Question about Sony FD Trinitron WEGA KD-36FS130 36" TV
WEGA 36" : Screen is low contrast and green
Hi, Our seven-year-old Sony Wega recently started having problems. Typical behavior on power-up is a black screen for 5-10 minutes, followed by flickering (the screen turning off and on every two to three seconds). As time went on, the flickering went on for a longer period. Now the screen cycles off and on during any scenes with high brightness. At the same time, the color balance has gone way out of whack. The image is now green monochrome and very low contrast. The blacks are medium green. I went into the service menu to see if any adjustments could be made, but attempts to change the red and blue settings did very little. Any thoughts? Thanks, Dave
    President:
  • 3,130 Answers
Sorry to say, it sounds like a bad picture tube, But could be also the capacitor that filters the screen voltage on the crt drivers. In all my years though, your complaint has been the picture tube. Good Luck.
Posted on Jan 02, 2007
Hj Sony Grand WEGA KF-42SX300 42" LCD TV
Check the options of contrast or tint, if your adjust them to your preferences then maybe it will work, or maybe it is just old. Glad if I helped.
Feb 05, 2014 | Sony Grand WEGA KF-42SX300 42" LCD TV
TV repeatedly goes into standby mode and then comes back on
Resolder Horizontal section & SMPS Power Supply with Soldering Iron
Jan 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Picture will come on and then go off after a couple minutes
This usually means the Lamp is failing. Replacing the Lamp usually fixes it. I would only use a Sony Replacement.
You can order one from Sony at 1800-222-SONY or you may be able to pick one up from a local Sony Retailer.
Skyassoc
Nov 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony wega kv-36hs20 will not turn on
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Mar 02, 2009 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Sony wega tv blinks seven times and does not come on
seven blinks means high voltage shutdown it gone into safety mode you need to check power supply regulation and horizontal circuits
shaun
Jan 16, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony 36 Wega XBR Flat Screen - sudden death.
This could be a scan amplifier failure, and there is a loss of high voltage to the CRT. Part of the power supply may have also failed. In these sets, if the CRT emission goes low in emission, or the CRT goes defective, the bias supply to the CRT will go in to protect.
An experienced TV service tech can troubleshoot the set and give you an estimate for service. Considering the age of the set, the cost of service may not be worth it.
Jerry G.
Jan 08, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony trinitron wega 36 inch
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
Aug 25, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
SONY GRAND WEGA KDF-60WF655 - VERTICAL LINES
This seems to be common problem with Sony projection tv. I have the KDF-E50A10 that lasted only 2 years. It's sitting in a corner now until I figure out what to do with it. I am not going to spend another grand to repair it!! Never Sony again.
Jun 16, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
SONY TV Model KV-36FV300 Problems
plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
Jan 30, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony FD Trinitron WEGA KD-36FS130 36" TV Logo
196 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
