Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Printer not recongnized via USB port
My X7170 does not work via the usb port on the 7170, It was previously working on both desktop and laptop PC's that I have
  • cedrlr Nov 20, 2008
    I uninstalled the software and downloaded driver from lexmark, when it tells you to connect priner cable to usb port, it says the device is unrecongnizable and has malfunctioned.
  • pdad49 Jan 05, 2009
    wHEN i TRY TO PRINT. mY COMPUTER TELLS ME IT CAN NOT COMMUNICATE WITH PRINTER. I un installed port but can't re install it.
    Sergeant:
  • 276 Answers
Drivers, Software, lost C.D....come this way!
If you have lost you cd or don't know how to install your printer then all you need to do is download the drivers and software from the manufactures website that suits your operating system and printer.
Drivers and software download areas for brands listed below, just click to gain access and then locate driver for your needs.
Posted on Nov 19, 2008
  • smarttech Nov 19, 2008
    Brother Epson Sharp Canon Lexmark OKI Dell HP Kyocera Samsung Konica/Minolta Xerox Panasonic
    PLEASE NOTE
    When installing drivers/software it is generally a good practice to -
    · Delete old/previous installs
    · Leave printers USB cable disconnected from computer until newly installed software requests it to be connected.
Cannot print says printer offline
try different usb port, try different usb device to see if port is working try different cable.
Apr 16, 2014 | Apple iMac Blueberry Mac Desktop
I have a Dell Dim 2400 and no connection with HP Deskjet 3070A.
Charles, has this combination worked previously, have you been able to print from your Dell Dimension 2400 to your HP Deskjet 3070A successfully?
If the answer to the above is Yes, then if you believe that the printer is still working correctly and you can test this with a different computer able to print to it, you should consider uninstalling and re-installing the HP software and device drivers for this printer.
If you have not printed to this printer successfully previously, have you tested the printer with a different computer and proven it is still working fine?
If the printer works fine to a different computer then providing you are using the same USB cable to connect to your Dell 2400, the problem needs to be narrowed down further.
Check that you can plus other USB devices into the port on the Dell used for the HP printer - if these work, then your USB port is good - if not, try another port if you have one.
If your USB hardware is good, then again you are left with the need to uninstall and re-install the HP software and device drivers - it may be worth trying to download the latest version of such software if available. HP tend to update their All-in-One software on a regular basis.
Dec 30, 2011 | Dell Dimension 2400 (24006YYVP31) PC...
Printer connected to a Asus router RT-n56u via usb port System with Windows 7 Ultimate 64Bit Usb port enable through Asus Printer Utility Driver select (auto) during installation SAMSUNG UNIVERSAL PRINT...
I'm having the same issue with the same router and printer (mine is CLP-300/XXA).
At first when I try t print a pdf file or an image or any text/word document file with pictures/images I get an SPL-C error.
I have upgraded the firmware and it worked great on my laptop! Then, I tried to install the printer driver on my desktop, but now none of them work correctly.
Still not solved, but here are some suggestions:
1. Try to upgrade the firmware. 2. Try to install the original samsung printer driver 3.0.1
3. If it didn't work try to install the updated driver 3.0.4 4. If it didn't work try to install the Universal Printer Driver
5. IMPORTANT: between uninstalling and installing driver, disconnect both printer and router A/C power adapter and try to reboot you PC after removing the previous driver!
I'm going to work on it and see if it works. The DD-WRT firmware solved the exact same problem on my previous RT-N13U router, but unfortunately DD-WRT doesn't support RT-N56U yet!
Note: I called ASUS and they told me that Samsung printers are not supported for printer sharing server :(
Jun 19, 2011 | Office Equipment & Supplies
We have a Lexmark 7170 printer. We have had no issues with it up until last week when it stopped printing. When you try to print it says printing but nothing happens or else it will say Communication...
Hi there, I have a solution for you. Unplug the printer/scanner for 30min. then plug it back in again.
This will reset all functions. The usb cable was good to start with, you didn't have to replace it..
When you run a print over another print it will jam up memory in printer. Clear all print jobs and you will be good to go.
Jun 08, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have a citizen prolaser 6000 laser printer, it emulates HP Laserjet 3, I want to connect it to my laptop via a usb interface cable, currently it is connected to the printer port of a desktop (lpt1 for...
There is three things that you will need:
Proper port set up on laptop device manager (Check settings) LPT1 is for a parallel port - Need USB Correct Driver for the Citizen 6000 Pro Laser (Windows should auto install) Hub that will communicate via USB to the IEEE 1284 Printer via cable.
Driver Site: http://www.driverfiles.net/Printers/Citizen/Prolaser-6000-Printer-Driver/download/page,sh,38839,389,12,.html
I hate to suggest, but you may have to call Microsoft Citizen Tech Support for suggestions on the Hub that will communicate via USB properly. Check your manual for setup options.
TF
Jun 02, 2011 | Office Equipment & Supplies
None of my USB ports on my p2210 monitor are working How do I fix. Thanks
be sure that you connect usb cable between pc usb port and monitor usb port and try its usb
good luck sir
Apr 01, 2011 | Dell P2210 Monitor
Have a Samsung desktop - how do I attach printer cable?
It really depends on the specific printer interface you have!
Newer printers can be attached to a Desktop or Notebook via the USB interface (small connector as for mouse).
Older printers, and 'commerciall' high speed printers, have a 'parallel' printer interface (large connector - LPT port) that will connect to a desktop (or higher end laptop) with a parallel (LPT) printer port. If you need a LPT connection, a USB to LPT converter can be used ... but a newer USB connected printer may be a cheaper alternative in this case!
Hope it helps let me know how you go.
Dec 13, 2010 | Samsung NC10-14GW Notebook
Lost cd for laserjet 1320 cl6 printer. installed
either the usb wire is getting loose in the new laptop port.or the port is faulty.press the usb wire tightly and then try printing keeping it pressed at the laptop side and printer side too.with some bodies help. check out.
Jul 12, 2009 | HP LaserJet 1320 Printer
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
88 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
