Boot Windows Vista Install disk by US. - Computers & Internet
    Scholar:
  • 195 Answers
Ha Ha Ho Hee Hee Ha Ha
Posted on Nov 19, 2008
Can't get past this screen....
Hi
your boot up files have become corrupted
you need windows install disk to reinstall your missing boot up files
for the windows you have installed on your pc
xp vista 7 or 8 etc install disk
common problem
when you reboot from the disk and it loads
it will ask you to install or repair
select repair and follow the prompts
to replace boot files or master boot record mbr
cheers
May 26, 2015 | Computers & Internet
Tip
How to install Windows Vista/7 using bootable USB storage device
How to install Windows Vista/7 using bootable USB storage device Requires:
- Windows Vista/7 DVD 0r installation source (setup backup files)
- A 4GB USB 2.0 Storage device (Its recommeded to use USB 2.0 device for optimal performance)
  • Plug your USB storage device.
  • Run CMD and execute the following commands one by one.
  • Diskpart
Run Disk parition utility
  • List disk
To get disk index that is used to pefrom disk paritioning.
  • Select disk 1
Selects disk to pefrom disk paritioning.
  • Clean
Flush your existing all USB drive's partitions.
  • Create parition primary
Creates a parition as primary parition.
  • Format recommeded
Format your USB drive w/ recommeded parameters. (No need to worry about file system format)
  • Active
Set the parition as active to hold bootmgr.
  • Exit
To quit Diskpart utlity
Now copy all Windows Vista/7 files to USB storage device... thats all.
  • Boot your PC w/ it, you can install Windows Vista/7 via bootable USB storage device.
Note: If you face any trouble to boot w/ it or unable to boot, try this
FIX.
I:\Boot\Bootsect.exe /NT60 I: Where I: is the drive letter of USB storage device
on Aug 29, 2010 | Computers & Internet
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
Upgrading windows vista to windows xp in presario 115DX
You cannot 'upgrade' Windows Vista to Windows XP - that is technically a 'downgrade' and would need you to save all your user data on Vista then format you Windows drive then do a clean install of Windows XP.
If you try to install XP over the top of Vista you will have lots of problems because of the difference in architecture and boot manager changes.
The only alternative would be to set up a dual-boot installation where you install XP alongside Vista but would be best done on either a separate disk partition or on a second disk. Normally such a dual-boot configuration would start with having XP installed then adding Vista as the second operating system.
Jan 11, 2012 | Compaq Presario CQ56-115DX Laptop
Can i boot win vista cd? can i use vista cd to reformat my computer?
Yes you can format computer with vista disk and instal new windows.
Inser that vista disk into cd/dvd rom then when you power up the computer press F1 or F2 del or ALT+F2 key to enter in bios.
Then go to boot menu and set first boot device as cd /dvd rom then save settings and exit from bios.
Then it boot with windows disk.Then follow the procedure and choose installing new windows xp then select 1 partition and format it then it install windows vista on it.It will take 30 to 45 minutes to complete the installation.
Let me know if you need further assistance.
Thanks for using FixYa.
Jul 13, 2010 | Microsoft Windows Vista Ultimate Edition
Tip
Dual Boot Windows Vista and XP
This tutorial will show you how to install Microsoft Windows Vista in a dual boot option with Microsoft Windows XP. This is great choice when you first migrate to Vista. If there are any problems, you can simply boot into XP and get important work done.
In order to install Windows Vista in a dual-boot configuration along with Windows XP, you need to have either a second partition on your existing hard disk or a second hard disk in your system. You will want to have about 20 GB of free space. You can create a new partition on your existing drive using software such as Partition Magic or Partition Expert (which I recommend), both are available online.
Once you have your second partition or second hard disk operational, just insert your Windows Vista disk and restart the machine. Then you will want to boot from CD (or DVD). You should see a screen letting you know that Windows Vista is loading.
The default settings are set for English, click next to continue.
Now select the Install Now button .
Now you will need to enter your Microsoft Windows Vista serial number. By default Windows Vista will activate you copy after installation, you can unselect this option is you wish. I recommend un-checking the box, simply because Microsoft may lock your serial key if it is activated too many times, this could happen if you are experimenting and have to reinstall Vista, or if you decide to install Vista by itself later on.
At this point in the installation, you’re prompted to type in your product key for activation.
If you decide to disable the automatic activation routine, you will receive a warning. Click yes to continue.
If you didn’t enter a serial key, the setup will prompt you for the version of Microsoft Windows Vista that you are using. Select the correct version for your license.
Now you must agree to Microsoft’s Terms. Of course they are completely absurd, but you have now choice.
On the Which Type Of Installation Do You Want Page click the Custom (advanced) button.
On the Where Do You Want To Install Windows? Select your second partition or second hard drive.
Once the select a partition or disk and click Next, the rest of the installation will continue as it normally would. As such, I won’t follow the installation procedure any further in this article.
Once the installation is complete, you’ll see the Windows Boot Manager screen, you can now select which operating system you will boot into. Select Microsoft Windows Vista
You can change the boot manager settings if you would like, if not then you can stop reading. Go to Control Panel, System, Advance System Setting link in the Tasks pane and confirm though the UAC prompt. When you see the System Properties dialog box, click Settings in the Startup and Recovery panel. You’ll then see the Startup and Recovery dialog box.
In the System Startup pane, you can change the settings.
0110110 G.I.G hacker 010101010
www.gighacker.blogspot.com
on Feb 14, 2010 | Computers & Internet
Reboot
To Reboot a computer is to turn it off, wait at least 20 seconds, then turn it back on.
A.If you're thinking of Reboot, as to reinstall the Operating System, you use a Restoration Disk, (sometimes listed as Recovery Disk), insert it in your CD/DVD drive, and restart your computer.
(Just press the CTRL, ALT and Delete keys AT THE SAME TIME.
Not shouting. Windows XP and Windows Vista are examples of an Operating System)
B.If you're trying to install an Operating System, from a CD disk that you bought, I suggest you go into BIOS Setup, and in Boot Order, change the first boot device to CDROM. Insert the CD disk in your CD/DVD drive, and restart the computer.
If you buy a Full Installation CD disk, as listed above, you have to change the Boot Order.
For example:
1.You have Windows XP on your computer now. It has problems, and doesn't work correctly. Instead of getting the Restoration Disk from your computer manufacturer, you decided to just buy a genuine copy of Windows XP, and install it. (This is a Full Installation Disk)
The Windows XP you have installed now, will not let the one you bought install over it, by just putting the disk in the drive. Change the first boot device, in Boot Order to CDROM, and it will. The Windows XP you have now, will 'see' the Windows XP you're trying to install, as just the same version. You have to install a better version of Windows, in order for it to write over what is installed.
Such as Windows Vista.
2.You have Windows Vista on your computer, and are not happy with it. You would like to put Windows XP on instead. Windows XP is considered a lesser version, and Vista won't let it write over it.
Go to BIOS Setup, change the first boot device in Boot Order, to CDROM, and it will.
May 10, 2009 | Compaq Presario R3000 Notebook
Dual Boot problem in Windows XP & VISTA
Don't try to edit the xp boot.ini or the vista bootloader. It only leads to other problems and headaches.
Try this first: Take note as to which drive has vista on it, put your vista installation cd in the drive and let it boot to the "installation window", then choose "repair", then "startup repair." Make sure you choose the drive that already has vista on it. Let that run and when it re-boots you should then be given a choice to boot to vista or "other windows".
There is also a (free) program called EasyBCD. Download that, read the directions and have at it.
If none of that works, you'll have to do a clean install. Install XP on one drive first, then Vista on the second drive in that order. The Vista bootloader will pick up the XP. However, XP is NOT forward compatible and will not recognize the Vista bootloader. Make sure that you don't have any flashdrives or media cards plugged in before doing the install.
Another approach would be to shrink the Vista volume, creat a new partition, then install Linux Ubuntu that partition. Linux will detect all of the OS's and create a boot menu. Unfortunately, you'll lose about 5 gigs to the Linux OS and it's swap partition, but then, you get to goof around with Linux :-)
Feb 25, 2009 | Microsoft Windows Vista Home Premium with...
Want to remove Win Vista and install Win XP on two computers
have or can you get a win 95/98 disk...
these disks utilize the dos enviroment...
when you boot with them you can easily get in the dos platform (c://prompt)
once there type in fdisk and follow instructions.
you can also do this from usb ..you need to make usb bootable first.
you may be able to use xp disk and choose repair which will take you to the dos prompt.
you may be able to format hd with vista disk and before it start to install files interrupt it(remove disk)
not advisable though.
if you want program to create bootable usb let me know.
I'll need youre email address to send via attachment.
Jan 25, 2009 | Acer Aspire 3680 Laptop
How to install vista on I-MAC
Hi Harry
yes, vista can be installed on I-macs ...but i need to know which version of operating system do you have (whether it's leopard or tiger and version 10.5.2 or earlier)
I say so because new version of Leopard Operating system has a feature called "boot camp"... this is Apple's "bootloader" ... which means it will help you install windows Vista on Apple I-mac .
If you have genuin vista disk handy with you and after you have backed up all the data on the apple machine , this is what you gotta do....
1. Using the Finder, navigate through Applications, Utilities and run Boot Camp Assistant.
2. Click Continue on the Introduction screen.
3. Next, you will need to specify how you want your hard drive divided up for Windows. A separate partition will be created that Windows will use. Drag the divider to adjust the size for Windows as shown below. I recommend at least 15 GB to allow for the OS and some apps. When you are ready, click Partition and your disk will be prepared.
4. It is time to start the Windows installation. Insert your Windows Vista install DVD and click Start Installation. Your Mac will automatically reboot and boot to the install DVD.
5. Install Windows Vista as you would normally do. When asked where to install, select the partition called BOOTCAMP. You will need for format this partition with NTFS.
6. When Windows Vista has installed, remove the Windows Vista install DVD and insert your OS X 10.5 Leopard install DVD. Run the Boot Camp installer application and all the Windows drivers for your Apple hardware will be automatically installed.
7. When you want to switch to OS X or Windows, just reboot and hold down the Option key to select what partition to boot.
Jun 07, 2008 | Computers & Internet
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
