Question about Honeywell Programmable Thermostat Heater
HELP NO HEAT
My notice my heater not working. I thought the thermostat wasn;t working so I bought a new one.SAME problom.My heater fan comes on and the heating element is lighting but no ignition. WHATS the deal?
  • 27 Answers
Sounds like a gas valve issue. if the hot surface ignitor is glowing red then the next step is for the gas valve to open, if it doesn't then it sounds like the valve, if it does open but only for a few seconds then it is your main burner flame senser.
Posted on Nov 26, 2008
Hi. I am not getting any heat. I have a White-Rodgers manual mercury thermostat model 1F56-501 and natural gas heat with GOODMAN packaged gas/electric model PGB024050-1 Before I call a service rep, I...
Hello,Good job with description.Something is keeping the condenser off(saftey).Do you have an emergency heat setting on the therm.It will run electric heat strips only until service can check it out.Very rare that the disconnect switch (black box) is it.Need electrical meter to prove it out.
Dec 01, 2010 | Goodman Heating & Cooling
1999 chevy cavalier. wasn,t getting heat to inside. put in new thermostat. heated up fine for a couple of miles, then cool air. shut off when got back home. anitfreeze was bubbling back out of reservoir....
make sure you get ALL the air out run it without cap until you see water circulate turn heater to hot NO FAN ABOUT 5 MIN close cap ,see if that works
Nov 29, 2010 | 1999 Chevrolet Cavalier
My 99 saturn sl drains the battery and the heater fan and ac won't work. I got a new battery and it drained it and won't take a charge again. can anyone help? chuck
Sounds like 2 probloms there is a bad alternator so the battery is not being charged, and the fuse for the heater/ac fan is bad
Jul 12, 2010 | 1999 Saturn SL
Replaced mercury thermostat w/Honeywell CT87K - doesn't work!
You need a specific thermostat for a Wall Furnace it is a Millivolt Thermostat and not a 24v standard thermostat....usually it will work anyway however if the powerpile (generator produces millivolts from the pilot light) is weak it may not be producing enough...or the Pilot light may be dirty and lazy...won't produce enough millivolts ...or you can have bad or dirty contacts or connections....or a combination of any of the above.....a 24v Thermostat and particularly a non-mercury thermostat has too much resistance in it for a millivolt system....as your Wall Furnace (other than the fan) runs on less than 1 volt
Oct 31, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Vulcan Quasar 40 air issue
Hi the problem you have is your heater is cutting out due to the over temp switch getting to hot the reason for this is that your fan is not working thus not enough air flow is getting through the heat exchanger to keep it cool
your heater is designed to not exceed a certain temprature so as not to become a fire risk
to solve your problem you will need to replace your fan
this will solves your problem
Jul 27, 2009 | Heating & Cooling
Heater furnace doesn't want to turn on'
Did the fan turn on, if it did when was the last time you cleaned the filter.
Mar 14, 2009 | LG L1004R Air Conditioner
New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Fan on but no heat
I never liked the user un-friendliness of the Chromatherm, I would suggest finding a thermostat that you can understand and operate. Yes the Chromatherm is a good one, but so damned hard to figure out. Stay away from thermostats that still use mercury. Good Luck!
Oct 20, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
69 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
