Question about Turbo Air 49 cu. ft. / 1388 liter Commercial Freezer MSF-49NM
Set tempature on minus 5 unit doen't shot down runs all the time.
It sounds to me very likely that your thermostat isn't functioning properly. change the settings and wait to see if it responds. If the thermostat is working it should shut down the compressor when you increase (rise) the temperature and aversly start it when you drop the temperature. Always let the unit sit for 3 minutes for the pressure inside to equalize before restarting. Good Luck
Posted on Dec 13, 2008
Chest freezer suddenly stops working then will start again later
This is normal if your freezer is in good working condition. If your compressor runs constantly then there is a problem. Once the unit reaches the set temperature the compressor shuts down. The set temperature should be between -2 & +2 degree F. The set temperature also depends on how full the freezer is. There will be a time when the freezer like refrigerators will shut down. This is relative to the term, "Frost Free". The unit will shut down for about 10 minutes. This occurs ever 8-10 hours. The heater turns on to defrost your freezer coil. It sounds like you are in good shape.
Apr 18, 2014 | Westinghouse Freezers
I have a kenmore upright frost free freezer mod #253.26432100. A couple of months ago everything defrosted and the unit was not running at all. I unplugged it cleaned it and plugged it back in, it turned...
You have a problem with the ADC.
Frigidaire has also jumped into the market with an adaptive defrost board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. "d" and "F" will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Nov 23, 2010 | Frigidaire 20.3 cu. ft. / 575 liter...
There has got to be a way to change the factory preset freezer temperature on a Delfield 6000 series MCII to operate at refrigerator tempatures. Does anyone know how I can change the factory preset...
Do you mean to go up to +36 degrees? If so, it just won't work correctly. The refrigerant is the wrong one to run at 36 degrees. The pressure on the "low" side of the compressor is so low that the compressor will starve for freon if you tried to change the thermostat to "warm" it up to +36. Also the defrost cycle would have to be disabled or it would jump to 50 or 60 degrees 4 times a day. It also has the wrong cap tube for that temperature. It could be done with a very expensive condensing unit changeout. Over the years I have seen a lot of people try it and nobody that I know have been succesful at it. It may be easier to find someone who wants to trade. After all a freezer is worth more dollars than a cooler. Good luck.
Oct 07, 2010 | Delfield 113.28 cu. ft. Commercial Freezer...
Unit runs continually with gurgling sounds
defrost fully once a year or more if you notice it frosting should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
Feb 17, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
Your defrost timer, switch or circuit board is probably shot or it would be defrosting.
Use a fridge / freezer thermometer to tell if temperture high (it should be 0 F plus or minus 5 degrees) to determine if it is too high - this is normal if frost builds up but will get worse unless repaired.
May 04, 2009 | Hoover Freezers
Running High @ -10 C and should run at -20 C on coldest setting
1. Make sure the sealing gasket is making good contact all the way around. It's pretty easy to lose 10 degrees. If it is a magnetic seal on the door gasket, it may not be sealing all the way around.
2. If it is staying that cold, everything is working well enough. Maybe you need a little gas in the compressor. Time for the service guy.
By the way, is your unit speced to be that cold full of supplies? Is the door opened frequently? minus 35 is pretty cold.
Mar 11, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Fridge Freezer very noisy!
cycling every 30 mins is normal. bear in mind that frost free are more noisy as there are fans running as well.
you appear to have temp in freezer too high - should be -18degC
Oct 11, 2008 | Freezers
Turbo Air 49 cu. ft. / 1388 liter Commercial Freezer MSF-49NM Logo
91 people viewed this question
Top Turbo Air Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Turbo Air Freezer Expert? Answer questions, earn points and help others
