Question about GE Refrigerators
Condenser fan turns very slow
Conderser motor turns slowley you can stop it with your hand and it may or may not start. What controlls the speed of it?
SOURCE: fan motor slow on a/c
If the fan motor has a capicator it could be bad. A bad cap will pull the motor down. If there is no cap then the motor beatings could be going bad. this can be checked by matching the motor amps with the rated amps on the unit information tag.
Posted on May 18, 2008
  • 7 Answers
SOURCE: fan motor keeps running on Audi A4 2004
fan motor has a thermal switch which turns on the fan as soon as the engine heats up. what happened there is that the switch is stuck on the closed position which keeps the fan on all the time. you should go to a garrage and have the part changed.
Posted on Jul 22, 2008
  • 62 Answers
SOURCE: Condenser fan motor
Technically, you could take the wires off the motor and check to see if you have 120 volts which elimenates any other componet. The fact that you can spin the motor and it runs some what indicates that you do have the voltage there and that the bearings in the motor are going bad and causingthe motor to stop. Repalce the motor,
Posted on Aug 31, 2008
Ajkill
  • 2035 Answers
If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
  • OR
    This could the problem the with short circuit or defective component you need to check :
  • Compressor
  • Overload and/or relay
  • Thermostat (Open thermostat)
  • Burnt wiring
  • Bad selector switch
  • Capacitor
  • Good luck....
    Posted on Nov 11, 2008
    • 25 Answers
    SOURCE: casa blanca fan motor speed control
    www.casablancafanco.com
    Posted on Jan 19, 2009
    Why would evap fan running slow
    If u turn the fan by hand and it turn then u need a new fan, and i think u are mixing up the fans, the fan inside the refrigerator would be the evaporator fan if that was broken then your compressor would be cold, the fan inside the compressor section would be the condenser fan, if that was defective then your compressor would be hot causing the compressor to short cycle. change the fan and clean your condenser coil and your problem should be gone,
    Jan 17, 2013 | True TSSU-27-12M-B Commercial Refrigerator
    Goodman heatpump fan runs, condenser wont start
    Either the condenser fan has bad bearings, or it has a defective fan capacitor.
    Turn off the breaker to the outside unit.
    Spin the fan blade by hand.
    If the fan blade spins easily and will spin a few revolutions with no problem the fan bearings are good.
    If not, replace the fan motor due to bad bearings.
    I am pretty sure you fan motor is bad because with a bad capacitor the fan motor will not get up to speed and may just sit and overheat.
    I'm leaning toward a bad fan motor.
    Sep 27, 2012 | Goodman Manufacturing Goodman GSC130301...
    Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
    That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
    Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
    Gene
    Aug 15, 2011 | Refrigerators
    My magic refigerator/freezer condenser fan stops but when I move the fan blade it starts working and the refrigerator get cold again. Is it a bad fan unit or something else?
    yes if you can barely touch blade and it stops the fan motor is bad. While replacing conderser fan motor be sure to clean dust from condenser coil.Then as regular maintiance clean coils twice per year.
    Aug 12, 2011 | Refrigerators
    Refrigerator gets extremely hot in the center strip on the doors. Is this is a condensor fan problem and if so can you give me an idea of how much it would cost to fix it?
    This is normal. The refrigerant lines run through the center strip to reduce condensation buldup between the doors.
    The temperature will vary and can be as high as 120 degrees F.
    When the compressor cycles off it cools down.
    Aug 08, 2011 | Refrigerators
    Fuses panel described in English
    Hope this helps your out. I know the diagram and locator is a bit blurry but hopefully it gets what you need.
    Drivers kick panel:
    Front wiper 20A - Front wiper system Cigar 15A- Cigarette lighter Audio 10A- Audio, remote control mirror Air Bag 10A -Air bag diagnostics Stop lights- 15A -Rear brake light, high mounted stop light ECU B+ 10A - Shift lock actuator, transaxle controle module, radio, engine control module Room 10A - Interior light, clock, ignition key reminder, rear cargo area light switch ABS 10A- Anti lock brake system control unit ECU IG1 10A - Transaxle control module, shift lock actuator, ABS control unit, DRL unit Meter 10A - Instrument panel, back-up switch, electronics time control module, inhibit switch Turn signal 10A- Hazard switch ,front and rear turn lights, turn indicator IGN1 20A - Ignition switch ABS 30A- ABS pump motor TNS 30A- Tail light, license plate light COOL/FAN 30A- Cooling fan Cond/Fan 20A- A/C condenser fan Starter 15A- Start signal , Fuel pump Blower 25A- Blower Motor SR/ACC 10A - Ignition switch Hazard 15A - Hazard and turn signal light D/Lock 25A- Door locks ABS 30A - Anti lock brake system control P/W RH 20A- Power window motor right hand P/W LH 20A- Power window motor left hand IGN2 25A- Ignition Switch
    Engine compartment :
    Head 25A- headlights IG 2 30A- Ignition switch IG coil 15A -Ignition coil, condenser,generator IC regulator, diagnostic connector. O2 down 10A- Rear O2 sensor O2 up 10A- Front O2 sensor Fuel pump 10A -Fuel pump unit Injector 10A -Fuel injector ,camshaft positioning sensor, purge solenoid valve, EVAP, IAC actuator, Mass Airflow sensor, EGR stepper motor. fuel pump relay coil, vehicle speed sensor. A/Con 10A - A/C compressor controls, cooling fan BTN 30A- Brake light , high mounted stop light. Tail light LH 10A- License plate light, tail light , rear combo light, instrument panel illumination Tail light RH 10A-License plate light, tail light , rear combo light, instrument panel illumination Head low 15A- Headlight Head Hi 15A-Headlight Horn 15A- Horn jlmacman.png jlmacman_0.png
    Mar 07, 2011 | 1995 Kia Sephia
    The fan on the bryant high efficient heat pump moves very slow or not at all
    Hi, this is a 3 ton unit. It may or may not have a variable speed fan. You are saying it turns very slow or just stops. I believe you either have a problem with the run capacitor, or you are loosing this motor. They are putting variable speed blower motors on some units now, but if you are talking about your condenser fan motor, it may have a head pressure control to speed up this motor when the ambient temperature is higher and slower when cooler, but to stop when running indicates a motor or run capacitor problem. Check the cap. for oil leaks, swollen and deformed, burned terminals. If you find this, replace it. Remove the fan guard and carefully with the power off after it has ran for a while touch to see how hot the body of the motor is. If it is to hot to touch, you are loosing this motor. If you have a clamp around amp probe or know someone who may, you can look at the data plate to see what this motor should be drawing as far as amps and compare your readings to this. You will know for sure doing it this way.
    Shastalaker7
    A/C, & Heating Contractor
    Jun 21, 2010 | Goodman CLQ36AR49 Air Conditioner
    CONDENSER FAN WHIRLPOOL MODEL CA3030VKA1 2 TOM
    check the capacitor of the fan motor.fan motor wiring will be done in parellel to the compressor check the wiring.
    May 31, 2009 | Whirlpool ACQ122XK Air Conditioner
    Fan motor slow on a/c
  • Compressor
  • Condenser
  • Evaporator
  • OR
  • Compressor
  • Burnt wiring
  • Capacitor
  • Good luck....
    Nov 11, 2008 | Heating & Cooling
    Refrigerators Logo
    117 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    Charles T Nevin
    Charles T Nevin
    Andrew Taylor
    Andrew Taylor
