Question about Aspire Digital Aspire X-Navigator, Silver-Black Metal case, 450W, w/window (ATXA9NWAL)
My five fans stopped working
I was on the computer when it just shut completely off. I manually turned it back on but thought it wasn't working because it was so quite. That's when I noticed none of my 5 fans worked. My power fan works and of course so does my cpu. At first the computer kept shutting off after so long. I went into the bios and changed it back to default settings and it has not shut off since. My problem is I don't know why the fans stopped or how to fix it? I tried going into the tower and try to reconnect the fan wires but now I don't even have the lcd for the front hooked up right and I can't find any manuals to see how to hook up all these wires. Can somebody help? I'm not sure how serious of a problem this is and if I can just use my computer as it is since I'm not a serious gamer and I really don't need so many fans.
    New Friend:
  • 128 Answers
As long as the CPU fan is operational your OK - the land in the power supply for the 12VDC fan voltage probably got hot and has an intermittent connection. You could try to connect the fans to another power supply connector - but as far as the computer itself you should be OK
Posted on Nov 24, 2008
Replaced fan cant get rid of fan error
I believe in laptops the fan is a integral part which must be plugged in to function , you have installed a new fan so i would suggest opening the computer again locating the cmos battery and holding it for a minute then put it back in and reassemble it should then work!
Mar 02, 2012 | IBM Lenovo ThinkPad X61 Notebook
I recently replaced the fan motor and capacitor for my condensing unit. The fan worked fine for a couple of days, but now after the unit turns on and runs for a time (minutes to an hour or so) the fan...
Yes, you either got a bad capacitor or the wrong one. As, it seems that it's overheating. When that happens it shuts OFF. After an hour of cooling, it functions again. If that's the case, in no time at all, it will fail completely.
Hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | Heating & Cooling
1999 chevy cavalier. wasn,t getting heat to inside. put in new thermostat. heated up fine for a couple of miles, then cool air. shut off when got back home. anitfreeze was bubbling back out of reservoir....
make sure you get ALL the air out run it without cap until you see water circulate turn heater to hot NO FAN ABOUT 5 MIN close cap ,see if that works
Nov 29, 2010 | 1999 Chevrolet Cavalier
The computer is an acer 5630 laptop. Before i changed the motherboard I would turn on the laptop and five seconds later The fan would shut off and all the lights would stay on. I purchased a motherboard...
fan always start working when u switch on the laptop, then it stop because it monitor your cpu temprature if CPU temp is blow the level of heating then it stay stop and if it exceed the limit of cooling then fan automatically start to just kick out heat of CPU, so it is normal, but tell me did u get display when fan switch off? let me know
Aug 24, 2009 | Computers & Internet
2004 s40 volvo-ac works for 10 minutes then gets warm.
evaporator leaking or condensor fan inop
Jul 31, 2009 | 2004 Volvo S40
My Gateway laptop shuts off after five minutes. I
Hi there.
There is probably dust trapped in the air vents and around the CPU fan, the best way to clear it is to turn the machine off, get a can of compressed air and give short blast through the air vents.
The CPU fan is usually located under the laptop and give a couple of blasts through that too.
Once your happy that all the dust is removed you can turn the laptop on again and it should stay on for much longer.
The cooling pad won't make any difference if the issue is dust.
Good luck and thanks for choosing FixYa!!
Jun 05, 2009 | Gateway 7510GX Notebook
Fan quits and the compressor still runs
is this a split residential system. it sounds like you are talking about the condenser fan either way it seems like the fan is overamping and tripping on thermal overload which is a device in the motor that protects itself. when you shut it off for a while and turn it back on does the fan work. if you turn it off then turn it right back on does the fan work. when it shuts off is the motor really hot. if possible, and you know how, check amp draw. typically you can find the rated amp draw on the motor nameplate.
May 27, 2009 | Carrier 52CQ315 Air Conditioner
Computer won't start
When the screen is black, try pressing Ctrl + Alt + Del; a soft reset should kick it back into gear. Did the laptop shut down unexpectedly due to power loss/overheating/etc..?
Apr 20, 2009 | Acer Computers & Internet
My computer is turning on and off continually
download memtest and burn the iso to a cd and boot from it to test your ram, it usually only takes a few minutes to see if your ram is bad or not, otherwise ive had computers with bad system boards (blown capacitors) that reboot themselves, and also computers that are overheating reboot themselves, check to make sure all air vents aren't blocked and that all of your case fans run well
Feb 19, 2009 | Gateway GT5220 PC Desktop
Computer shutting down
  1. Be sure your power supply is working and charging battery
  2. Allow battery to full charge
  3. Be sure PC is cold not hot or warm
  4. check if before shutting down PC fan is starting: if not starting PC thermal protection can be triggered and your fan out of service.
Jan 14, 2009 | Acer Aspire 3000 Notebook
Aspire Digital Aspire X-Navigator, Silver-Black Metal case, 450W, w/window (ATXA9NWAL) Logo
88 people viewed this question
Top Aspire Digital Computers & Internet Experts
David Payne
David Payne
Are you an Aspire Digital Computer and Internet Expert? Answer questions, earn points and help others
