Question about Acme 5001 Supreme Juicerator Juice Extractor
Acme 5001 need a stem that holds the horizontal cutting blade in place. can you recommend any solutions. I am very visual and need to see the  repacement part
  • JOHN REILLY May 11, 2010
    ARE YOU TALKING ABOUT THE CLUTCH NUT OR THE THREADED MOTOR SHAFT THAT IT SCREWS ONTO? NUT IS AVLB. ON LINE FOR ABOUT 12 BUCKS.
    Champion:
  • 356 Answers
IF IT'S THE CLUTCH NUT YOU ARE TALKING
ABOUT, WARING- AT 800 492 7464-HAS IT.
Posted on Jul 02, 2009
Opening lid to add fruits
The Manual for the Acme 5001 Supreme Juicerator can be downloaded from the following link:
http://www.everythingkitchens.com/PDFfiles/6001.pdf
Items to be juiced must be cut to size and fed through the feed chute. The machine will not operate if the cover is not properly in place.
Jul 23, 2012 | Acme 5001 Supreme Juicerator Juice...
Excessive vibration and rattling when I have less than a cup of juice extracted.
I've had an Acme for 21 years and I don't care
what anyone tells you-they vibrate. After years
of trial and error I found mine vibrates less with
a worn blade that I sharpen with a drill. With
a new shredder blade you actually have to file
down the cutting burrs about one third and
adjust the blade to chute gap by unlocking
the adjusting screw on the center of the bottom,
turn it clockwise until blade contacts chute, and
back it off a half turn. Apparently with a slightly
duller blade, smaller gap, the produce goes through
more slowly and evenly. Also severe vibration will
cause the blade to jump up and chip the chute.
Dec 24, 2010 | Acme 5001 Supreme Juicerator Juice...
I'm missing the nuts that holds the blade in place.
Call waring at 1 800 492 7464 and ask for a new
clutch nut.
Aug 28, 2010 | Acme 5001 Supreme Juicerator Juice...
Parts, the blade
BLADE IS AVAILABLE ON LINE. BELIEVE
YOU CAN USE EITHER ACME ($30) OR
OMEGA ($20)
Dec 24, 2008 | Acme 5001 Supreme Juicerator Juice...
Acme juicer
There should be a lug nut in the center that loosens so you can take the blade, basket & outer basket out to clean.
Jul 26, 2008 | Acme 5001 Supreme Juicerator Juice...
Cleaning
http://www.smallappliance.com/product.asp?pid=9879&cur=USD&sid=18956&mid=34&gid=18975&prdCls=P&shopBy=Category
Jul 12, 2008 | Acme 5001 Supreme Juicerator Juice...
Acme Supreme Juicerator 6001 Model # 11JE21
REMOVE THE COVER BY ROTATING AND
THE CLUTCH NUT HOLDING DOWN THE
CUTTING BLADE. EVERYTHING LIFTS OFF.
CLEAN ALL DISCOLORED PARTS BY FIRST
BOILING IN A SOLUTION OF OXI CLEAN AND
WATER, THEN SCRUB WITH A SAFE
ABRASIVE SPONGE. SHE WILL SHINE UP
NICE.
Feb 14, 2008 | Acme 5001 Supreme Juicerator Juice...
Acme Juicer
Are both of the metal parts that you twist the top onto still sturdy? One of mine is broken, and I have to find a replacement part.
Jan 18, 2008 | Acme 5001 Supreme Juicerator Juice...
Screw that holds down the blade in cwnter
try here, not sure if it's listed or not though: http://www.healthnutalternatives.com/acme5001.htm
Sep 02, 2007 | Acme 5001 Supreme Juicerator Juice...
Acme 5001 Supreme Juicerator Juice Extractor Logo
137 people viewed this question
Top Acme Juicers Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you an Acme Juicer Expert? Answer questions, earn points and help others
