Question about HP Office Equipment & Supplies
I have a HP Printer C5500 When I try printing something on the CD/DVD Directly I get a Error saying that the printer doesn't support printing directly on the CD while the Printer is meant to print on CD/DVD Directly
  • daniellefilm May 25, 2009
    I have the same problem on my Photosmart C5550. When you go to select
    the "paper source" as a CD/DVD, it's greyed out. I called HP and wrote
    to them for support. Their only suggestion was to reinstall the
    Photosmart software. This didn't work. I'm pretty sure the Photosmart
    software is not compatible with Mac OSX 10.5.x
    Please tell me
    I'm wrong... I'd love to have a solution. My HP is going back to Costco
    in a few days because I bought it to print on DVDs.
    Scholar:
  • 78 Answers
I'm confused.. Are you trying to print to a CD/DVD Drive? Try the print job again, and choose the C5500 as the print device.. Seems that there may be a problem with the print device set-up , and you may have to delete the printer, and reinstall it.
If the printer is designed to print a label on a CD / DVD. then you will have to use the programs provided to accomplish this, as it requires formatting parameters be sent along with the print request. I.E. You can not cut and paste directly to a CD / DVD printer..
Posted on Nov 19, 2008
Xp-800 cd/dvd printing
The tray is for the DVD or CD itself, not for a label. The printer prints directly on the CD or DVD, you must use ink jet compatible blank disks, the white ones with no printing. You don't need a tray to print the label.
Oct 14, 2014 | Epson Expression Premium XP-800...
Avery design pro will not print with my HP C5500
I found an odd workaround. Probably a better one available, but this worked for me. When you select Print from Design Pro, in the printer drop down box select Microsoft XPS Document Writer instead of your printer. Click OK, enter a file name, and save. That will save a .xps file. Next, open the .xps file and print it.
Dec 13, 2009 | HP Photosmart C5580 All-In-One InkJet...
Printing Direct to CD using Roxio EMC10 and HP All in One C5280
Solved by trial and error.
I went through every type of paper and printer combination listed in the Printer Preferences and eventually found a system compatible with Roxio EMC 10.
This by setting "Commercial Paper" and Neato 3-Disc Paper.
Whilst this is probably the incorrect way to do it, it has solved the problem and I can now print directly onto CD via my HP C5280 All in One Printer.
Tip. If you set Print preview before printing you can determine what the finished article will look like without having to wast numerous Discs trying.
Aug 28, 2009 | Roxio Easy CD & DVD Creator 6...
How do I print a label on a cd/dvd
your printer does not support CD label orinting. though you can still print CD labels but with some softwares. there are HP printers that prints CD labels. Check them out.
HP Lightscribe
Use LightScribe technology to label CDs and DVDs.
HP Photosmart D5460, D5463, D5468, and D7560 Printers - Printing Directly onto a Printable CD or DVD in HP Solution Center ...
On a computer running Windows, print directly onto a CD or DVD using the HP Solution Center software.
HP Photosmart Premium C309a, C309c, C309g, and C309n All-in-One Printers - Printing Directly onto a CD or DVD - c01622666
Review steps for printing directly to a CD or DVD.
HP Deskjet 900C series printers - CD Label.
These printers comes with a special software that enables them print on CD labels. Also try to get their softwares and see if you can interface them with your own printer and them print. Else you may have to get one of these printers that support CD labelling. Cheers!
May 19, 2009 | HP OfficeJet 4255 All-In-One InkJet...
CD/DVD Tray open; Close Tray to print
This solution is taken from the HP website.
Follow these steps to print on a CD or DVD.
  1. Make sure that the CD/DVD tray is completely closed (completely inserted into the product).
    NOTE: Make sure that the side of the tray that holds the CD/DVD is inserted into the printer first.
  2. In HP Photosmart Essential, click the Print tab.
  3. Click Printer Settings and then click Advanced to open the printer properties.
  4. In the properties, click the Features tab.
  5. In Paper Type , select Printable CD 120mm .
  6. In Source , select the CD/DVD tray .
  7. Save the settings and then again attempt to print on the CD or DVD.
Feb 05, 2009 | HP Photosmart D5360 InkJet Printer
HP Photosmart C5500 series CD will not install completely
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | HP Photosmart C5580 All-In-One InkJet...
Printing directly onto CD's/DVD's
try and use the watermark setting to put your logo on the print but not in the print
the same as when you see draft, copy on the page under the print
May 24, 2017 | HP Officejet Pro L7680 All-In-One Printer
151 people viewed this question
Seeker5211
Seeker5211
