Thinkpad 390x 2626, won't boot from cd drive
I'm trying to boot a live-CD OS from a cd drive. The live-cd works on another computer and the CD drive works.
The bios was setup to boot first from CD drive, then from floppy, then from hard disk. I checked and found that the current bios is the most recent available for this machine.
Somehow, the computer ignores the bios order and looks for an OS on the hard disk.
It gives a boot error ''operating system not found'' if 1- no hard drive is present 2- an unformatted hard drive is present (detected in the bios).
If I place a formatted hard disk with XP in the computer, it goes straight to the OS, ignoring the boot order in the bios - thus not even attempting to read the cd-rom boot disk.
Any ideas on how to get it to boot from the cd-drive?
Thanks.
  • 1 more comment
  • nic1876 Nov 19, 2008
    Thanks for the F12 suggestion, but I still doesn't boot from the cd-rom.
  • nic1876 Nov 20, 2008
    Thanks again rickyostrom,
    I tried the live bootable USB thumb drive with no success. I tested the USB drive on another laptop and it works perfectly.
    While trying again to boot with the F12 key and an unformatted hard drive, I got the following error messages:
    1- "Error 0210: stuck key 58" - this is probably the F12 key I was pressing.
    2- "Hard disk sector read function failed. Save disk feature is disabled. Run Phdisk for information. File: create new partition. Consult manual. Hit any key to exit." - so it is still trying to read the hard disk, even if in the bios it is last in the boot order and I even disabled it. I guess the Phdisk is a hard disk diagnosis/formatting utility. Also, I can hear that it always checks the floppy disk drive in the boot process, even if it is placed behind the CD-rom in the bios boot order.
    Any other ideas?
  • nic1876 Nov 21, 2008
    I have disabled the hard drive and the floppy in the BIOS with same results - the boot process does 1-floppy 2-hard drive 3-error message, if 1 or 2 don't have an OS.
    Unless you mean something different when you say in the CMOS?
    Thanks again rickyostrom.
    Sergeant:
    Champion:
  • 274 Answers
Try pressing F12 at startup, you should get a boot option.
Posted on Nov 19, 2008
  • 1 more comment
  • Ricky Ostrom
    Ricky Ostrom Nov 19, 2008
    Bummer,
    Have you thoght about making a live bootable USB Thumb Drive.
  • Ricky Ostrom
    Ricky Ostrom Nov 20, 2008
    Have you tried to disable the hard drive in the CMOS, just to see if you can boot off of a CD or USB Device?
  • Ricky Ostrom
    Ricky Ostrom Nov 21, 2008
    I'm not sure how you burned the live-cd, either ISO or Data. But try burning at a low spin factor like 8x with Finalize / Not Multi-session mode.
How to boot with usb flash drive. detailed please, I'm trying to many diff ways nothing working, bios is the only thing on comp.
It is possible to boot from a USB drive....but only if the USB drive has been formatted as bootable, in the same way that OS CDs and DVDs are bootable media. You have to have an operating system either on the hard drive or on the flash drive in order to boot the computer. The BIOS is simply a "Basic Input-Output System" that interfaces the computer hardware to the OS, whatever media it is on. That is why you have to select the boot device and the boot device priority in the BIOS during setup, so it can direct itself to the bootable OS. Once you have installed an OS, then all will work fine. Until then, you will continue to have issues. Normally, with Window-based systems (you don't say what OS you are trying to use), you would insert the bootable Windows setup disk in the CD/DVD drive, ensure the BIOS was set to boot to CD/DVD first, and start the computer. The windows setup file would load itself and start the OS install process. It may even be necessary to partition and format the hard drive during this evolution, but the setup program would lead you through that as well. I have seen Windows setup files loaded to USB sticks, but they require a special process to generate so the BIOS sees the USB as bootable.
Jun 26, 2015 | ASUS Computers & Internet
My computer motherboard was Intel desktop board D865GSA i am trying to format and install Windows XP but it did'nt Ask like Press Any Key Boot From Cd... I Have also set in setup as boot from cd d
If you are sure about changing in your BIOS CD or DVD as your First boot device then there might be chances that your Drive is not doing its job, you can try with other drive if you can manage it from your friend side. Second thing is that your OS cd is not a bootable Cd or DVD. you can give a try of your OS CD in other PC.
Aug 17, 2012 | Computers & Internet
Boots only to bios settings, then blank screen after save and exit. will not take a cd boot.
Hello, since it can boot to bios setting, then have you try configuring the boot order,the cd drive should come first,after that your hard disc, if the hard drive comes before the cd rom then it would not recognise it. Change the settings and Save this settings, then try to boot from the cd again, if this does not work then i am rest assured that your hard drive has a problem,and you need to find solution to it by getting a new one. cheers Regards
Dec 01, 2010 | Acer Aspire One Netbook 8.9" Notebook
Hello, I have a problem with: Machine is HP netserver E800 Runs MS W2k SBS. Hardware ? single PIII 933, board supports second processor IDE onboard controller with CD Problem booting up....
why not ask HP this. and not on the chat forums here,
this is NOT HP. not in the very least.
F2 sounds me , its the command to reload the OS.
did you lose the manuals on this server?
it tells you what F2 means, id be there in a heart beat at hP
in fact id down load all books on it now, because soon or now
there will be no PIII books at all, its a relic, pentium 3.
Can you boot to say a linux live CD.
or a window PE live cd?
your server will not boot to USB so, that out. (modern ways)
if yes your OS is dead, or HDD dead.
reload the OS. now. try that using the books for this server.
is it RAID? or one IDE disk.?
what does CD problem mean
why not tell the helper why is a CD in your hand
and how made it and if and OS install who's , HP or microsoft
we can not guess what you are attempting with CD in hand.
if the CD will not boot 3 disks,
1: yours.
2: linux live
3: windows live.
then the CD drive is dead, or you need DVD drive.
the newer OS needs a DVD drive, for sure.
i think (omg long ago) windows 2000 is on 800mb CD.
to boot CD you must tell BIOS to boot there first. force it.
true on all PCs and now impossible (near) with W10 and UEFI and secure boot enabled, (said or watchers looking here)
get a test CD with LINUX and test the boot.
this proves it can boot and BIOS is using it.
POST - memory count
power on self test or POST??????????????????
is this a BSOD , blue screen of ***** off a new CD from HP?
if yes the CD drive is DEAD< end of life gone and now reads corrupted data, as most do this old, buy a new CD drive.
now.
this BSOD if is, can be seen on 1000000 of posts (messages about POST, LOL where the guy doing it, used CD-r disk that are pure JUNK> or a burner old that is trashed.
please post here X your P.O.S.T screen,. I always wanted to say that.
there you go.
May 25, 2017 | HP NetServer E800
Dell Computer- Cannot find Cd-drive
Are you getting an error message saying "CD drive cannot be found"? If so, check the cable connected to your pc or swap that drive with a working cd drive.
Afterward, you have to enter the BIOS and change the BOOT order. Make the CD drive the first boot device and the HDD your second boot device. If the CD is a valid BOOTABLE Windows OS CD you will see the following option directly after the bios loads: "Press any key to boot from cd...."
Please remember that the OS CD only has the Windows Operating Software and will not provide you with the necessary drivers to run all the hardware on your PC. If it is not the original OS cd that came with your system don't even bother as you will have activate windows within 30 days and may not even allow you to enter the OS once installed until windows is activated.
The green or purple Dell CD's will boot on that system with no problem and it will not even ask you for the keys as it is a Dell OEM Windows OS CD. If you try an official Windows XP OS CD you must have the keys for it.
Jun 06, 2009 | Dell Precision 380n (380TNMIN) PC Desktop
Boot problem
open your bios setup and check the cd rom is recognized and check the boot priority is set to allow to boot from the cd rom first.
Feb 20, 2009 | Dell Computers & Internet
Aspire 9500 doesn't start - cursor and drive indicator blinks
Generally the bios setting will be set to check the primary Hard disk for the Operating system and then move to the CD/DVD drive . It looks like your system is not finding the hard disk. Thats why its moving on the CD drive and trying to read it.
Possible issues :
1) Hard Drive crash
Solution : Nothing much. You need to replace the hard drive and reinstall the OS.
2) Hard Drive connection issue.
Solution : Open the chasi and try to figure out if the hard disc is properly connected.
3) Corrupted OS or boot file
Solution : Try to repair the OS use the OS cd and run the repair option.
4) Bios setting to treat CD drive as the primary media.
Solution : Use the F10 option in the Bios to change the primary Media.
Rate the Solution accordingly...
Feb 07, 2009 | Acer Aspire 9500 Notebook
Building new computer with ASUS M2A motherboard and AMD 749 processor. Computer starts, displays ASUS setup screen, goes to blank screen with blinking cursor and then hangs up.
Try to check connections to hard drive...If OK..then check boot device priority in BIOS and change 1st boot device as Hard drive..Then If not worked then chnage 1st boot device as cd rom and boot from a bootable CD and installl OS..
Dec 09, 2008 | Computers & Internet
Hello i have installed AVG anti virus n it makes my pc system crash!!!!!!! Just i tried to format my pc but failed it says missing operating system and no longer boot. I assured my BIOS and set Boot CD but...
It sounds like your pc is trying to boot from the formatted hard drive. Go into your BIOS and make sure both the hard drive and CD drive are detected. Make sure your CD drive is set as the first boot drive and disable all other drives for booting.
Nov 30, 2008 | Computers & Internet
OS installation.
is the old hard drive still working if it is you can clone the two
Jan 20, 2008 | Dell Latitude C640 Notebook
Computers & Internet Logo
1,126 people viewed this question
Alun Cox
David Payne
David Payne
