Question about JVC Televison & Video
JVC TV model AV-31BP6 single horizontal line
Just like this post:
http://www.fixya.com/support/t255183-jvc_av_35750_single_horizontal_line
I have a single horizontal line for the picture. I opened the TV and have found the vertical deflection section of the IC but do not see IC421. I see other 400s but not 421. Looking over the solder points in the area, they all look good as well with no visible cracks.
Does this model have a different code for this solder point? Since all of the solder looks ok is this problem being caused by something else?
    Sergeant:
    Champion:
  • 346 Answers
1c4 21 is not an 1c. it is the location number under the green circuit board.
the name of the ic is written as la 7832 for example
Posted on Nov 19, 2008
JVC av-35750 digital or analog???
Unfortunately this TV does not have a digital tuner built in.
Is not digital ready.
Jun 28, 2009 | JVC AV-35750 35" TV
LOOKING FOR OPERATORS MANUAL FOR MODEL AV-32890
http://www.retrevo.com/s/JVC-AV-32D302-TVs-review-manual/id/279ag311/t/1-2/ - 65k -
Feb 13, 2009 | JVC AV-32D305 32" TV
JVC AV-36260 No Sound No Picture Red Light Blinks Copntinuously
Try this blog I found on this site. I have the same model and problem with my JVC TV set and I was able to fix it for 2 bucks at home by myself.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 07, 2009 | JVC AV-36950 TV
JVC AV 35750
its a boat anchor dont break jus hvy
Aug 06, 2008 | JVC AV-35750 35" TV
JVC AV-35750 TV
I changed capacitor C926 (1000Uf 16V) on main board. It solved the problem. I went with 1000uF 63V as it was readily available...it's okay to go with higher voltage. It was hard to fit it on because of the larger size but it worked.
Jul 28, 2008 | JVC AV-35750 35" TV
POWER WON'T TURN ON . YES, POWER SUPPLY OUTLET IS GOOD
Replace capacitor C926 near center of circuit board chassis (label is on the bottom) by a 1000uF 50V. Mind the polarity!
R,
A
Feb 05, 2008 | JVC AV-35750 35" TV
WON'T TURN ON. POWER SUPPLY GOOD
Replace capacitor C926 near center of circuit board chassis (label is on bottom) by a 1000uF 50V one. Mind the polarity!
R,
A
JVC Television Model AV 27820
One or more of the electrolytic condensers near the vertical ic are bad
Nov 20, 2007 | JVC AV-27820 27" TV
JVC AV 35750 single horizontal line
Jeremey,
It's ring cracks on the solder joints of the vertical IC... IC421 i mounted to a small heat sink on the board. With the unit off and unplugged remove the board and locate IC421 (LA7832) and closely examine the pins connecting this component to the foil side of the board. You'll notice small rings around the footings that are actually open cracks in the solder, caused by heating and cooling over a period of years. Simply and carefully reflow some solder over these cracked joints, careful not to get the ic too hot in the process, and put it back together.. That should sole the problem...
Another problem we encounter a lot in the vertical deflection circuit of this unit are the two feeder caps C424 (100UF/35V) and C425 (470uf/35v).. If you're already there you might want to go ahead and replace these as well - save taking the back off again if they go bad..
Bill
Nov 13, 2007 | JVC AV-35750 35" TV
Televison & Video Logo
129 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
