Question about HP Business Notebook NX9110 Notebook
Keyboard Not responding
My keyboard stoped responding after re-installing WinXp SP2 OS. Morevore the sound of the laptop is very very low. I tried intalling sound drivers the correct the problem but had not result. Model of laptop is HP nx9110. Pls help me solve this problem. Thanks.
    President:
  • 2,961 Answers
Firstly your keyboard and sound driver may need to be re-installed using your original HP installation/driver disc or from the HP web site. http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=395749&lang=en&cc=us&prodTypeId=321957&prodSeriesId=395747&taskId=135 Windows XP has probably loaded generic drivers when installed which are'nt always compatable, especially for assigned keys. Also go to your speaker icon on the right corner of your task bar(right click then properties) and check that the volume cursors are set correctly.
Posted on Dec 11, 2006
Sound is low even with volume at 100%
1.make sure you have the latest driver for your sound card.
2.check speaker connection.
3.check sound mixer in lower right and try to change balance to right and left if one of them corrected the problem so there is a physical problem.
4.if non of them solved your problem try to reinstall your OS or install other versions of OS(ex. WINXP SP2)
May 10, 2010 | Vizio L37 Television
Unresponsive keyboard + mouse pad
I guess you have a mechanical problem, sounds like the mother board have some issues on starting all devices.
If you could use keyboard to go in the bios, and see the screen, if would be the OS that need to be repaired.
Aug 04, 2009 | Acer Aspire 5100 Notebook
My pc keyboard buttons 'T and Y' is malfunctions
I would suggest that you try and remove it again, clean the interface(connector with the laptop) with an eraser, and reconnect it back firmly.
If you cant do it by yourself, your can just get a Technician to do it for you. Although it is very easy.
It might just be a partial contact with the system interface...Good luck!
Hope this helps.
Jul 12, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
Keyboard and mouse unresponsive under Windows. OK with LinSpire
Have u tried uninstalling the keyboard and mouse under the device manager .. then reboot your computer
Mar 30, 2009 | Acer Aspire 3000 Notebook
KB Genuis Luxemate 320 USB can not choice OS in loader's menu.
Try to change in the BIOS the option "Keyboard USB" from value "OS" to "BIOS".
Mar 18, 2009 | Abit NF7-S V2 Motherboard
Laptop Mousepad and Keyboard stuttering, slow
This may be a battery power monitor issue. Try disabling the "Mircosoft ACPI- Compliant Control Method Battery" device. This is located in Control Panel-->System-->Hardware Tab-->Device Manager-->Batteries. Had similar problem with 2 Acer Aspire series laptops (diff models). 2 and 3 year old. Original batteries (both still hold charges for 1.5 hrs of normal usage). Running WinXP, one with SP2 and other had SP3. Both came in the last month with slow jerky TPAD function and nearly non responsive keyboard access. Checked the usual; virus, spyware, hijacking, driver conflict etc. Cloned drive and factory installed..still same problem with kb & mouse. However an external USB keyboard and mouse functioned normally (no lag). Noticed with Battery removed kb & mouse was normal. Finally found disabling ACPI control battery device resolved this issue while allowing laptop to run on either battery or AC.
Jan 30, 2009 | Acer Aspire 1640Z Notebook
Keyboard and mouse not working
try reinstall the chipset driver your laptop/pc this might problem with driver, if still not working maybe cause by hardware failure or os damage files.
*resintall the driver.
*clean install xp
Sep 22, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Laptop
A couple of solutions for this,,,,
First when did you do you SP2 windows updates?
if running XP then you will need SP2 for the devices to function and with the correct informations.
Try this one first and reboot,
restart and test
If not you may have to ....
format this unit and a fresh install will take away all your problems,dont for get the updates for your drivers,
Very staright forward if you got the disk
or a restore from a partition on the recovery image,back up disk?
What OS are you runnig thanks
Jun 24, 2008 | Acer Aspire 3680 Laptop
All needed drivers for WinXp.
The Toshiba website had directions for getting drivers. You will need to provide your model number and follow links to get help. Good luck
Feb 18, 2008 | Toshiba Satellite A135 Notebook
Compaq C733TU audio driver for windows XP sp2
i have compaq 772TUlaptop
i formated my laptop bt now want to download d audio from net
hw to do
Jan 21, 2008 | Compaq Presario 700 470024-192 Notebook
HP Business Notebook NX9110 Notebook Logo
90 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
