Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
High pitched noise
I just bought a barely used rca 52 inch rear projection d52w23 after it has been on a few minutes it starts to emit an extremely annoying high pitched noise.....I read a few posts that it might be the video input...after swithching those from component to s video to rca plugs it changes slightly and goes away when it is completely unplugged from the video but comes back when plugged back in by any video source have not tried hdmi yet please help
  • 1 more comment
  • Anonymous Dec 06, 2008
    I have a 52 inch RCA Rear Projection TV as well. Whenever I turn on mine it makes the high pitched noise too. The first time I noticed it was no more than 6months ago. I haven't done anything to fix it except ask others about it for ideas. It goes away after a minute or two everytime and doesn't come back until its shut off for a while and restarted so I wasn't extremely worried at first. It does vary in volume and pitch and yesterday was worse than its been in some time. I am concerned with trying to fix it somehow because I'm not set to buying another big screen TV at this time. I've been told it might be to do with loose solder points on the high voltage flyback or something, nothing to do with video. Having issues now with adjusting picture to widescreen or letterbox or to fit screen properly too. I would love to know the fix for this so I can keep it for a while longer. Getting closer to Christmas and i have many others to worry about before myself. Any help would be very appreciated. Thanks.
  • robcason Jan 28, 2009
    I have found a round black thing near the flyback that when touched stops the whine.... the number on the top of this item is is round about the diameter of a dime or penny and sticks up from the board about 1 inch half is wrapped in wire
  • robcason Jan 29, 2009
    sorry so my last comment said where it is and what it looks like but I forgot to ask what it is and should it be replaced or should I just put something on top of is so it stays quiet?
    Problem Solver:
  • 61 Answers
There may be abreak on the av board . is it doing on cable,dvd another source the front panel jacks sometimes develops breaks sound like you may need a tech look at it
Posted on Nov 22, 2008
  • Mark Hammonds Jan 29, 2009
    the component your are touching is probably the horizontal centering coil the higth pitched sound you are hearing is the flyback you may need to change it you will also want to change your horizontal output. that tv also has caps go bad in the power with the set unplugged check the electrolytic behind the heat sink toward the back put your finger on it se if it is swollen if so change it
My rca tv has a distorted picture and a really high pitched buzzing sound
Problem is in High voltage circuit and likely either the high voltage transformer or a connection right under or around it.
Jun 16, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52 inch RCA HDTV is making a high pitch noise with no pitcure but the tv is on and i can hear sound PLLLEASE HELP!!!
your bulb is going out/ or the balast. and possibly the color boads on the inside as well. to figure out which it is take each one out on by one and turn it on. then try another till you determine which it is
Mar 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
How much would it cost to replace a color tube in a RCA HDTV 32 inches?
The cost of replaceing a tube in a d52w23 is unfortanly high..sorry.. if you can find one the last time i replaced a tube cost about 250 for the tube and labor is extensive it takes a exp tech about 2 hours to replace. Are you sure that the tube is at fault? which tube is it. is this set 32 inches? the d52w23 is 52 inches
Nov 03, 2010 | RCA D52W23 52" HDTV CRT TV
52 in. rca high def. rear proj. making high pitch noise
the set probably has lots of bad solder connection on the flyback and in the horizontal deflection circuit.
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sometimes screams a high pitched noise when turned on
the high pitch noise is from the HV. arcing acrss each other.
( the screen comes up at a pop).
I suggest get a better one. ( sorry! no domastic brand).
Oct 27, 2008 | RCA HD52W56 52" Rear Projection HDTV
My rca 52 inch hdtv turns itself off after a few minutes
Sounds like the green tube shorting intermittantly. Have a qualified tech use a tube restorer to check for shorts, or the loss of the 300v line to the green tube.
Aug 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV making high pitch sound
Hi, There are usually 1 or 2 fans inside the TV's. Could be worn bearings, or fan blade interference. Sorry, without my electric ear working, I can only guess.
Apr 21, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W19 - High Picth sqealing noise
Thats usually a sign of the flyback or HV Splitter nearing the end of their operational lifespan. However its not an exspensive fix unless done ay a repair shop then it can be a few hundred.
Apr 21, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52 in. Rear
open it up and see if any liquid is spilled on the boards, most squeals are from the high voltage transformer and or splitter
Jan 17, 2008 | RCA D52W19 52" Rear Projection Television
High Pitch Noise
there has been a few cases of a coil in the cuircit whinning. and there is a simple fix...applying some silicone onto the coil to dampen it. the coil is ll037 on deflectin board. location m2 a black compnent with coil of copper wire wrap around it. thats my initale thought. it may be more. since you still have a picture.. any questions email me at
Dec 10, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
174 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
