Question about Frigidaire FSC23F7D Side by Side Refrigerator
Drain pan underneath fridge is filling on a daily basis
Brand new Whirlpool top freezer refrigerator (Model Number: GR2SHWXVS01)
Three days in a row, I have heard water coming out of tube in the back (more than a drip), most likely during defrost cycle. When I check the drip pan, it's almost full. I have hard wood floors, so I empty the pan immediately for fear of the pan overflowing.
Is it normal for this much water to be coming out? Should I be able to hear it dripping that much? And lastly, if I let the water go, will it evaporate, or do I need to empty the pan every single day?
Please help!!
    New Friend:
  • 28 Answers
The system is designed to evaporate that water using the warmth of the compressor.. is your compressor warm ? (the drip tray sits on top of it) I see that model has an Ic e maker... to check that the ice maker refill is not running on too long, switch off the ice maker, by lifting the wire arm that checks the level of the ice in the storage bucket.. leave it turned off for a day or two.. empty the drain pan, and check it again after 24 hours.. but if the ice is already full, the water problem may APPEAR to be resolved already, but will return when the level drops and the ice production begins again.
If it is just condensate, then the drain pan should be able to contain the amount it produces, but 3-days straight, would indicate to me, that is not that... if your water pressure is good, it may be that the ice tray filler solenoid is being held open a fraction too long (maybe a second or so) and as the fridge is new, it will be making lots of ice to fill the container up,... so lots of small overfills.. mounting up to a full drain pan. Under normal use,.. other than parties and festive nights, when you use a lot, the water should evaporate faster than it is produced, but it shouldn't be happening at all.. if it is that, then turn the tap at the back of the fridge to where the cold water dispenser slows down slightly.. that should be enough to prevent it continuing.. IF that's the problem.
Posted on Apr 24, 2017
  • 1462 Answers
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
docjohn174
  • 943 Answers
SOURCE: refrigerator water drip pan
thanks for the question no other way to do itthere is no drain hose attached to that tray sorry thanks for the question The appliance doc
Posted on Sep 11, 2008
  • 151 Answers
SOURCE: kenmore model 253.65812502 water leaks from
Do you live in a area where it's humid. Check if the doors seals are sealing properly.
Posted on May 14, 2009
Bat1956
  • 585 Answers
SOURCE: drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
Posted on May 20, 2009
woodchuck789
  • 4070 Answers
SOURCE: ice buildup in freezer drip pan and water overflow
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 21, 2009
Top freezer whirlpool refrigerator condensation water leaking/dripping
there is a drain in the freezer that sum time get Clogged the drain is located below the evaporator coil you have to remove the evaporator cover to unclog it make sure the refrigerator is unplugged before trying this you can't unclog the freezer drain without removing parts
Sep 10, 2013 | Refrigerators
Frigidaire upright fridge freezer.The drainage hole at back of fridge part of item keeps freezing over blocking drainage from fridge
Yrur model number is missing the last three digits.... I will use FRT21H8CB1 as the example model number.
You need to do a total manual defrost with a catch basin and comprtment drain cleaning.
- Unplug the unit
- Remove fgreezer contents
- Direct an exteranl fan into the freezer compartment for just over 2 hours to ensure the compartment drain tube has defrosted.
- During the defrost period... open the fiberboard panel on the lower back of the refrigerator and clean out everything, Condensor coils, catch / drip pan (Called pan-defrost for parts), and the END of the compartment drain tube.
Model reference:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5158190&diagram_id=1311449#d1311449
Defrost pan Item 26 of above link needs to be cleaned.
Coils Item 1 need to be cleaned
Fan blade Item 61 needs to be cleaned.
The evaporator trough, drain item 17 also should be clear. Here is what you can do without tearing everything in the back of the freezer apart. Once your sure the comprtment drain tube (no item number / bulk hose) is clean on the end. Use the exhaust of a Vacuum cleaner and the hose to force air UP through the drain hose and float out any debris from the trough drain. Have a 2nd person listen for air flow into the freezer compartment if possible. The biggest problems with freezer compartment drains is the END of the hose at the defrost pan underneath the unit clogs up and then the compartment drain hose just loads up with scum. Then the freezer stops draining and you have the symtom your describing.
After the manual defrost and cleaning return the unit to normal service.
Having said all of that... if the refrigerator then freezer starts warming up in 3 - 4 days... you may have an automatic defrost problem causing the icing. I.e it is not defrosting so the evaporator eventually ices over and forms an ice block in the back and bottom of the freezer compartment. Usually if there is an ice block that forms you wil hear the evaporator fan striking the ice build up.
If this is happening... for sure there is an automatic defrosting problem and your stuck doing a manual defrost ever 3 - 4 days until repairs are complete.
One more note.. if there is NOT any compartment drain tubing visible... your unit may port evaporator tray water down the back of the fresh food compartment to the defrost pan under the unit... just clean everything that serves as a drain function best you can during the manual defrost and cleaning process.
Thanks for choosing FixYa,
Kelly
May 23, 2011 | Frigidaire FRT21H8 Top Freezer...
Where is the defrost drain in a whirlpool refrigerator model number ET1FHMXMQ00
It's part 7 in this diagram. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5149338&diagram_id=929467#d929467
It's behind the rear cover inside the freezer. From there the water drains to the drip pan underneath the fridge where it's evaporated by the condenser fan.
Jan 30, 2010 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool refrigerator leaking from top of unit
Listened to other posts and figured drain plug was clogged. It was with ice. Removed bottom pan and back panel of freezer, removed ice on bottom, put hot water in drain to thaw ice until it flowed into pan underneath fridge. Thanks for the ideas.
Jun 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
There is water dripping filling up the bottom under the salad container. The model is a LRTN22311TT.
Remove contents of fridge and check the drain line running down the top back of the back of fridge and follow to lower section of fridge (usually a back ledge or under the crisper sections) and locate a small round drain hole. Also, check to see that the drain collector (funnel looking thing at top back of fridge section) is located under the freezer defrost drain opening, to allow water to flow through the fridge into the drain pan under the fridge.
If something has obstructed the drain funnel, path, tube, or lower drain hole, remove the blockage to allow water to drain into underneath of fridge into drain pan for proper evaporation of water produced from the usual daily defrost cycle of fridge/freezer.
If that is not the problem, it could be that you have a leaking water supply line for your ice maker and you'll need to see if the freezer is allowing excessive water to flow out of the ice maker into the fridge section.
Another simple check/solution is that the fridge is not properly leveled, meaning that the front of the fridge should be slightly higher than the rear to allow for proper drainage and self closing of the front doors. This will help keep the water flowing in the built in channels and drains.
A perfectly level fridge isn't the right way to install most moveable refridgerators, while built in fridges (Sub Zero, etc.) are designed for plumb and level installations for proper functioning and use.
Apr 09, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Can't get to drain pan for cleaning, whirlpool fridge
You can not acces the drain pan. Por 1/4 cup bleach in the defrost drain hole.
Two days later pour 1/4 cup vinegar in the defrost drain hole.
Mar 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
for reallybsq
for guest.
Sep 06, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Frigidaire FSC23F7D Side by Side Refrigerator Logo
372 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
