Question about Lexmark Office Equipment & Supplies
My printer/fax machine will not print. it is saying to remove a paper jam. there is no paper jam. i have followed the steps as far as turning it off and back on plus i hit the check button and still nothing. i need to print important papers on a daily basis. i have not had this machine a whole year. i need my machine fixed or a replacement. thanks.
    Scholar:
  • 78 Answers
Was there a paper jam just prior to this problem occurring? If so, look for any small pieces of paper that might be causing a jam. This may take a flashlight, and a close inspection of the entire paper path. This type of error generally occurs when the paper path is being blocked, or the paper can not move to the proper registration point ( ready position ) in the printer.
Posted on Nov 19, 2008
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
How to clear and avoid paper jams
Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
Paper jam in the printer
Remove the paper manually
  1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
  2. Firmly grasp the paper, and gently pull it out.
  3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
Paper jam in the paper support
Paper or specialty media misfeeds
These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
Try one or more of the following:
Check paper condition
  • Use only new, unwrinkled paper.
Check paper loading
  • Load a smaller amount of paper into the printer.
  • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
Remove each page as it is printed
  • Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper guides
  • When using media less than 8.5 inches wide
  • To rest against the edges of the paper or media, making sure it does not buckle
Printer does not feed paper, envelopes, or specialty media
These are possible solutions. Try one or more of the following:
Check for paper jams
  • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
Check media loading
  • Verify that the specialty media is loaded correctly.
  • Try loading one page, envelope, or sheet of specialty media at a time.
Check printer default and pause settings
  1. Click:
    • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
    • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
  2. Double-click the print queue device.
  3. Click Printer.
    • Make sure no check mark appears next to Pause Printing.
    • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
Banner paper jams
There are many possible solutions. Try one or more of the following:
Clear banner paper jams
  2. Remove the jammed banner paper from the printer.
Review banner printing checklist
  • Use only the number of sheets needed for the banner.
  • Select the following settings to enable the printer to feed paper continuously without jamming:
    1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
    2. Click Properties, Preferences, Options, or Setup.
    3. Select the Paper Setup tab.
    4. From the Paper Size area, select Banner.
    5. Select Letter Banner or A4 Banner as the paper size.
    6. Select Portrait or Landscape.
    7. Click OK.
    8. Click OK or Print.
Regards,
Ron
Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
Cannot remove the paper jam
To clear the message Paper Jam from the display, follow the steps listed below:
NOTE: images shown below are from a representative product and may differ from your Brother machine.
STEP A. Check for and remove any jammed paper or foreign objects in the machine
  1. Unplug the Brother machine from the power outlet.
    Caution Before you unplug the machine from the power source, you can transfer your faxes that are stored in the memory to your PC or another fax machine so you will not lose any important messages. Refer to the Related FAQs in the end of the page for information. (only for applicable models)
  2. Lift the scanner cover using the plastic tabs or finger holds, located on the left and right side of the machine until it locks securely into the open position.
    Caution DO NOT touch the encoder strip. The encoder strip is a clear plastic strip in front of the white vinyl band (outlined in red as shown in the picture below). If the encoder gets markings or debris on its surface, it may cause other problems.
  3. Verify the location of the print head. The print head is a black square object, located behind the encoder strip. The print head moves from left to right.
  4. Move the print head to the middle using your fingers.
    Caution DO NOT touch the encoder strip (marked in red shown below).
  5. Check for and remove any ripped paper or a foreign object in the left corners or underneath the print head.
    Hint The ripped paper may be very small. Using a flashlight will help you to find the ripped paper.
  6. Turn the machine around and open the Jam Clear Cover (1). Look inside the machine and remove any jammed paper.
  7. Close the Jam Clear Cover. Make sure the cover is closed properly.
  8. After removing all of the paper scraps, Close the scanner cover by lifting the scanner cover to release the lock. Gently push the green scanner cover support down and then close the cover.
  9. Remove the paper tray (1) from the machine.
  10. Place one of your hands under the LCD unit and into the opening of where the paper tray was.
  11. Using your hand, lift the front of the machine approximately 6 inches off the surface.
  12. Look inside the tray areas roof of the machine and a row of black rollers will be aligned across. See picture below.
  13. Look in-between each of the black exit rollers for a piece of stuck scrap paper. (A flash light may need to be used if you are having trouble locating the paper scrap).
  14. Using a pair of tweezers, the paper scrap can be easily removed from the exit rollers.
  15. Place the machine gently down onto the surface.
    • If no paper scraps were found inside the machine, please check the paper in the tray. If the paper is slightly curled, the print head will catch the edge of the paper and tear it. To resolve the issue, the paper in the tray must be replaced and continue to STEP 16.
    • If paper scraps were found and removed from the machine, continue to STEP 16.
  16. Put the paper tray back into the machine.
  17. Plug the power cord back into the power outlet.
    • If the LCD displays the date and time, go to STEP D.
    • If LCD displays the message "Paper Jam" go to STEP B.
- If the print head is on the right side:
  1. Plug the power cord back into the power outlet and wait for the machine to stop making noises.
  2. Press the Stop/Exit key for approximately 5 seconds until the print head moves to the middle.
  3. Unplug the machine from the power outlet.
    Caution Make sure to unplug the machine. The print head may move and injure your hand. Before you unplug the machine, you can transfer your faxes that are stored in the memory to your PC or another fax machine so you will not lose any important messages. Refer to the Related FAQs in the end of the page for information. (only for applicable models)
  4. Examine the right side of the machine where the print head had been positioned and underneath the print head and remove any pieces of ripped paper or foreign objects.
    Tweezers may be used with caution to remove paper scraps or the foreign objects.
  5. After confirm the paper scraps or the foreign objects in the right corners or underneath the print head, go to STEP 6.
Mar 10, 2011 | Brother MFC255CW All-in-One InkJet Printer
Machine diplays "paper jammed" with no paper in
Hello
This the method to clear paper jam, follow these steps:-
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Open any other doors that give access to the printer's paper path and to the ink cartridge. 5 If necessary, remove the ink cartridge. Place it in a bag or away from light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Replace the ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Good Luck
Dec 18, 2010 | Sharp UX-B20 Plain Paper Inkjet Fax
Paper jam in fax how do I clear?
folow the instruction
Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
  • Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
  • Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
  • Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
  • Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
  • Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
  • Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
  • Apr 20, 2010 | HP LaserJet 3055 All-In-One Printer
    My Canon MP530 indicates that I have a paper jam. There is no paper jam - I have checked and re-checked and turned it off and on several times and it is still reading that there is a paper jam. How do I...
    Hello there You may not see a paper jam.
    This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
    First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
    If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
    And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
    Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
    That is where you'll find the print head assembly parked on top of it.
    It also has an electrical pump to milk the print heads and test for ink flow.
    So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Mar 25, 2010 | Canon PIXMA MP530 All-In-One InkJet...
    It say paper jam and ther is no paper jam
    Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
    1. Turn off your printer
    2. Open all trays and remove any paper stuck there
    3. Locate the button to open the printer, open it and remove any paper stuck there also.
    4. Repeate the above step for all buttons that you can find to access the inside of the printer
    5. Close all doors and put back all trays
    6. Turn on your printer
    NOTE: Please rate our help to keep this free service online.
    Dec 31, 2009 | Samsung SF-335T Plain Paper Inkjet Fax
    It says paper jam, but there is no jam
    Dec 17, 2009 | HP 1010 Plain Paper Inkjet Fax
    Canon Pixma MP160 shows errors E3 and won't print
    Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
    Paper Jams :
    Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
    Landscape Credit Card sized paper jams inside the machine.
    Action : Remove the paper according to the following procedure.
    1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
    * If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
    * If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
    2) Reload the paper into the machine and press [Black] or [Color].
    * If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
    If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
    Important : You cannot load Credit Card sized paper in the landscape orientation.
    Hope this helps.
    Have a good day.
    Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Message unable to print 50
    Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
    Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
    52 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
