Question about Vector VEC056 MAXX Power Inverter
Puff of smoke
Vector 5000 watt inverter - sudden puff of smoke and pfffft. No power.
Who can repair these things? I think I overloaded it with 2 heaters plugged in at the same time.
Yes u got da inverter overloaded out puts r gone 2hot and fan couldnt cool it enough now this inverter basicly a amplifier amp does da same problem when da out put r blown yes i got da unswer
Posted on Mar 03, 2009
Have you looked at the fuses within? I have two in the one I am trying to fix!!
Peter
Posted on Nov 26, 2008
A puff of smoke into cab (vents), then the AC turned off
of course check the compressor for malfunction but that would never explain a puff of smoke in the cab what did the puff of smoke smell like just a water vapor electrical, rubber,
May 28, 2013 | 2005 Nissan Frontier
I have a auto pro 800 watt inverter that gives 220volt ac **** wont run my kellerman freezer it runs in the house on ac can you help
If your freezer need more than 800 watts to run then your 800 watt inverter will be overloaded and it will shutdown.
Mar 21, 2012 | Vector 1000w Power Inverter
Vector 3000 watt model VEC051D
Time for a new inverter. Lesson learnt I dare say.
Check polarity!
Sep 05, 2017 | Vector 3000w
Overloaded grinder no longer turns after puff of smoke!
the shear pin, which goes through the grinder blade base and the motor shaft has 'sheared' off the protect the motor from overload. The metal bits of the pin need to be removed from both the grinder part and the shaft, a new one inserted. It is a 'pressed fit', so it will be hard to remove.
After the bits are removed, a common 'roll pin' of the proper diameter should be a suitable replacement
Feb 04, 2010 | DeLonghi DCG39 Electric Blades Grinder
89 chevy s10 blazer puff smoke out tailpipe when 1st started
A puff of smoke when you start up indicates worn valve seals.That's why all your work didn't fix the problem and it doesn't show a code. It's a pain in the --- job that requires some specialized tools so I guess it depends on how bad it bugs you,if oyu want to fix it.
Jul 13, 2009 | 1989 Chevrolet S-10 Blazer
Puff of smoke from crack between heater vent and dash
antifreeze i think,heater matrix leak ,try putting a rad leak stopper in
Jan 19, 2009 | 1998 Ford Contour
I think my inverter burned.
it depends on what burnt in it, you should check it out to know
Jan 13, 2009 | Vector VEC 024 400-Watt Power Inverter...
Hp L1490 monitor
problem in smps output diodes or the output transistor located near the FBT/EHT
mail me ur response @ vishwas_4u@rediffmail.com
Apr 06, 2008 | Computers & Internet
Vector VEC056 MAXX Power Inverter Logo
478 people viewed this question
Top Vector Electronics - Others Experts
Marvin
Marvin
Craig Butler
Craig Butler
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
