Question about Toshiba e-STUDIO 16 Printer
Connection to printer via parallel eratic
On our network we have a PC that acts as a print server for the toshiba e-studio 16 via a parallel cable the pc is a generic dell running XP home. every so often the connection between the PC and the printer is lost (an error comes up on the screen saying the device is is not responding or not attached) usually the only way to fix it is to delete the printer from the printers section in the OS and re install the driver which can be time consuming and a pain in the *** any suggestions would be greatly appreciated. side note: the parallel is relatively new and of a good quality build
    Scholar:
  • 78 Answers
It appears from what you say, that the driver files are getting corrupted. Typically this may occur as the HDD or controller fails.. The print server may have begun to reach the end of it's useful life. You might consider replacing this computer with another one, especially if it runs 24/7, and has been doing so for several years.
This type of setup is very reliable, and failures usually relate to pending hardware failure.
Optionally, a printer specific internal or an external print server ( like the HP JetDirect EX ... which you can find used on eBay for under $50.00 ) connected directly to the network will provide a reliable alternative to the computer. It uses fewer resources, fewer components to fail, and is more "green".
Posted on Nov 19, 2008
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Hi, I just purchased a Xerox Work Centre 4118 for my office. I have Windows 7 Professional and am unable to Print via wireless. I receive a message that the Printer is offline. Would you be able to...
http://www.support.xerox.com/support/workcentre-4118/downloads/enus.html
The above links to the drivers page, but unfortunately, I do not see specific Windows 7 drivers for this printer. This means that older XP or the latest drivers from the year 2008 are used in emulation mode, maybe, for Windows 7.
Since this is not a 'new' printer, I gather, it will not guaranteed to work with Windows 7. However, I would try the link above for various drivers which may or may not work on this printer.
The fact that the Printer is shown to be offline, is a bad sign.
I read that the printer in question has the following connectivity:
Connectivity
But, that it doesn't support WiFi.
USB, Parallel, optional 10/100 BaseT Ethernet.
Jan 19, 2011 | Xerox WorkCentre 4118 Network Kit...
How to connect toshiba e-studio 25 through usb cable
E-studio 25 only has parallel port. IT does not support USB port.
Feb 01, 2010 | Toshiba e-STUDIO 16 Printer
Drivers for this product. for Windows XP
Does your estudio 250 have the "print option" installed? Most newer Toshiba copiers have the parallel port on the machine, however it has to be enabled by adding a print kit or print option.
May 08, 2009 | Toshiba E-Studio 250 All-In-One Laser...
Connect Kyocera Mita FS-1010 to Macbook (OS X 10.5)
in FS1010 printer usb port avilable u can connect the printer through usb port .
please delet ur printer driver and reconfigure it . use a usb cable to connect the printer it will work.one more u can put ur printer in network
Dec 23, 2008 | Kyocera Mita FS 1010 Laser Printer
I have a new Compaq laptop running Vista home and an old samsung 4216f. I tried a parallel to usb and cannot get the printer to work. No parallel ports on laptop and no usb on printer. Any ideas?
If you have a home network, try a Print Server with parallel port. You will connect the printer to the print server via parallel, and the print server to a network hub/switch/router (any of the listed) via a network cable, and the computer to the hub/switch/router via network cable or wireless.
Cost should be around $20 - $60 depending on make/model.
Nov 30, 2008 | Office Equipment & Supplies
NETWORK
Does your copier have a Network Interface Card ( NIC ) installed in the printer? If not, and if the copier has the Parallel port option installed, you can purchase an HP JetDirect EX network print server, and then connect it to the printer parallel port, and then into your ethernet network. This option is very effective, and a very "Green" solution vs using a computer as a print server for example, or the high cost of adding a Toshiba ethernet option if not already installed.
Nov 07, 2008 | Toshiba e-STUDIO 16 Printer
Network will not initialize
you need to shut the machine down, turn off power and restart it... it should go through the Network Initializing after it has connection with the network, this screen should go away..
Jul 21, 2008 | Toshiba (GM1030) for E-Studio 200L Print...
Toshiba e-studio 350
Do you have printer scanner enabler kit
gm-2010
if not you can't scan
Jan 10, 2008 | Toshiba e-Studio 350 Copier
Toshiba e-STUDIO 16 Printer Logo
153 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
