Question about HP Officejet Pro L7680 All-In-One Printer
HP L7680 print head problem
I keep getting the error 'Printhead(s) Problem
The following printhead has a problem: Black / Yellow '
When I run the helps to clean the printhead, or align or check the status/health, everything comes back with a GOOD status. WHat else is wrong? and how do you get rid of the eror message? I can't even turn it off now? I have the same problem wirh my HP L7580 AIO==wont show black/yellow ink as refilled. Entire machine wont work. I f I return it (Still under warrantry----I will not get another HP anything.
    Sergeant:
    Champion:
  • 283 Answers
Uninstall the driver of the printer then install it back again. Hope this will fix your printer. Please dont rate me if not satisfied..Thank you...
Posted on Nov 19, 2008
  • HP Master
  • 685 Answers
Unplug it for a little bit then plug it back in see if that resets the error message. with the other one try taking out the ink and replacing it.you can also unplug that one and try plugging it back in to see if that helps.
    Master:
    Sergeant:
  • 461 Answers
Try reset your printer
1. turn off the main power supply
2. remove/unplug the power cable.
3. leave it for about 10 minutes
4. turn it back on again
I am getting message "the
More black/yellow print head failure we observed in this series, no remidy for this issue replace the print head..
Sep 23, 2011 | HP Officejet Pro L7680 All-In-One Printer
I bought and replaced the black and yellow printhead today. It printed some colored pages. Then when I began to print this evening a colored page. It stopped in the middle of printing and the printer...
please take your print head and get it tested or get it replaced, or you could take your printer to a local HP service centre and get it checked, rather than trying to fix it yourself you mite damage the sensors for the print head.
Sep 13, 2011 | HP Officejet Pro L7680 All-In-One Printer
My out of warranty l7680 will not print or photocopy in colour. Printhead status says Refilled supply Detected in printhead Black No/Yellow Yes Magenta Yes/Cyan Yes Detected in Printer Black No/Yellow Yes...
The error states that you are using non-HP cartridges for all colours. If black prints fine then you should replace the colour cartridges with genuine HP colour carts. You should be able to get a refund on the refills since they clearly do not work as intended.
May 25, 2010 | HP Officejet Pro L7680 All-In-One Printer
Printhead Problem:
Have you tried to replace the black/yellow printhead? This is not the same as the ink cartridges, but it is located in the compartment under and to the right of the scanner lid.
Here is HP's link.
Mar 19, 2010 | HP Officejet Pro L7680 All-In-One Printer
L7680 has been printing perfectly - printed
Yes, you can pop the cover on the right over where the printhead parks, and remove the black/yellow printhead and soak it in about a 1/4 inch deep water for 30 mins or so, you only want the nozzle area on the bottom in the water. However if you are using generic inks it may report a printhead failure soon. After soaking you dab the bottom on a paper towel and look for a solid black line on the towel.
Jan 10, 2010 | HP Officejet Pro L7680 All-In-One Printer
HP L7680 won't print black, cartridge is new, says it is full, Self diagnostic page says printhead is good
Try printing a Diagnostic page or clean cartridge. Looks like the printheads might be clogged due to low usage or general wear and tear, they may not be working as desired.
Oct 26, 2009 | HP Officejet Pro L7680 All-In-One Printer
Error message on the screen is following print heads have a problem Black/Yellow
follow the document
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01446637&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=2512009&lang=en
this is the best document that we can follow
other wise if your printer is in warranty call hp they will replace the printhead or the printer
Oct 20, 2009 | HP Officejet Pro L7680 All-In-One Printer
Unfortunately it's highly likely that your black printhead is clogged due to the conditions you are using the printer in (ie: warm, dry, air-conditioned?).
I get this a lot in hot offices and school classrooms.
The only solution I've found that works long term is to use a dyebase black ink instead of the pigment ink that HP provide but this obviously means you would have to source a 3rd party ink supplier with ink of this type.
In the mean time a shorter term solution is to purchase a new black/yellow printhead and follow the process for changing the printhead for this new one.
Hope that helps.
Martin
May 18, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP officejet pro l7680 all in one
Most likely the print head has failed and the black is not printing which is causing the printer to have issues. Talk to HP as I guess printheads have warranty or simply change the yellow/black printhead. Or if all of these fail give the machine to HP to get you a new one as this is not right. I hope this helps.
Nov 18, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
123 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
