Question about RCA P52926 52" Rear Projection Television
RCA D52W26 Worked perfectly and was in perfect convergance before, now is out of convergance and auto convergance wont fix it" it's not even showing in set up menu"", picture kinof makes a downward arch in the middle, green and blue crt seem out of focus, is there a focus adj.?
  • dave000 Nov 21, 2008
    picture does not come in clear.
  • caribooshawn Feb 24, 2009
    I have exactly the same problem
Very simple fix there's three micro fuses beside the flyback transformer if the center fuse is open check with meter then theres bad solder connections on flyback simply resolder flyback in board &install new fuse. the 3 fuses are brown or tan about a 1/2" long
Posted on Sep 18, 2009
My RCA P52960 52in. rear projection tv has what looks like a slight Fisheye lense look to it,the center being perfectly fine but all around the edges is a slightly blurry and can see all three...
We calling convergence problem.
Re solder fly back terminal ( transformer)
Replace pico fuse 400mA(little red box fuse) beside fly back.
Go to set up, convergence, select auto convergence and your TV will work perfect.
I will be here for any future question.
Thank you for visit fix ya.
Aug 04, 2011 | RCA P52960 52" Rear Projection Television
HDTV monitor 52 in. Model #: D52W26 Serial #: G072CU07E colors are separated, warped screen and cannot find auto convergence
Very easy repair. The ITC222 and ITC222A convergence option missing repair kit available from will solve that issue. Its listed under the RCA repair kits and has the parts and the CD with repir instructions.
Mar 31, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA hd52w67 analog convergence problem.
with Tv off press and hold ch- and vol- at same time untill tv turns on then release and you should be in factory settings service mode.
May 26, 2010 | Televison & Video
RCA D52W26- 52 " rear projectio- 3d
try to inspect the convergerce power supply and the convergence output module for cold solder joints around the mos fets...i had seen many of them on the same condition.
Jan 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Fixing rca D52w26 convergence problem can you try fixing with remote
No,must replace parts,These websites,have convergence kits for many DLP TVS.Tv Repair,Tv Repair kits.U know how to solder right?
Oct 23, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W26 rear projection. 2 years old. 3 times and powers out.
Try replacing CP150, CP114 and CP120 first cost about 12.00 with free instructions available at the following link under the RCA parts category
Feb 10, 2009 | RCA P56923BL 56" Rear Projection...
Akai PT4298HD projection tv
convergence must be adj then saved then magic focus
if cannot be adj chips need to be replaced.
Sep 21, 2008 | Akai PT4298HD Rear Projection Television
D52W26 Convergence board
Yes the D52W20 and the D52w26 are both ITC222 chassis they are exactly the same
Jul 17, 2008 | RCA P52926 52" Rear Projection Television
Convergence prob for d52w26 rear projection tv 52"
If the auto-convergence is not working then the convergence amp ICs are starting to fail. If you can solder, try resoldering the pins on these ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted.
Jul 14, 2008 | RCA P52926 52" Rear Projection Television
convergence ic bad
Dec 03, 2007 | RCA P46812BL 46" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
120 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
