Question about Motorola Mobility HS850 Consumer Headset
Motorola HS850 and samsung d807
I m trying to link my hs850 to samsung d807, my phone detects the headset and when i hit connect and it asks for a code and i put in code "0000", after trying to connect it fails.
  • tperruso Mar 18, 2009
    Can't get past 4 digit 0000, paring motorola HS850, paring unsuccessful, help?
I have the same problem with my sony phone and h350. plus once i get it connected, eventually it cuts off and disconnects and i cant get the calls to transfer back to my headset. The only thing that helps is if i turn my phone off then back on and go through the pairing process all over. Then it connects perfectly. This method might work for you but it is very inefficient if you have to continue to do this. I am still looking for answers myself
Posted on Apr 30, 2007
I tried Paring my motorola 8s850 for a second time and it tells me my passcode is incorrect...Can't Figure this out at all
Posted on Jan 21, 2007
Can't connect a motorola hs850 with a samsung m520.
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Jun 23, 2009 | HTC G1 Smartphone
Won't pair with Motorola HS850 headset
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Having problems pairing
Apr 12, 2009 | Motorola Mobility Universal Wireless...
Bluetooth head set
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HS850 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Sep 22, 2008 | Motorola Mobility Universal Wireless...
How do i connect motorola hs850 with lgcu720 (shine)
1. With the headset’s boom closed,press and hold the Multifunction
Button E until the headset indicator turns on (about 3 seconds).
2. Release the button, then open the headset boom.
3. The headset indicator remains on.
4. Perform a device discovery from the phone.
5. Select the Motorola HS850 from the discovered devices list and confirm following the on screen prompts.
6. When prompted by the phone, enter the passkey 0000 and confirm to pair the headset with the phone.
The device ID is now stored in the phone’s memory.
Pairing is successful when the headset indicator flashes 10 times
rapidly.
Hope this helps
- Ted G.
Jun 25, 2008 | Motorola Mobility HS850 Consumer Headset
PAIRED MOTOROLA BLUETOOTH WITH SAMSUNG
hold down the connect button on the bluetooth tl the light stays on, then open the boom, release the button. The light should stay on now, and your phone should be able to find you bluetooth.
Jun 18, 2008 | Motorola Mobility HS850 Consumer Headset
Motorola Hs850
The default passcode is "0000" You can get a step by step guide to pairing this headset (plus manual) on the following link: http://www.motorola.com/consumer/v/index.jsp?vgnextoid=38b5f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=fd13e7af976c9010VgnVCM1000008206b00aRCRD
Jul 27, 2007 | Motorola Mobility HS850 Consumer Headset
Samsung A900 and Motorola HS850
Have U tried re-link them? Turn off both device. Then switch the cell phone on first and check if the bluetooth is on. Then link it with the bluetooth. If you lost the manual, search online on the steps to do the linking. Cell phone should be able to detect the bluetooth and finally link with it.
Aug 25, 2006 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
95 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
