother MFC 210C Printer won't print the colors.
Check your ink cartridge if they are properly installed.
Check your print settings.
Make sure your ink cartridge are not empty.
Replace your ink with the original Brother ink cartridge.
Sep 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
I don't know how to change the ink bought this printer from a guy at work no manual
Lift the scanner cover from the right-hand side of the MFC until
it locks securely into the open position.
If one or more ink cartridges are empty, for example Black, the
LCD shows Ink Empty Black and Cover is Open.
Pull the ink cartridge hook toward you and remove the ink
cartridge for the color shown on the LCD.
Open the new ink cartridge bag for the color shown on the LCD,
and then take out the ink cartridge.
Remove the cartridge covers.
Each color has its own correct position. Keep the ink cartridge
in an upright position when you insert it into slot. Press down on
the ink cartridge until the hook snaps over it.
Lift the scanner cover to release the lock. Gently push the
scanner cover support down and close the scanner cover.
If you replaced an ink cartridge while Near Empty was
displayed on the LCD, the LCD may ask you to verify that it was
a brand new one. Example: Did You Change Blck? 1.Yes
2.No. For each new cartridge you installed, press 1 on the dial
pad to automatically reset the ink dot counter for that color. If the
ink cartridge you installed is not a brand new one, please be
sure to select 2.
If you wait until Ink Empty message is displayed on the LCD,
the MFC will automatically reset the ink dot counter.
If the Install message is on the display after you have
installed ink cartridges, check that the ink cartridges are
installed properly.
Hope that helps you!
Aug 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Says the yellow ink needs replacing,have a new ink cartridge in
pulled plug, removed yellow cartridge, cleaned point where yellow ink goes in, put plug back in and it worked.........Thanks
Jan 27, 2009 | Brother MFC 210C All-In-One InkJet Printer
MFC does not recognise the new black ink cartridge.
Disconnect power supply and USB lead (leave disconnected for 10 min). Repeat this for each colour that is not working and hey presto the LCD readout will revert to normal and you will be able to print again. Happy Christmas! Hope this works for you (worked for me)
Dec 18, 2008 | Brother MFC 210C All-In-One InkJet Printer
The usual obvious fix is to buy a new catridge, insert, power off machine, then switch back on to reset any sensors. But if the circuitry on the machine itself is faulty it wont fix it.
I used to own an MFC 260C. It had a perfectly good full ink catridge in it, that was working fine, until...it suddenly did not recognise the cartridge anymore.
I pulled the machine apart and found that 2 of the 4 sensors on the cct board at the back of the cartridge housing were loose. These sensors pass light through the exposed part of the cartridge to see if ink is there. So if these are faulty, you will never clear the "No Cartridge" or "Ink Empty..." or "Near Empty Ink ..." messages on the MFC260C and probably other similar printers in the MFC range.
Why did they fail? Because the soldering on these sensors was poor quality.
I would never buy another Brother machine because of this, also because they design the machine to be totally useless unless all the ink ccartridges are full. Shame on you Brother, and kiss my *** for the $160 pile of junk I bought off you that was only on its second batch of cartridges (ie very little use)
Nov 21, 2008 | Office Equipment & Supplies
Have a mfc-210c brother ink empty cyan replace ink. have put in a new lc41y ink cartridge . machine says open cover and reinstall ink cartridge. sortof done this 20 times!look forward to some advice...
I pulled the machine apart and found that 2 of the 4 sensors on the cct board at the back of the cartridge housing were loose. These sensors pass light through the exposed part of the cartridge to see if ink is there. So if these are faulty, you will never clear the "No Cartridge" or "Ink Empty..." or "Near Empty Ink ..." messages on the MFC260C and prbably other similar printers in the MFC range.
May 03, 2008 | Office Equipment & Supplies
Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Feb 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
800 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
