Can get my cassette adapter for my ipod to work it keeps ejecting the cassette
I also have a '95 ford explorer. Same problem. I took the screws out of the tape and opened up the adapter. I took out all the gears EXCEPT for the one large one in the middle two on either side. Now it works perfectly.
Posted on Apr 23, 2009
Try a different brand of adapter... My '02 Explorer refuses to accept Sony cassette adapters (it ejects the cassette after a minute or two). On the other hand, a cheap Phillips adapter plays flawlessly!
Inside the cassette adapter is a mechanism to apply a certain amount of "tension" to a sensor in the cassette player. If this simulated tension is too great, the cassette player will try switching to "side b" (thinking that it is the end of the tape). On some adapters, this "tension" is so great that the cassette keeps changing from side a to side b. If this occurs too often, the cassette will be ejected!
Posted on Apr 04, 2009
    Problem Solver:
  • 8 Answers
Hey,
I actually had the same problem happen to me and it still occurs every now and then. Try blowing in the end of the cassette adapter while using ur pinky finger to turn the insides of the cassette. Next, turn the volume off on the cassette insert device and insert your cassette adapter. Now turn your volume up slowly and see if this fixed the problem.
Best of luck,
Matt
Posted on Jan 25, 2009
2 Suggested Answers
  • 41 Answers
SOURCE: Can't play songs.
i don`t know if we can use cassette in nano.
In case you want to avail a free technical support,
just get in touch with one of the techbuddies they provide free
technical support, you can find them on http://tinyurl.com/n29l7c
Posted on Jun 18, 2009
I have a 99 ford Taurus and its a cassette tape adapter stuck in it please help me
Been there. Done that. If there is a wire attached to the adapter for connection of the iPod, that most likely is jamming the adapter and preventing ejection. You need a non-metallic tool such as an ice cream stick (not a screwdriver!). While pressing the EJECT button repeatedly, GENTLY pry the adapter up to pop it out. When the operation is over and the patient is recovering, examine the removed adapter. You probably will find that the wire has popped out of its groove and may even have lost some insulation so that will have to be repaired.
Jan 11, 2013 | Cars & Trucks
Tip
How can I connect an iPod to work through a car stereo?
<p>An iPod can store hundreds of songs makes it an ideal source for music on your car. Buy an adapter is the easiest and cheapest way to connect your iPod to your car stereo system. Do you know which adapter fits you best and know how to use the first steps to expand their musical possibilities. <br /> <p><br /> <p>Tape deck <br /> <p>1. Buy an iPod adapter cassette player, if your car has a cassette player. This is one of the easiest and cheapest way to get your iPod to play music from a car radio. A cassette adapter is shaped like a tape with a wire connected to an end. <br /> <p><br /> <p>2. For a cassette adapter or a store of electronic music in good standing. This adapter is relatively easy to find and can usually be purchased for less than $ 20. <br /> <p><br /> <p>3. Slide the cassette tape in the car. Take the end of the cable and connect the headset to your iPod. Select a song to your iPod and press the "Play". Be sure to order the car stereo's cassette player. <br /> <p><br /> <p>FM Transmitter <br /> <p>1. Purchase an FM transmission adapter if your car has a cassette player. This type of adapter connects to both your iPod headphone jack or car cigarette lighter and stream music via FM radio signal. <br /> <p><br /> <p>2. In an FM adapter to send any electronics store. This adapter is a little more expensive than a cassette adapter. Make sure you have an FM transmitter instead, for many FM stations broadcast from a transmitter can only be transmitted to a unit to buy. This gives you more options when you're in certain areas where FM stations are vague or nonexistent. <br /> <p><br /> <p>3. Connect the FM transmitter for the iPod to a lighter (depending on model purchased). Turn on your car's FM radio and find a channel that is unoccupied. Adjust the transmitter to the channel number exactly the same and then to match the iPod. For example, 99.1 FM if you find a free channel in your area, the FM transmitter on 99.1 reading. Connect the iPod and press "Play." <br /> <p><br /> <p>Extra- <br /> <p>1. Purchase an additional cable if your car has an auxiliary input panel. This type of iPod adapter is one of the easiest ways for your iPod to play music in the car. <br /> <p><br /> <p>2. Find a reputable shop and buy an electronic overhead. This type of iPod adapter is usually sold for about $ 10. <br /> <p><br /> <p>3. Connect the cable to the extra auxiliary input on the dashboard of your car and plug it into the iPod headphone jack. Make sure the sound of the car is in standby mode. Select a number and press the "Play" button on the iPod to the music to start. <br />
on Aug 09, 2011 | Apple iPod touch
'96 gmc safari: I bought a cassette adapter to
They aren't in the same family are will never work together! Take it back!
Oct 07, 2012 | Cars & Trucks
I have a brand new tape adapter (for my iPod) that was working for weeks, but after I ejected it, it just keeps ejecting itself right when I try to put it back in. It will play just a tiny bit of the...
You might try flipping the adapter over the other way. If that doesn't work, you might want to try putting a cleaning tape in and clean the cassette heads. The tape player will sometimes eject a tape if it cannot read it very well. It assumes that the tape is damaged. Dirt on your heads can cause it to eject your adapter because it is having trouble reading the signal from the adapter.
Aug 22, 2011 | 1996 Chrysler Concorde
Can't play songs.
Jun 18, 2009 | Apple iPod nano
I can't eject cassette from my Canon MV800i
The mechanical of the tape loading path is misaligned, Contact any expert for mechanical adjustment of the tape loading path, No worries it will work fine again, and this would not be expensive.
Thanks for using fixya.
Jun 16, 2009 | Canon MV800i Mini DV Digital Camcorder
Casstte Player- '94 ford
I think you are saying you are using a cassette adapter to play the external iPod/PSP etc. and I presume the cassette plays regular tapes OK. The auto-reverse cassette player thinks the 'tape' is over, so reverses then ejects. You can try putting in a regular tape, change sides then eject. Try the adapter again. Hopefully the adapter will work in 'one' direction.
Apr 13, 2009 | Car Audio & Video
Canon ZR900 cassette won't eject
you could hit like the method for if a canon won't let you put in a cassette but i don't know if that will work. just hit it on the non screen side a few times and in theory it should work.
if nothing it will get rid of stress
Dec 12, 2008 | Canon ZR900 Mini DV Camcorder
MP3 Cassette Adapter Not Working
hi.....can you check if the rola ( that has teath and roling the tape ) in ur cassette adapter is actually turinig easy because whith the new cassettes if it is hard they swich the sides thinking that the tape finished if they hard try to losen them......hopfully that wil work
Jun 27, 2008 | Alpine TDM-7561 Cassette Player
I have a bose stereo in my 96 nissan Maxima that works poorly
there is a problem in the tape drive - possibly a bad belt- thats why the cassette adapter keeps ejecting itself- most add on xm tuners have the ability to broadcast its signal wirelessly-you press the menu button then turn the tuner to select the menu option that you want then press on the tuner control again to choose broadcast (fm signal and which channel you want to broadcast to the factory radio-try www.xmradio.com for more detailed info
Apr 16, 2008 | Car Audio & Video
2,084 people viewed this question
 Grubhead
Grubhead
