Question about HP Office Equipment & Supplies
Photo paper jamb but not standard paper - HP Office Equipment & Supplies
  • 2009beatle Nov 19, 2008
    Thank you, this paper is 69lbs, will try lighter weight.
    Scholar:
  • 78 Answers
What printer, what is the paper weight. Is the paper recommended for use with your specific printer? You can typically find your printer specs on the manufacturers website. Paper above 60 # may have problems with 180 degree bends in a lightweight inkjet printer.
Posted on Nov 19, 2008
Canon pixma mp495 rear tray rollers only pulls paper in on one side then it jams
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Canon PIXMA MP495 Wireless Photo...
Photo paper jams
Feed only one sheet at a time and select the paper type properly in the menu. HP are notorious for paper jambs with thick paper because the paper path folds back on itself when using front loading trays. If the printer has a rear paper feed capability, use it to make the paper path straight. EPSONs do not jamb as much, but the ink is far more expensive. Reading the on-line instructional manual from the web-site may provide a paper settings solution and calling HP's toll-free number may help too.
Aug 27, 2012 | HP Deskjet 5400 Series
How to load photo paper in paper tray canon mg5220
For front or front tray loading printers, shiny side down... for rear/back loading printers.., shiny side up. Pictures should be visible coming out of the exit slot. Using pre-cut photo paper requires some technique, if the paper holder does not have an adjustable paper width feature. Feed paper in one sheet at a time to prevent jambs.
Aug 27, 2012 | Canon Pixma MG5220 InkJet Printer
I cant get the paper to feed without jaming is ther a way to adjust the feed
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Nov 03, 2011 | Canon Pixma iP2600 Photo InkJet Printer
When I hit print when the paper starts to feed the pushbar paper feed does so fast causing the paper to start slightly off caqusing a paper jam.. Is there anyway to adjust the feed
Nov 03, 2011 | Canon Pixma iP2600 InkJet Photo Printer
It seems my F2180 can not print photo paper. Are they too thick? I get paper jam all the time. Regards Loyd
Photo paper usually needs to be loaded SINGLE SHEET, or it will jamb, and this is commonly stated on the packaging of the paper...Just load single sheets, and no more problem.
Aug 28, 2011 | HP Deskjet F2180 All-In-One InkJet Printer
Hello i have a canon mp250 printer and when i put paper in it i takes it at an angle and says paper jam what could the problem be and how can i fix it
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Jul 15, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Printer will not print.a photo paper went thru on a angle. now it will not print.
A paper jamb could be caused by dirty orsticky rollers, also failure to remove all traces of paper from a previouspaper jamb.
May 28, 2011 | HP PSC 1315 All-In-One InkJet Printer
Photo Paper keeps jamming
It's the top rollers, the paper is too slick to get through them. I'm using HP photo paper, in an HP printer. It needs to do a 180, but gets jammed right where it prints, so the paper never makes it to the ink. It's an engineering problem by HP. I suggest putting a rough surface on the top edge of the photo paper, something removable but rough enough for the printer to pull the photo paper through.
Jul 12, 2010 | HP Officejet 6310 All-In-One InkJet...
Hi, Photo paper loads at start of print job but locks up and paper jamb error comes on. Have loaded 10 or 15 sheets of just photo paper that does not help. I can run standard paper thru and it prints pics...
Is this the first time you have used the heaver paper ? Also is it the same brand? You did not provide the printer model, but you can typically go to the manufacturers site, and check the specs for proper ( Mim / Max ) paper requirements. Above # 60 the paper feed rollers may have worn, and may need to be replaced. If 20 # copy paper works, then this may be the problem.
Nov 19, 2008 | HP Office Equipment & Supplies
56 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
