Question about Onkyo TX-SR604 Receiver
No Power I plug the unit in, and no clicking, no power. This is a Onkyo AV Receiver TX-604. I checked with a meter and it is getting power to the power board, 120 v, I hit the power button and nothing. I did find tho if I take the power board off the frame were it is not grounded to the rest of the unit the unit does power on and I get lights on the display, every light for that matter and they just stay on, but nothing works yet. It kinda seems like a grounding issue to me, but I am not sure. Or if not being grounded to the rest of the frame it just does that. All the fuses work fine, check them with an ohm's meter. All cable are or seem fine. Not sure what else to check, or if it is junk. Any thoughts would be welcome. Thanks
  • Official Brand Answer
  • 333 Answers
Hello, I am sorry that you are having an issue. Your receiver needs to be serviced. If you are in the US you can take advantage of our trade in program. Please contact us at 800-229-1687 option #3 and we will provide the details. Thank you, Onkyo USA
Posted on Mar 27, 2017
SOURCE: Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Posted on Jun 02, 2008
When I initially bough mine, I had the same problem. It wouldn't shut down, but occasional popping sound on the center speaker. Turns out the impedance on the speaker was 4 ohms, not not 8. Replaced center with an o 8ohm speaker. This receiver is not reated to run 4 ohm speakers. If I had problems with 1, I can only imagine what kind of problems could happen if all the speakers were 4-ohms.
Posted on Aug 03, 2009
  • 5 Answers
SOURCE: Onkyo Reciever TX-SR806 Losing HDMI signal.
I had the same problem with my xbox 360. I was able to fix the problem by disabling the Display Discovery setting on the xbox.
Posted on Feb 12, 2010
  • 2335 Answers
SOURCE: I own an Onkyo av receiver and I want the remote
Samsung Blu-Ray player code for Onkyo universal remotes is 33001.
You can download Onkyo universal remote codes with instructions here.
I hope that helps.
Posted on Apr 20, 2010
  • 3 Answers
SOURCE: Onkyo TX-DS777 does not retain settings after power loss
No internal battery, a large "SuperCap" on the main board acts as one. Look for C8007, 0.1 F, 5.5V.
Posted on Jun 24, 2010
Onyko tx nr616 receiver keeps shutting off. Only stays on for approximately 3 seconds. Can you help?
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 30, 2014 | Onkyo Tx-nr616 7.2 Thx Certified Network...
Onkyo tx-ds656 stand by power light comes on volume control knob rotates to max but display or unit wont start
Try factory reset: while holding the(CD) button on front panel,press (POWER) button.
After "Clear" is displayed the unit should be back to its factory default. :) If this dont work for you take the unit to be checked by service . :)
Jan 24, 2014 | Onkyo TX-DS656 Receiver
Had a power surge and now my Onkyo TX-SR607 will not power on. Only get a constant click sound. Any repair advice?
although power surge can trigger activations of protection circuits,
there are at times, damage is done before it is activated.
• Check first for low power supply regulators,
then check for possible output stage failure.
let me know if you need further assistance!
Sep 09, 2012 | Onkyo Tx-sr607 7.2-channel A/v Surround...
Apr 26, 2010 | Onkyo TX-DS777
Onkyo TX SV7M Knocked out by Power Surge
Try pulling the plug out of the wall for 5 min or more,give the unit a chance to reset.Hopefully you didn't get a power surge that might have blown the protection circuits.
Jan 03, 2009 | Onkyo TX-SR705 Receiver
Onkyo TX-SR502 AV receiver
this could be the pre amp transistor or the power amp that needs replacing
the pre amp transistor is cheap but the power amp is not
if you did not crank it , then it is probably just the transistor that needs replacing
Oct 31, 2008 | Onkyo TX-SR602 Receiver
Unit no longer powers up after shorting the switched plug in back of unti
you most likely fried a circuit board trace on the power supply
Dec 25, 2007 | Onkyo TX-SR500 Receiver
Onkyo TX-SR604 Receiver Logo
65 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
