Re: The compartment where the electrical plug conects...
Go to a computer repair store they often carry spare new or used parts, or go to www.ebay.com Type make and model of laptop, and refine search to power supply.
If you look under glove box you will see two to four screws that hold the glove box on. Take out the screws and the glove box will drop down and you can get inside and release latch..then you can get a replacement latch and replace.
The hoses dont go together, they are the vacuum lines that operate your heating and air dams. The black one is the vacuum line in from the engine compartment and the others operate a certain selection. You can hook the black into any one of the hoses to make the air operate the desired location.
A common problem for older vehicles is that A/C-Heater blower stops and goes due to loose electrical connections. some people try to "kick" or "bang" around the blower compartment to make it vibrate and work. I suggest have it take out and clean and tight up the electrical conection.
hope this helps.
Yes. The elements are individually replaceable. Depending on the element, the small one P/N is WB30X342,
the large element P/N is WB30X348.
Unplug the cook-top or turn the breakers off. Pull the burner out horizontally and upward to expose the screw connectors. Unfasten the wires, remove the element, place new element in place, conect the wires, and reinstall.
artielou, I assume that you've checked the fuse panel in the passenger compartment. There is a fuse and relay panel under the hood in the engine compartment. Get a 12 volt test light or multimeter and start tracing the lines from the master panel under the hood to the panel inside until you find the broken conection or blown fuse. Try to have as much patience as possible in that electrical systems sometimes have a mind of their own. Good Luck, quicbric (the volvo man)
go to home depot and get the replacement element for the brinkmann gourmet smoker. costs $29.95. the replacement parts from charbroil (thermostat and element) will cost about $60.00. just remove the elemnt, replace it with the brinkmann and you're back in business.
