Question about HP Office Equipment & Supplies
Hi, Photo paper loads at start of print job but locks up and paper jamb error comes on. Have loaded 10 or 15 sheets of just photo paper that does not help. I can run standard paper thru and it prints pics fine. Is there a max on photo paper weight? this is rated at 69 lbs. Thank you Donnie
    Scholar:
  • 78 Answers
Is this the first time you have used the heaver paper ? Also is it the same brand? You did not provide the printer model, but you can typically go to the manufacturers site, and check the specs for proper ( Mim / Max ) paper requirements. Above # 60 the paper feed rollers may have worn, and may need to be replaced. If 20 # copy paper works, then this may be the problem.
Posted on Nov 19, 2008
How to load photo paper in paper tray canon mg5220
For front or front tray loading printers, shiny side down... for rear/back loading printers.., shiny side up. Pictures should be visible coming out of the exit slot. Using pre-cut photo paper requires some technique, if the paper holder does not have an adjustable paper width feature. Feed paper in one sheet at a time to prevent jambs.
Aug 27, 2012 | Canon Pixma MG5220 InkJet Printer
Feeding problem
give one paper and check if it accepts correctly
Oct 05, 2008 | Epson Stylus 1400 InkJet Photo Printer
It seems my F2180 can not print photo paper. Are they too thick? I get paper jam all the time. Regards Loyd
Photo paper usually needs to be loaded SINGLE SHEET, or it will jamb, and this is commonly stated on the packaging of the paper...Just load single sheets, and no more problem.
Aug 28, 2011 | HP Deskjet F2180 All-In-One InkJet Printer
Photo Paper keeps jamming
It's the top rollers, the paper is too slick to get through them. I'm using HP photo paper, in an HP printer. It needs to do a 180, but gets jammed right where it prints, so the paper never makes it to the ink. It's an engineering problem by HP. I suggest putting a rough surface on the top edge of the photo paper, something removable but rough enough for the printer to pull the photo paper through.
Jul 12, 2010 | HP Officejet 6310 All-In-One InkJet...
Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Feb 09, 2010 | Epson Office Equipment & Supplies
My kodak easyshare5300 is printing black picture
Hi-
If your product is still within the warranty period from KOdak then you can call them up for some step by step troubleshooting to help you with your problem and as well they can replace the printer if defective.
Try this first
Calibrate your printer, then print a demo sheet.
  1. If paper is in the photo paper tray, remove it.
  2. Load photo paper into the photo tray.
    1. Fan the paper to keep the sheets from sticking together. IMPORTANT: Do not overload the photo tray.
    2. Load a maximum of 20 sheets into the photo tray, with the Kodak logo facing up.
  3. Calibrate your printer.
    1. Press Menu.
    2. Select Calibrate Printer, then press Start.
    3. Wait for your printer to print the calibration sheet.
    4. Place the calibration sheet face down on the scanner glass.
      • For the 5300 AiO printer, place the sheet on the front right corner of the scanner glass.
      • For the 5500 AiO printer, place the sheet on the left rear corner of the scanner glass.
    5. Press Start.
    6. Wait until "Calibration complete. Remove calibration page from scanner glass. Press OK to continue." appears on the LCD display.
    7. Remove the calibration sheet from the scanner glass, then press OK.
  4. Print a demo sheet.
    1. Disengage the photo tray by sliding it towards you until it stops. When the photo tray is disengaged, the main tray is active.
    2. Select Print Demo Page, then press Start.
    3. Wait for the demo sheet to print.
Then call them if issue Persist at these numbers:
In the U.S. and Canada: 1-800-421-6699
In Australia and New Zealand: 1800 793 895
Thanks for using Fixya!
Jun 21, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Epson R300
Make sure the photo paper is not curling when it goes in. I had same problem before, with paper jam error even though the photo paper did not appear jammed. I noticed the photo paper was slightly curled, so I flattened it out and that solved my problem. Also, if you are loading multiple sheets at one time, try just loading one sheet and see if that fixes it.
May 11, 2008 | Epson Stylus Photo R300 InkJet Printer
Photo paper loading
is this still current issue?
Apr 15, 2008 | Canon PIXMA iP1600 Printer
Epson R340 not loading ultra premium glossy photo paper correctly
I have several Epson printers and it would seem this is common, I am on my fourth replacement printer, Epson keeps shipping them.
Mar 08, 2008 | Epson Stylus Photo R340 InkJet Printer
Paper won't load
first this to do is turn it off unplug, take paper tray out and remove paper and clean the tray, take the printer and put it on it's side (the side where the paper tray goes and see if you get any paper dust to come out. other wise blow air into that area you will see a roller on top need to clean that.
Feb 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
51 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
