Changed hard drive(at a repair shop)to lager laptop is getting hot(on bottom)and shutting off.why?
  • 849 Answers
It might not fixed properly or fan is not running which caused over heating resulting to shutdown. re-examine the laptop and fix every thing properly.
Posted on Nov 19, 2008
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/ for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
My toshiba laptop will shutting down randomly what can I do?
possible hard drive failing or overheating
take it in to a computer repair shop and have it properly diagnosed and a quote
Jun 28, 2016 | Toshiba Computers & Internet
How to replace the hard drive?
While I've not seen this particular model, quite often to change the hard drive in these types laptops requires removal of the bottom. This means closing the laptop (so the screen faces the keyboard), turning it over, removing the screws in the bottom of the laptop and gently removing the bottom cover. If you are not experienced in laptop repair you may want to take it to a professional. Provided the hard drive is a standard SATA (which is what is listed in the specs for this model) the cost would be about $170 at our shop, including parts and labor. Just so you have an idea.
Mar 06, 2014 | Acer Aspire R7-571-53336G52ass 15.6" LED...
The hard drive indicator light of my Dell Inspiron 17 constantly flashes.
The hard drive LED is flashing because the video is data being retrieved from the hard drive. The fan runs high because the video card is working hard and creating a lot of heat. This causes the laptop to shut down.
How to fix
Get more memory.
Get a laptop cooler rest.
Get the dust and junk blown out of the inside of the laptop
Feb 28, 2014 | Dell Computers & Internet
Gateway MX8711 Shuts off while running
I suggest you take your laptop back to the repair shop and tell them you still have the same problem. There should be a warranty covering the repair for a period.
May 20, 2012 | Gateway MX8711 Notebook
On start up my hard drive light flashes red and then my laptop will shut off. Model # dv5-1253cl.
It is possible that your hard drive has malfunctioned and the computer can not use it to boot. Not being able to see the laptop in person, I would recommend taking it to a PC repair shop.
May 26, 2011 | Computers & Internet
I bought a Dell inspiron 400 laptop. I will boot
I would take the hard drive to a computer repair shop and let them scan the HDD and remove the infections. They can also repair the windows installation files so it will boot back up. Either way, you do not have to change out the memory unless you want to install more.
Jan 28, 2010 | Dell Inspiron 4000 Notebook
My Compaq nc6320 was damaged and I think I got cheated on repair
if you remove your current hd you do not lose any memory as far as I know and you can later access it if you have the necessay cables to either connect it to a desktop or laptop..I am 99.9% sure that you can do it for desktops but I can remember seeing anything for laptops..Google and ebay would help to solve this..
Jun 12, 2009 | HP Compaq nc6320 Notebook
Cooling fan not working
if you don't have experience of opening laptop then i'd advice not to do so as i have seen many people carrying half opened laptops in bag to the repair shop.
And then some repair shop take advantage by telling some part missing/screw missing etc. and charge more.
take it to repair shop and ask them to change the fan. it should not cost much.
Jun 01, 2009 | HP Computers & Internet
Computer won't start up
hmm have you tried taking the bottom off and making sure nothing got hot and melted or ruined anything...???
Jan 09, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
David Payne
David Payne
