Question about Hitachi 53UDX10B 53" Rear Projection Television
Convergence problem How do you manually adjust the red blue and green? I see people saying that they can move the red horizontal and vertical. Is there a adjustment capability or do you do this via the remote
    Genius:
  • 1,139 Answers
Hello llamacrew,
The answer is yes you can do it manually, but you don't have the time to do it that way (12 hours), and that is 12 hours if you know what you are doing and have done it before. I would suggest that you do it by using the remote and going to the menu that allows you to adjust convergence.
I hope this helps,
Thank you,
Shuttle83
Posted on Nov 22, 2008
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
    To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
    To process and save the adjustment made, follow the steps below;
    1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
    2. Enter the menu on your TV. Use the remote control and bring up the menu.
    3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    5. Press "Enter." A crosshair pattern will appear on your screen.
    6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    9. Repeat these steps for all colors.
    Take care
    Jul 06, 2010 | Televison & Video
    How do you set convergence
    What is your Make and Model number?
    Mar 18, 2010 | Televison & Video
    Where are the convergence chips located on my 60PP9202 for the red
    There are 2 Convergence Chips: 1 for Horizontal (it includes Red, Green and Blue Convergence channels) and 1 for Vertical (it includes Red, Green and Blue Convergence channels). Horizontal Convergence Chip is 7044 and Vertical convergence Chip is 7045 (both STK392-120). They are fixed in same "big" Heat Sink, with a 2 metal black clips, from Video Inputs board side.
    Oct 19, 2009 | Philips 60PP9202 60" Rear Projection...
    Remote will not adjust red convergence/multi-point horizontally
    check resistors around convergence i.c.(red) philips may use 2 resistors in parallell. should be about 1.8 ohms. assuming you already changed the i.c.
    Jan 17, 2009 | Philips 55PP9352 55" Projection Television
    Can't control red convergence on VS-45607
    The STKs are three channel ICs they each control horizontal and vertical of one color the third channel controls part of green and the other half of green is controled by the other ICs third channel. Its customary for the Ics to fail and only have one channel bad in the IC. However its recomended to change both because of the bad Ic having green it can actually weaken the other IC and that one will fail shortly.
    Aug 03, 2008 | Mitsubishi VS-45607 45" Rear Projection...
    Toshiba 65H81 convergence issue
    Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
    Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
    How to adjust the green convergence?
    Hi, If the green crosshatch lines are bent or curved then you have an IC failure, Green is the reference so it can`t be adjusted with your remote, the correct procedure is to move the red and blue on top of the green to make the crosshatch white, As I said if the green horizontal or vertical lines are not perfectly straight then it needs repair not adjustment, BMW Rider
    Dec 12, 2007 | Samsung HCM4215W 42" Rear Projection...
    Convergence
    you can replace IC stk 392-110 (one or all) and tray to adjust R_G_B
    Nov 25, 2007 | Toshiba 43H71 43" Rear Projection...
    Hitachi 53UDX10B 53" Rear Projection Television Logo
    42 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
