My Gateway flat screen monitor model # 1730 has no power
No power when plugged in.
  • tatlocs Dec 15, 2008
    The button's on the screeen don't work
    New Friend:
  • 62 Answers
1. cheak the power cable.
2. fuse
3. 3842 ic
4. horizontal out put transistor.
Posted on Nov 19, 2008
The monitor does not turn on.
Are you using the correct cable from the PC to the monitor?
Mar 25, 2014 | Gateway FPD 1730 17 in. Flat Panel LCD...
Monitor flashes on but with 1-3 seconds it goes to balck screen. I've replaced the electrolytic caps in the power supply, but it didn't help
Try different video and/or power cables, but most likely this is dead. Sorry!
If it's still under warranty, (or the computer it came with is), call Gateway support.
Mar 10, 2010 | Gateway FPD 1730 17 in. Flat Panel LCD...
Why would the Gateway FPD 1730 17 in. Flat Panel LCD Monitor turn on,,then go right back off,,if you leave it unhooked for a few days then it will work for a short time than quit again
This sounds like a typical Capacitor in the Power Supply fault. Some people take them apart and replace the capacitors, however I recommend that you get a "Quote" for repair, as these often "Chain Fault" and I have seen a lot of disappointed would be fixers.
Feb 20, 2010 | Gateway FPD 1730 17" Flat Panel LCD...
Message from display FPD 1730 won't go away
press the menu button on screen panel and press exit.
Dec 02, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Computer will power up, but FPD 1730 screen stays dark, says "power saving mode" How to cure??
Its setting problem just fallow this stapes for the same.
Go to Start > Control panel > Power options Properties >
Turn off monitor: Never
Turn off hard disks: Never
System standby: Never
Apply > Ok
After that your issue will resolve.
Thanks
Abhay Singh
Nov 16, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway flatscreen monitor
There is a problem with the power supply cable to this monitor. You need to have a new one put on. An easy way to test this is to get it to a shop so they can test the cable.
Jun 11, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway flat screen monitor goes black when turned on
open monitor and look at the PC Board to locate some kind of DRY SOLDER or burn point , specially where a transformer is located , check re solder any solder point that looks suspicious , and try again , hope this helps
May 03, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway FPD 1730 17 in. Flat... Problem
Try using it on a different computer, it's possible that it is your graphics card causing the problem. Check for bent pins.
Dec 20, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Computers & Internet Logo
410 people viewed this question
David Payne
David Payne
