I cannot get my ac clutch to engage.i do not have power to my lowside pressure wsitch.i checked my fuses and relays and they are all good.if i run my conpressor direct the the battery it works fine
In a 1994 Chevy K1500, the compressor should receive power when the AC button is turned on, assuming that the system is adequately pressurized and there are no other issues preventing it from engaging. Here are some steps to diagnose the issue:
Check Refrigerant Levels: Low refrigerant levels can prevent the AC compressor from engaging. If your system is low on refrigerant, it may need to be recharged. This is typically a job for a qualified technician.
Check for Refrigerant Leaks: If your system is low on refrigerant, it's essential to check for leaks. A leak can cause the refrigerant to escape and prevent the compressor from engaging. Look for signs of oil or refrigerant leaks around the AC components.
Fuse and Relay Inspection: Ensure that the AC system's fuse and relay are functioning correctly. You can consult your vehicle's owner's manual or a fuse box diagram to locate the relevant fuses and relays. Replace any blown fuses or faulty relays.
Check the Pressure Switch: Many vehicles have a high-pressure and low-pressure switch in the AC system. These switches monitor the pressure in the system and can prevent the compressor from engaging if the pressure is too high or too low. Check these switches for proper operation and continuity.
Inspect Wiring and Connectors: Examine the wiring and connectors leading to the AC compressor. Look for damaged wires, loose connections, or corrosion. Ensure that there is no damage to the wiring harness.
AC Clutch and Compressor: If all the electrical components are working correctly, you may need to inspect the AC clutch and compressor itself. The AC clutch should engage and disengage when the AC is turned on and off. If the clutch isn't engaging, it may be faulty, or there could be an issue with the compressor itself.
Refrigerant Pressure Sensors: Some vehicles are equipped with refrigerant pressure sensors that can prevent the compressor from engaging if the pressure is out of the specified range. Check if your vehicle has such sensors and test them if necessary.
Professional Diagnosis: If you've checked all of the above and cannot identify the issue, or if you're uncomfortable working on AC systems, it's recommended to consult a qualified automotive technician or AC specialist for a thorough diagnosis and repair.
Remember to prioritize safety when working on your vehicle's AC system, as it involves high-pressure refrigerant and electrical components. If you're not experienced in automotive AC repairs, it's best to seek professional assistance to avoid injury or damage to your vehicle.
Could be several problems. Depending on what vehicle you have you may have high and low pressure switches. If the freon is low, the low pressure will not let the compressor engage. The ac controller could be bad not sending current to the AC clutch. If you have power to the relay, depending on the vehicle, the relay may not be getting a ground signal.
Looks like the low pressure switch gets power from a 10amp ac fuse. Power then goes to the ac relay which is powered on by the ac heat controller on the dash. Power then goes thru the high pressure switch to the compressor. The ac relay is grounded to the body. Do you have power on the lite and dark green wires going into the relay and is it grounded ?
On the low pressure line of the ac you have a pressure switch which allows the compressor to come on once a certain pressure is reached, and it will cut the compressor off if the pressure is too high or too low. Look at your ac hose and find the switch *you will see wires connected to it* you may need to replace this switch. You can use a test light to see if you are getting power to the switch. You should check you fuses, and the ac relay witch is usually in a black plastic box under the hood.
CHECK AC COMPRESSOR CLUTCH SHOULD BE ENGAGED OR RUNNING WITH AC SWITCH ON POSITION.IF NOT CHECK AC COMPRESSOR CLUTCH FUSE AND RELAY.IF BOTH GOOD AND POWER IS GOING TO AC CLUTCH.YOUR CLUTCH IS OPEN.IF ALL LOOKS GOOD YOUR AC LOW PRESSURE SWITCH IS BAD.COMPRESSOR SEIZED OR YOU HAVE TOO MUCH MOISTURE IN AC SYSTEM.
On the Hi/Low pressure switch conection Terminal 1 and 2 are for AC clutch bridge them briefly to see if clutch engage if so system is low on refrigerent.
If you get cold air its more then likely Hi/Low switch is bad.
Note engine must be running and ac fan in on position.
