Question about Miele DG 4080 Stainless Steel Electric Single Oven
CHANGE THE LIGHT IN MIELE OVEN
UNABLE TO REMOVE THE GLASS COVER AND DON'T WANT TO FORCE IT, ANY SUGGESTIONS
Had the same problem. Ended up removing interior oven panels (sides first then top on model H310B). This is easier than you might think. Could then get a good grip on the light's glass cover and it unscrewed easily.
Posted on Sep 25, 2009
Unable to remove light cover inside oven
I'm not familiar with that oven model, but as I have had a similar issue with my Neff oven light, I thought I would give you the benefit of what I had discovered. The light cover in my oven is a round, thick glass cover. The hand book has a graphic showing that the cover is simply twisted with one hand in an anti-clockwise direction as viewed straight onto the cover. No way! The first issue is that the lamp housing is right in a tight corner and getting sufficient grip on the cover is tricky. I put rubber gloves on to increase the grip and resorted to using two hands to exert as much force as I could manage, but it only moved a small amount. I think the movement was only the entire lamp housing moving in the oven wall, rather than any movement of the cover. I tried warming up the oven (not too hot) in the hope that the cover might release due to expansion, but no go. I then wondered if cooking grease / deposits and bonded the cover to the holder; although it appeared reasonable clear. This appears to have been the issue as I applied WD40 to the seam where the glass meets with the lamp housing and left it for a few minutes. It needed a second application, but eventually came free. On inspection, there was only a minor 'varnish' on the glass that appeared to have prevented the two parts from moving. Using WD40 weakened the bond eventually, but it also made the glass incredibly slippery, so gripping the glass cover after application is difficult. I used the rubber gloves and wiped the glass well to remove any residual WD40 prior to attempting to twist the glass cover off.
Oct 06, 2014 | Neff Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
I am trying to replace the light bulb in a Miele H326 oven but I cannot remove the glass cover in order to get at the bulb. Can you suggest the best method?
Usually they just screw off, may need a good turn as they can be tight due to the heat. If not then you may need to remove the back panel, usually 4 screws. Otherwise a bit of elbow grease to turn it anti-clockwise.
Apr 06, 2011 | Miele Ovens
We have a multifunction freestyle over 698 and want to change the light inside the oven. how do we do this
The glass cover over the bulb should screw off, remove the bulb and replace it with a new one of the correct type. Clean and replace the glass cover. Be careful not to use force which could break the glass and cause an injury. Make sure that the stove main switch is off. (The lamp cover may have a screw type or have a bayonet fitting).
Jan 17, 2011 | Ovens
Can NOT remove glass cover to change light in oven Jenn Air W30400P
If it is the round glass cover it should unscrew. It is thick glass so you might need to try more force of tap it with a piece of wood.
Jan 02, 2011 | Ovens
How is the glass cover removed to change globe in a miele oven
unplug the oven, grab cover and turn anti clockwise, sometimes the glass welds itself to its holder and will break, may have to replace this aswell.
Apr 07, 2010 | Miele DG 4080 Stainless Steel Electric...
How to change the oven light bulb in a candy f245. Glass cover on inside doesn't seem to undo - moves a bit each way. No apparent access from outside.
The glass cover does come off. Use some latex gloves or non skid material and grasp the lens firmly and turn counter clockwise.
Jul 15, 2009 | KitchenAid KEHC309 Electric Double Oven
Unable to remove the glass cover to change the light bulb in oven
I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
Jan 12, 2009 | Ovens
Kenmore oven: glass dome for interior light removal
Hopefully someone answered your question by now. If not, the glass bulb cover sticks sometimes, but it does turn counterclockwise. Be firm with it, let it know who's boss. Once you've removed it, you can replace the 40 watt appliance bulb. (The manual suggests you unplug the range or disconnect power for your safety). Good luck.
Oct 23, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Miele DG 4080 Stainless Steel Electric Single Oven Logo
2,348 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
