Question about Brother DCP 115C All-In-One InkJet Printer
Too small print on Brother printer MFC-490CW
Prints very small type while online
SOURCE: my Brother MFC-490CW won't print
Did you try onboard print test by pressing INK LEVEL button. I am having similar problem but color prints but black does not. The printer has built in diagnostics that walks you thru some troubleshooting steps. It has you repeat cleaning 5 times and then asks you to replace cartridges if test fails...than repeat tests and call customer support if that does not work. Which I may do soon.
Posted on Jul 25, 2009
  • 60 Answers
SOURCE: Brother MFC-490CW printer Does not connect to my computer
You willl need to setup the printer first to use the wirelss in your place. Once you have that you will need to have the cd to install the printer and it should work.
DirectTech Computers
Palm Desert, Ca
Brother ASC Center
Posted on Jan 01, 2010
cns assoc
  • 677 Answers
SOURCE: Brother MFC-440CN USB Printer double prints letters
Did you use Brother Genuine Cartirdges????
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine.
When they see it’s Generic Cartridges, it will print lines thru the words, mis-align the letters & put stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Jan 30, 2010
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
  • 48 Answers
SOURCE: Need service manuals
You can access all of Brother's printer manuals online at their website in .pdf for free. Just go to http://www.brother-usa.com/manuals/default.aspx?PGID=5&R3ModelID=DCP165c and find your printers; you don't even have to download them.
Posted on Aug 17, 2010
Prints out blank pages, won't test print, new ink, cleaned multi-times, still blank!
Silly question from my side: have you removed the tape covering the nozzles of the cartridges? Is it original Brother cartridges, or is it compatibles?
Aug 23, 2011 | Brother MFC 490cw Color Inkjet...
My Brother MFC-490CW prints magenta where it should be printing black. I have done numerous cleanings and alignments. I changed the black cartridge and it is a Brother cartridge, not a refill. Still...
Well, either your print settings have it set to print in a color model that is not the native one (I can get this from CUPS drivers by picking KMCY instead of CMYK, among others) or it is confused enough to need Brother's initializing tool (program, I mean) to get it sorted out. Try de-weirding your settings first, then double-check the print dialog's settings when you retry. Nobody loves magenta-on-white for print.
Jul 25, 2011 | Brother MFC 490cw Color Inkjet...
HI! my printer brother mfc-490cw is offline and wont print .what do i have to do to get it on line ? i own a mac . Louie
Go to system settings and select the 'Printer' option. Right-click on the printer and enable the 'Use Printer Online' function. Cancel all the printing jobs till that moment and redo the process. Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue. Check all network connections and functions. Be sure the network interfaces work properly. Turn the printer off and on to see whether the device is working properly.
Mar 18, 2011 | Brother MFC 490cw Color Inkjet...
My brother MFC 790-cw prints color images in black and white only
Hello
the color cartridge may gone empty or dried, try other cartridge or clean the head of the printer.
Good Luck
Dec 22, 2010 | Brother MFC 490cw Color Inkjet...
My Brother MFC-495cw will not print. It pulls paper through but nothing prints.
This is due to the ink...Check you ink cartridges if they are still full of if the ink has dried out thats wht printing is not working
Jun 11, 2010 | Brother MFC 490cw Color Inkjet...
My MFC 490 cw only prints yellow and magenta. All
You should run a few cleanings. Push the ink button then down arrow for cleaning and push ok.
Mar 27, 2010 | Brother MFC 490cw Color Inkjet...
My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
Nov 10, 2009 | Brother MFC 490cw Color Inkjet...
My Brother MFC-490CW won't print
Apr 25, 2009 | Brother MFC 490cw Color Inkjet...
Brother DCP 115C All-In-One InkJet Printer Logo
490 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
