When printing from excel 2007, I am getting a printer spooler error "Spooler subsystem App has encountered an error and needs to close" but only when i print on my HP officejet j6480....then other printer works fine
l would start with re-installing the printer drivers for that printer. If that doesn't work, you may have to actually delete the printer, re-start the computer. let the OS re-discover the printer, and re-install the drivers.
Comments:
Nov 19, 2008
- I failed to also suggest that you try the same operation from Word, to see if the results are different? Spooler errors are most commonly driver related. I will assume your disk is not full, or that the print job is not so large as to be running out of space in which to spool that specific job..
i have replaced the ink toners with the ones you refill and replaced the correct chips on each one. ...
(More)
i have replaced the ink toners with the ones you refill and replaced the correct chips on each one. the red light comes on to replace the toner, I open the lid take out the toner that it is telling me give it a quick shake replace and the light will turn green again, only to turn to red after the 2nd printout it switches color suggestions every time at other times it will ask me to replace the waste toner tank which I have taken out and cleaned and put it back in place. Do I need to get a new waste toner tank? Do I need to get the toners that are not refillable?
I keep getting an out of paper error message on the photo paper carrier even when it is full of...
(More)
I keep getting an out of paper error message on the photo paper carrier even when it is full of paper. any ideas?
