Question about Samsung SC-D363 Mini DV Digital Camcorder
No play back image
My Samsung mini dv shows that I am recording but will not play back any image.I have tried a different tape but with the same problem.
  • 1 more comment
  • Anonymous Dec 10, 2007
    will record but will NOT playback... any suggestions
  • HighNoon Dec 10, 2007
    so i have tried the SD card solution with success, but how do i get my tape to be able to play back again, what is the problem that it will still record but not play back... again the SD card does record and playback, but the tape will not playback!! I'm going to europe and i need my camcorder
  • tlna01 Dec 26, 2007
    i dont know much about mini dv's but all of a sudden my tapes have no playback. they say they're recording but nothing is on there to play back. please help. need it to work for new years.
I was having the same problem. What You can do is try is using a micro Sd card. It works for me
Posted on Jul 01, 2007
SOURCE:
I have a Samsung camcorder and when I play mini dv tape recordings from Canon camera I recorded on , the sound is distorted
If the tape plays correctly in the Canon camcorder, here are a couple of possible reasons for the issues you are having:
1. the Samsung camcorder has a cleaning issue - try running a dry head cleaning tape for about 5 to 10 seconds and see if that helps.
2. The alignment is off between the two different camcorders. Nothing you personally can do about that, but a repair center would be able to correctly align the tape path on both camcorders.
Do the tapes that you record on the Samsung have issues when you play them back on the Samsung? If so, you have a problem with that camcorder (may be cleaning, but could be a mechanism problem) Hope this has helped you. www.austintelstarservices.com
Aug 30, 2010 | Samsung SC-D353 Mini DV Digital Camcorder
Lines through the tape when recording or playing back
It could need a head adjustment. Any camera store can do that for you.
Feb 11, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
Wont let me record! Flashes "Protection!"
My Samsung camcorder one day displays protection. Used or new tape no difference. Used the menu options to remove protection and it gives me a play mode alert. Regardless I can not record in protection mode. Help!
Feb 08, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
Panasonic nv gs50 camcorder not recording images
Try using a different tape or cd. It could be faulty media.
Jan 05, 2009 | Panasonic NV-GS50 Mini DV Digital...
Distorted sound on playback, samsung mini dv camcorder.
Try a DV tape cleaner first. If that doesn't work, see what it would take to get the audio heads realigned. Any camera store can do that for you.
Dec 18, 2008 | Samsung SC-D67 Mini DV Digital Camcorder
JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Oct 15, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Samsung SC-D363 Mini DV Digital Camcorder Logo
66 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
