Question about Sansui VRDVD4000 DVD Player/VCR
Vcr eating tapes
Does anyone have a solution for the VCR eating the tapes ??? Thanks , Bara
  • 520 Answers
SOURCE: Sansui VCR/DVD combo unit
Use the SLP speed setting.
Posted on Sep 08, 2008
  • 458 Answers
SOURCE: Sansui DVD/VCR remote control issue, VCR works/DVD does not-black
There should be a DVD/VCR button on the remote control which will toggle the machine from one playback source to another. If she has pressed the VCR button then the machine will only playback tapes & not show DVD's. Press this button & the DVD's should play. If you look closely at the front window of the machine it will show what mode it is in ie VCR or DVD, set this for the DVD to get it to play.
Posted on Sep 16, 2009
  • 975 Answers
SOURCE: I have a VRDVD5000 vcr/dvdrecorder and am missin
check tyhis site , complete the info needed then download the manual , hope this helps AJ
Posted on Oct 24, 2009
Testimonial: "great resource but very expensive searched distributor instead and got a manual for 4.50 + shiping"
  • 6993 Answers
SOURCE: cannot remove vcr tape from my 13 tv/vcr combo
there is every possibility that the tape has coiled inside the player and that's why it cannot remove.
You need to open up the player so that you can gain access to the tape and remove the tape from whatever might have hooked it.
This should work a great deal because I have done this couple of times.
I wish you good luck.
Posted on Mar 04, 2010
  • 242 Answers
SOURCE: vcr eats tape old samsung blak box
Check all belts. clean the all moving parts
Posted on Jul 17, 2010
  • 485 Answers
SOURCE: Can the sansui vcr/dvd combo record vcr tapes to a
No, the DVD section only plays DVDs, to record VCR tapes to DVD you need a ripping device that digitalize audio and video (convert step) and then transfer to DVD specifications this data to disk (record step). The easiest way to do this is using a USB video capture adapter connected to your PC with a DVD recorder drive installed, the software to do this commonly comes as a bonus in the setup disk of the adapter.
Posted on Mar 17, 2011
0 characters
1 Points
The vcr of my dvd vcr combo is eating tapes and will not play
the vcr needs a re alighnment,(on the tape path)and maybe a idler as well needs to be repaired
Jul 05, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR is eating tapes
There are different reasons that a VCR could start eating tapes. It could that it just needs a good cleaning or it could have a mechanical problem you will really need to have it checked out by a service center to determine why. If you have small children I would check it for signs of “peanut butter sandwiches. J
Nov 29, 2009 | Philips Magnavox DVD/VCR Dual Player
The vcr on my sylvania vcr dvd combo DVC840E eats my vcr tapes. What can I do
Clean the tape path, that any thing the tape come in contact with. there is a roller that presses the tape against a metal guide. The roller should be dull not shining.
Aug 04, 2009 | Sylvania DVC840G DVD Player/VCR
My vcr/dvd recorder eats the tapes.
clean pinch rollers and head. check if there is any dirt on capstan post
Apr 30, 2009 | Philips Magnavox DVD/VCR Dual Player
Eats Tapes
clean all moving parts.
May 02, 2008 | Broksonic DRVCR900 DVD Recorder/VCR
Dvd/vcr sylvania combo
did a few google searches and suggestions were made to buy a**ther vcr...** way to fix the vcr heads. thanks anyways!
Mar 08, 2008 | Sylvania (SRDD495) DVD Player/VCR
VCR stops, ejects, eats tapes
clean the heads and retime the gears.
Nov 24, 2007 | Symphonic WF802
VCR Eats the tapes
Often the "Pinch Roller" type Tape Drive can "Dry Out" and it slips. this causes the tape to get all screwed up.. It could also be a belt that turns the capstan.. Or even a thing called the "Mode Switch" In any event Ya probably be best to take it in for repair as it's not really a "Homer" I suggest ya get a quote and an explanation, and see if it is economically worthwhile?
Aug 22, 2007 | Sony SLV-D550P DVD Player/VCR
VCR eating tapes when attempting to rewind
VCRs are so cheaply priced these days that it's not worth the time and trouble to fix them or have them repaired. If you fix one worn or slipping belt, another problem isn't far behind.
Feb 26, 2007 | Symphonic WF802
Sansui VRDVD4000 DVD Player/VCR Logo
Top Sansui DVD & Blu-Ray Players Experts
Josh Whitehead
Josh Whitehead
Are you a Sansui DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
