Question about Whirlpool Refrigerators
Freezer & refrigerator do not cool
The refrigerator and freezer were not working when i returned from a week long vacation. The fan and the lights work but no cooling. All of the contents were thawed and ruined. Help!!
It is a side by side model ED5FHEXMBOO
4 Suggested Answers
  • 958 Answers
SOURCE: FRS22ZRG- Problem with Refrigerator cooling, freezer works fine
hi,
keep me posted what happened next?..we were disconnected.
tnx 4 using fixya,
drcool
P.S. please if you are satisfied whith my help, kindly rate my chat . tnx again
drcool
Posted on Oct 07, 2008
22yooper
  • 828 Answers
SOURCE: Freezer / Refrigerator not cooling
When the fans are running the compressor should also be running. If the compressor is hot but not running you have a compressor problem. If the compressor is running check for frost on back wall of the freezer compartment which would indicate a defrost system problem. At five years old have you cleaned the condenser where the heat is transferred to the outside air in the room?
Posted on Nov 19, 2008
philbran
  • 242 Answers
SOURCE: Neither refrigerator nor freezer cooling.
sounds like the compressor or relay went out. if the compressor is hot turn off and let cool to room temp. and try it then [a few hours] , if it is not hot then replace the relay on the compressor.
Phil
Posted on Jun 10, 2009
Top freezer cold, lower part 40 -50 degrees, vacuumed condenser already, what part blows coldness too refrigerator area?
Check for ice build up in the rear of the freezer if so defrost unit and the fan should come back on
Sep 05, 2015 | Refrigerators
Hi I have pressed the vacation button on my side by side refrigerator/freezer as we are going away for 8 weeks. The display has lit up but there is no difference in the way the fridge is operating - same...
The settings will reset to a lower settting as the fridge/freezer will not be disturbed . So wait for the fridge to run and shut down and it will continue to run in this low mode to save power but to keep the food in prime condition. The fridge alone will not be shut down.
Aug 31, 2011 | Samsung SRS20DTD Side by Side Refrigerator
Refrigerator and freezer were working properly before an extended vacation. Cleaned both refrigerator and freezer, unplugged, and left doors open. Upon return plugged in and have waited 72 hours. ...
Let's think this through a bit....
You say it is cooling but it seems too quiet.... is the compressor runing but the condenser fan is not??? that would make it cool but not cold and also make it more quiet...
If both compressor and condenser fan are running... is the evaporator fan... the one inside the freezer running? That also could cause the same problems...
Is the compressor running all of the time??? or is it cycling? if it is cycling then it could be a t-stat or sensor problem....if it is not starting properly it may be a capacitor/relay problem...
These are alll things that you can easily check yourself....
If they all checkout... then the unit may have a small refrigerant leak and just will not cool enough now to catchup from a earm condition....
To check that out you would need a tech. to attach gauges to the system and check the charge...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
Amana Model SZD25NL is not cooling at all, neither
compresor fan working? if it is not you need to consider the compressor starter need to be replace
Dec 29, 2009 | Refrigerators
Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Sep 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Phil
Jun 10, 2009 | Kenmore 52582 / 52584
Refrigerator not cooling.
for what you say you have defrost problem
Apr 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Nov 19, 2008 | Whirlpool ED5FHEXMQ Side by Side...
hi,
tnx 4 using fixya,
drcool
drcool
Oct 06, 2008 | Refrigerators
Refrigerators Logo
256 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
