Question about Jensen XA2150 Car Audio Amplifier
Jensen XA2150 Hi Input help
I have a Jensen XA2150 and I dont have the cable plug that slots into the hi input socket on the amp itself. Now the manual shows the cable jack but it isnt the same on the amp because in the manual there is a diagram showing only 5 wires (L+ L- R+ R- Earth) all in one line but on the amp there is actually 6 needed cables which goes in a pattern 3 squares across on top and 3 squares across bottom. These holes which the speaker cables go into are unlabled and I need to know what one is which because I have created my own plug and all i need to do is wire the correct cable into the correct socket.
Can I please be given a diagram showing which hole is what. Thanks so much!
  • 20 Answers
According to crutchfield, this connector should have come with the amp. Was this an open box? I would suggest getting a replacement molex connector from jensen. I see what you are talking about in the manual, and if you don't have the supplied connector, you have a big chance of frying your amp. The manual expects you to have this connector, and is not specific about the actual pins. For all you know, you could be wiring it the opposite way. Either that of call jensen, and ask how the pins are layed out. If you are confident you do have it wired properly, you could try both pins, and see which is the ground, but this is risky of course. There is also the chance there is no actual metal connector in one hole. You can also test for impedance if you have a multimeter, and you definitely should if you are taking shot in the dark with your amp.
Posted on Nov 19, 2008
Jensen 300 watt 2 channel amp model xa2150
Get into this link. You can download the operation and installation manual to your Jensen XA2150. It is absolutely free download. If you fail to get it downloaded, inform me by Fixya comment box, with your email address. I've the downloaded manual with me, and I'll send a copy of it to you by return mail. OK
Please don't hesitate to rate this solution.
Dec 23, 2011 | Car Audio & Video
How to i install a Pioneer DEH-1250 to a Jensen 5500?I got these as a gift and its like confusing me.Please help me out and send me a diagram on the input wiring from the Pioneer player to the Jensen 5500-...
Hi, what you want to do is just connect the speaker wires from the head unit straight across to the pre-amp inputs of the amp. If you have a sub, also connect the pre-amp outputs of the head unit to the 2 sub inputs of the amp. Connect the blue wire of the head unit to the turn-on terminal of the amp and connect power wires to both units. May I ask what speakers are you using?
Aug 14, 2011 | Jensen Car Audio & Video
Hi! I have a Jensen XA2150 Amplifier, from the speaker output I have connected a Subwoofer Sony 10 inch 1100W. Tha'ts gave me a nice bass sound, but now it's death! The amplifier have a 25A fuse,...
Have you checked the fuses inside the amp?Unscrew the cover and with the amp sitting on its back,remove the cover.You have 2-4 fuses,old round type,in there.
May 21, 2011 | Jensen XA2150 Car Audio Amplifier
Case has 1 small speaker in front but dont know where to connect to motherboard. speaker have 1 black & red wire on small female plug
Input the speaker's jack to the mother board,from back side or the front panel,which is green socket.
Hope this helps. Let me know if you need more information Thanks
May 11, 2011 | Intel Motherboard
Where can i get the hi-input plug jensen 600w amplifier? amplifier made by audio-vox, model jpa460, 10 prong socket
You will have to call Jensen. They normally don't come with amps anymore as most users prefer the RCA input for better clarity and sound quality.
Aug 11, 2009 | Jensen 100W x 4 Amplifier KA5 Car Audio...
PINs for high level input
Hello gmb_66,
You did not specify exactly which Jensen amp you have. None of the Jensen PowerPlus series I found had high-level inputs. You can go here and select your amp to download the manual. They should also have the connector for speaker inputs.
Most amps that have both high-level and RCA inputs allow you to use one or the other, but not both at the same time. If your head unit has RCA ourputs, those would be the ones to use, because they generally provide a cleaner signal to the amp with less noise.
Hope this helps.
May 24, 2009 | Jensen Car Audio & Video
Jensen xa2150 amplifier
Check and see if its dirty inside, dust and smoke are known to cause problems via shorting or not making contact... sometimes your fuses are a bit over the wall so it would be best to replace them... and check if you have a fuse between your battery and the power cable to avoid over powering the amp
Dec 18, 2007 | Jensen XA2150 Car Audio Amplifier
Power on
you must use same cable used to power sound unit.
also check if the sound may have a remote connector.
Dec 04, 2007 | Jensen XA2150 Car Audio Amplifier
Hi, Jensen is under different ownership from when your amp was made, so it's unlikely that you'll find a replacement plug for the high-level input. A high-low converter is also called a line-out converter. It's a device that connects to the speaker wires and changes the signal to a low-level RCA connection. This allows you to use the amp's RCA plugs with your speaker wiring (through RCA signal cables). A line-out converter should be available any place that sells car audio accessories.
Aug 11, 2007 | Jensen XA92 Car Audio Amplifier
Jensen XA2150 Car Audio Amplifier Logo
372 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
