Question about Remington 111409 - 01 6" Branch Wizard Electric Pruning Saw
Pole saw won't start
Used pole saw once several months ago, now it won't start. What am I doing wrong?
  • Anonymous Mar 27, 2014
    Is getting no gas to start
    Sergeant:
  • 359 Answers
Try a small amount of starting fluid in breather and pull small amount
Posted on Dec 03, 2008
I need coupling collar for my remington pole saw
I experienced the same problem with mine. The collar ring split making the pole saw useless. I am one of those who can basically fix anything you can put into my hands......
I have the solution for you! Loosen the collar ring and ensure the matching edges (where it is split) are clean & dry.....(no oil or residue).
Use JB-Weld (available in most department stores, hardware stores and auto suuplies) to repair the collar ring. Use the standard type epoxy (not the fast drying type). You will also need one other item to keep the ring from splitting again. The collar ring has a 2-inch diameter. Go to a hardware store or an auto supply store and ask for a 2-1/2 inch stainless worm clamp. Be sure to get the wider type that is about one-half inch across the stainless band. The clamp is typically used to connect radiator hoses on automotive engines. Make sure the clamp you get is stainless. Unscrew the clamp using safety in mind.....they typically have a large "straight slot" screw; using a screwdriver is a bit dangerous especially if you have to tighten it very tight. If you have access to a nut driver or a small quality socket set, these tools will enable you to tighten the worm clamp very tight. Do not force the collar ring back into service for a few days to ensure that the epoxy has had plenty of time to cure. I repaired mine a few years ago and it still works great!
Please send me a reply once the surgery and recovery is complete.
The total cost for materials is about $9-$10.
I hope this fixes your collar ring for good!
Nov 07, 2013 | Remington Electric Pole Saw
Car won't start. it tries to turn over, but just doesn't .battery replaced several months ago so it's not that. The red "GEN" light pops up. Is that the generator signal? Manual doesn&
Interesting. They haven't used generators in over 50 yrs.
But yes that was the warning light for the generator.
If you have a volt meter that would tell you what the system is doing.
If the engine will not crank, and the battery is fully charged, you would need to check the connections at the starter for voltage and ground.
And the red warning lights would normally come on until the engine starts.
Jan 13, 2013 | 1996 Jeep Cherokee Sport
Electric pole saw was put togeather wrong and can't take pole apart.
check for a small button in the connecting parts of the pole press it in and slip the parts
on reassembly make sure that that button lines up with a hole and clicks in
Sep 16, 2012 | Earthwise 10" Cordless Lithium Pole Saw
Oil is out on the remington pole saw- what brand do I need?
unless the warning tag on the saw says otherwise, use standard bar/chain lube oil which is used on any chainsaw.
Aug 28, 2012 | Remington Electric Pole Saw
Tesco 6 Person Vis-a-Vis Tent Instructions
Whoever they employed to write the instructions should be shot or go back to kindergarten....how difficult can it be?
Anyway, this tent is relatively easy to put up IF you know how to do it...which the instructions are painfully inadequate. It (un)helpfully uses colour coding on black and white print out and not explaining which way around the longer/shorter poles should be. Actually, once the poles are in, the instructions are ok....but it is a major point and wastes a shtload of time.
There are 2 LONG (well, slightly longer) poles, with a yellow sticker on the end (which comes off after 1 use of the tent). Start on one side of the tent with 2 poles (one longer, one shorter). Slide the long pole into the inner rib (ie towards the middle of the tent), then put in the shorter pole on the outside rib (i.e.the furthest away from the middle). You do need some grunt to force these into place, but at least they go (they won't if you put the wrong pole in the wrong slot). Then do the other side of the tent, longer first (inside), shorter second (outside). Then just pin everything else together like the instructions show.
The tent is ok, just ok, not great, not terrible, although it is pretty terrible in the wind, but what do you expect for 60 quid.
Jun 24, 2012 | Sport & Outdoor - Others
Pole chainsaw not working
No power could be a broken wire in the power cord, usually near the plug end. It could also be the switch, or the motor brushes. More rare is a broken wire in the motor or the saw case. Hope this helps!
May 10, 2010 | Remington Electric Pole Saw
I disconnected the saw from the pole, and now I
Bracket fits over saw handle, must push lockout button and install bracket so its keeps the trigger depressed
May 10, 2010 | Remington Polesaw Wizard
I bought a black and decker pole battery saw, used it once and recharged it to use again,it only ran about 10 minutes and the battery went dead, or to low to do any work. Is all the batterys that...
George, firestorm bats. I believe are for the drills ? There is usually a 2 year warranty on B&D products, either take it back to the store where you purchased or contact Black & Decker : blackanddecker.com
Feb 01, 2010 | Garden
IT STARTS BUT DIES AFTER ABOUT 5 SECONDS
what kind of saw is it? and if this is the problem u might have over primed the button on the side thats part of getting the saw started and maby flooded the carb and could be the reason why its hard to get it goin. Doesnt take much to flood a small motor. Oh and almost forgot do u have the right mixure of ur fuel? for my saw its 40:1.
Jun 04, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Remington 111409 - 01 6" Branch Wizard Electric Pruning Saw Logo
306 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
